fairing and polishing #134738
03/03/08 04:12 PM
03/03/08 04:12 PM
fin. Offline OP
fin.  Offline OP
When do you stop? 1200? 1500? 2500?
Re: fairing and polishing [Re: fin.] #134739
03/04/08 09:01 AM
03/04/08 09:01 AM
Mark P Offline
Mark P  Offline
You know when you've done enough when you consider polishing with toothpaste!!! On a more serious note I find 'Tetrosyl' Rubbing Compound to be superb at polishing hulls and foils. If your local Motor Factors doesn't stock Tetrosly then maybe enquire about an alternative rubbing compound as I'm positive you wont be disappointed with the results.
For general hull cleaning I use a caravan/boat cleaner, it can get rid of light marks whilst at the same time provides a very light 'T' cut to the Gel coat. There's also very little detergent so no problems with sliding about afterwards on the gleaming hulls <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
MP*MULTIHULLS
Re: fairing and polishing [Re: Mark P] #134740
03/04/08 04:42 PM
03/04/08 04:42 PM
fin. Offline OP
fin.  Offline OP
My arm wore out, so I finished with 2000 and a very light rubbing compound. Not perfect, but it's all I'm doing! <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: fairing and polishing [Re: fin.] #134741
03/04/08 08:17 PM
03/04/08 08:17 PM
South Carolina, USA
Corksfloat Offline
Corksfloat  Offline
South Carolina, USA
Go to Northern Tool and you can purchase a buffer for about $60. Then use rubbung compound, then go to polishing compound and finish with a silicone car wax. This will give you awesome results.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200319667_200319667
Re: fairing and polishing [Re: Corksfloat] #134742
03/04/08 08:43 PM
03/04/08 08:43 PM
Milwaukee 9" grinder with a 3M buffer head. Then just a cleaner wax with a foam pad. Your arms will still be sore though, that thing is a brute to hang on to.
Re: fairing and polishing [Re: Karl_Brogger] #134743
03/05/08 06:04 AM
03/05/08 06:04 AM
fin. Offline OP
fin.  Offline OP
I have a big honkin' grinder, but prefer to wet sand. Better feel, less dust, less chance of cutting through the gel coat.
btw- I rolled the gel coat on. It was work to smooth it out, but not as bad as I had feared. From here on out my rule is: white boats and gel coat. NO PAINT!
bbtw- I applied the gel coat on a very cool day, 63 degrees. The temp. prompted me to use more hardener than was necessary, causing the gel to "tack" before I was ready. Next time, experimenting with the hardener should reduce the work significantly.
Re: fairing and polishing [Re: fin.] #134744
03/05/08 08:21 AM
03/05/08 08:21 AM
Use the grinder with the buffing pad to work the wax. I use Mcguires cleaner wax in a paste. The boat looks brand new in no time. No dust really.
Re: fairing and polishing [Re: Karl_Brogger] #134745
03/05/08 08:11 PM
03/05/08 08:11 PM
South Carolina, USA
Corksfloat Offline
Corksfloat  Offline
South Carolina, USA
If you liked those results then you should thin it with acetone and spray it on. Then you will only be polishing the work you've done.
Re: fairing and polishing [Re: Corksfloat] #134746
03/05/08 08:22 PM
03/05/08 08:22 PM
fin. Offline OP
fin.  Offline OP
Next time, I'll try spray.
0 registered members (), 2,096 guests, and 352 spiders.
