| Re: DS12
[Re: ]
#135087 06/25/08 02:06 AM 06/25/08 02:06 AM |
Posts: 1,383 Kingston SE South Australia | Scarecrow, Now you and I know real pressure thanks to Gato regards
| | | Re: DS12
[Re: Luiz]
#135088 06/25/08 07:56 AM 06/25/08 07:56 AM |
Posts: 435 Finland | It's faster than the Laser in windspeeds over 5 knots, downwind it can sail around it. Trapeze <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> the kid asked for a kite when he came ashore <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> In fact I think we are quite all right with the sail area and the mast lenght. At least here it's not allowed to have somethig on the car that exeedes it with more than 2 meters. This kid has been sailing Optimist, and since last year he is crewing on a 29:er, no multihull experiense, it took him about 10 minutes to get the hang on the thing. this cat is extremly easy to handle. At least here where the cats are not so common I think it could last up to 15 -16 years old equipped with a kite for the older ones. http://www.gust.ax/gallery/f12/08-06-25/
| | | Re: DS12
[Re: Rolf_Nilsen]
#135090 06/26/08 02:11 AM 06/26/08 02:11 AM |
Posts: 435 Finland | Not thinking of disappering quite yet, even if I sometimes are a little bit surprised about the catsailors. Went to see the guys on the Archipelago raid, and there was only one that even bothered to answer some questions... If they come to ask for a boat, well I tell them to build one... I am alredy looking at something like this http://www.graingerdesigns.com.au/stock-plan-detail-145.php | | | Re: DS12
[Re: Gato]
#135091 06/26/08 08:20 AM 06/26/08 08:20 AM |
Joined: Mar 2005 Posts: 322 South Australia Marcus F16
Posts: 322 South Australia | Grainger designs are pretty good......good choice.
Marcus Towell
| | | Re: DS12
[Re: Marcus F16]
#135092 08/06/08 07:28 AM 08/06/08 07:28 AM |
Posts: 120 Finland | I got to sail Gato's DS12 last week and I think that I should post some comments about it (from 75 kg's adults point of view).
I was really surprised how well it handled my weight, conditions were really light and I was significantly faster than a small (<50 kg?) girl in Laser 4.7 directly downwind. Biggest problem in light conditions was that it took some speed to get the daggerboards work and it meant few seconds drifting sideways every time that gust came (when I wasn't moving at all), after I gained some speed pointing abilities were decent. Also the boat was really light to handle on the ground, I guess that even mom with ~12 year old kid could manage with it.
If mass production prices will be low enough and it doesn't gain lot more weight then I believe that F12 has lot of potential to be a success.
ps. Test sail got me wondering about foam-carbon (a la A-cat) DS12 weighting about 40 kg's (for adults only, the XXX edition <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />).
Valtteri
| | | Re: DS12
[Re: valtteri]
#135095 08/06/08 04:33 PM 08/06/08 04:33 PM |
Great report Val !
I'm really pleased to see the DS12 (F12's) living up to the expectations.
| | | Re: DS12
[Re: Gato]
#172913 03/26/09 08:44 AM 03/26/09 08:44 AM |
Posts: 2 | Great thread guys. I'm a Math teacher here in Texas. I built 3 wooden boats with my students in a Math class a few years ago. If I may make a few suggestions I think it may make it actually a bit easier. Scarfing is a process which can give students a bit of trouble. The reason being that if you don't scarf evenly you'll end up with voids in the hull or dimples. A simple butt block joint works well and is VERY easy to make for the students. You can use it as a structural point as well and put braces on each side. Second, have you thought about stich and glue for the construction. I know we only built 12 row boats, but Epoxy and Meranti 6566 wood still only turned out to be $300 per boat using this method and the only real tools needed were a jigsaw and sandpaper. You can see some pictures by going to my website www.texasspearfishing.com and looking at boat building 101
20,751
guests, and 1,104
