Cracks & beam bolts #134764
03/04/08 03:50 AM
03/04/08 03:50 AM
Simon C Offline OP
Simon C  Offline OP
Hi All,
Just going over the boat for the upcoming weekend and I noticed
a couple of small cracks in the deck (ply), inside at the front beam,both
fore and aft of the beam. They have appeared after a couple of recent outings
in heavy conditions. (blurry photo atached.)
Cause?
Cure?
When investigating, I checked the beam bolts and whilst tight, they were not as tight
as I would have thought. Can they be too tight?
Any input welcome!
Simon
Taipan AUS341
Re: Cracks & beam bolts [Re: Simon C] #134765
03/04/08 05:52 AM
03/04/08 05:52 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Simon
It may be just the paint cracking a bit, if its on both sides of the beam, and is on the rear beam, theres a fair bit of twist occuring at the rear beam, but I guess theres movement at all beam mountings, especially a mossie with its smaller beams.
Beam bolts - I think firm, but not over tight as you will damage the bolts and make them hard to remove when you want/need to. Without really knowing the right answer, I would say if you've had the beam bolts undone at any stage, do them up firmly and after been for a sail I would check them again. Not sure how often they need checking after that, as much as you like I guess.
Sorry just re-read your post, being the main beam, but I still think it applies anyway.
Regards
Re: Cracks & beam bolts [Re: mattaipan] #134766
03/04/08 08:11 PM
03/04/08 08:11 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
I tighten my beam bolts a couple of times a year, as tight as I can get them with a 7 inch long spanner.
Darryn
Mozzy
1782
Re: Cracks & beam bolts [Re: Simon C] #134767
03/05/08 05:46 AM
03/05/08 05:46 AM
Peter_Foulsum Offline
Simon,
Do the bolts up tight. There can be allot of damage to the supporting structure and/or hull movement if they are loose. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Maintaining a good compressive load on the joints will prolong hull life and maintain correct toe out. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Just don't do them up so hard that you can't get them off.
Peter
Mosquito 1814
Macka Mozzie
Re: Cracks & beam bolts [Re: Peter_Foulsum] #134768
03/05/08 06:34 PM
03/05/08 06:34 PM
Simon C Offline OP
Simon C  Offline OP
Thank you Matt, Darryn and Peter.
Using Darryn's measure, I got a good turn on them with the 7 incher so I guess I got my answer.
Cheers and thanks again.
Simon
Taipan AUS341
0 registered members (), 567 guests, and 26 spiders.
