Page 2 of 3 1 2 3
Re: Trailer - Rudders On or Off? [Re: ] #135202
03/07/08 07:34 PM
03/07/08 07:34 PM
I take them off.
Re: Trailer - Rudders On or Off? [Re: Jake] #135203
03/07/08 07:57 PM
03/07/08 07:57 PM
West Virginia
Soapysails Offline
Soapysails  Offline
West Virginia
Unless you have a relief system to hold the rudders in place and take the bounch effect out, I would remove mine. "Most accidents happen within 25 miles of home" just a thought..
Re: Trailer - Rudders On or Off? [Re: Soapysails] #135204
03/07/08 08:14 PM
03/07/08 08:14 PM
Guys:
The wind and vibration will tear your rudders system up. Think of them as power steering. You take all the time to get it tweaked then destroy it on the way home. Plus it should be hard on the gudgeons? Take th off.
Doug
Re: Trailer - Rudders On or Off? [Re: ] #135205
03/07/08 08:31 PM
03/07/08 08:31 PM
Commerce, MI
tigerboy1 Offline
tigerboy1  Offline
Commerce, MI
I use carbon rudders on my Tiger and take them OFF when trailering. Generally it is best to remove your rudders. Saves on wear'n'tear and you'll also get more life out of your rudder system.
Re: Trailer - Rudders On or Off? [Re: Jake] #135206
03/07/08 08:37 PM
03/07/08 08:37 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
OFF - Nobody over here would dream of leaving rudders on - except Hobie 16 or 18 sailors - which we don't have anymore <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Dermot
Catapult 265
Re: Trailer - Rudders On or Off? [Re: Mary] #135207
03/07/08 08:54 PM
03/07/08 08:54 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Yeah, but if you take them off, how do you get them back on the correct sides? That's always been OUR problem.
Nuts in.
Did I just say that?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Trailer - Rudders On or Off? [Re: hobie1616] #135208
03/07/08 09:47 PM
03/07/08 09:47 PM
(I once saw a Hobie 20 go through a toll booth with the rudder swinging loose side to side...narrowly avoided having the rudder arm jam against the toll booth.)
You gotta watch out for those Hobie 20 sailors, they need all the help they can get! <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Quote:
If you owned a hobie, I could understand your fustration with putting them on and off...
...I needed a damn hammer to get my 17's rudder pins in and out.
A lot of guys carry a 1/2" wrench around and take the rudder off of the lower cstng. Then they put a bungee cord between the lowers to keep them from flopping around. Quick and easy.
That's what we do. Same set up as the 20, which BTW originally had four individual pins and someone had a better idea. I even removed the gudgeons to reseat and better align them for the long pins...to no avail. It's a bitch, but I take ours OFF.
Re: Trailer - Rudders On or Off? [Re: _flatlander_] #135209
03/08/08 12:12 AM
03/08/08 12:12 AM
Southern California
H
HealeyBN7 Offline OP
H
Southern California
Thanks everyone. Looks like the tally is 11 Off vs 3 On. Since it really isn't too hard to remove and reinstall them on the Nacra, I'll be removing them for now.
Hope to get some new pictures posted this weekend, so you can offer advice on my setup.
Dean
Re: Trailer - Rudders On or Off? [Re: HealeyBN7] #135210
03/08/08 01:59 AM
03/08/08 01:59 AM
Minnesota
Jeff Peterson Offline
Minnesota
I solved this complex trailering issue by buying a lake home. Now, I leave everything on (except the trailer, that's useless now).
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Trailer - Rudders On or Off? [Re: Jeff Peterson] #135211
03/08/08 03:49 PM
03/08/08 03:49 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
How do you re-install the rudders correctly??
When removing my rudders from the trailerbox I determine which way the tiller arm extention is angled ... secondly, I install the bolts holding the rudder blades to the castings from the outside to the in-boardside, (so not to be injuried when falling off the boat .. cut the extra bolt off) So the nuts are always on the "in-boardside" on my boat ... easy!
It may not be only about wear & tear, or time. I trailered w/ "rudders on" w/ my H-18, and w/"rudders off" w/ my P-19. You can tie the Hobie rudders "UP" to the rear crossbar, the Prindle has a line that holds the rudderblade up, if it breaks/slips you lose the blade by dragging on the ground.
.... then two things happened ... I started to add up the $$$$s' hanging off the back of my boat ... and I watched as a NJ STATE Trooper ticketed a guy who had his scull/rowwing shell on top off his VW Jetta for violating the "overhang" laws in the Motor Vechicle Code ( it did look a little funny). So with your rudders on are you legal??? remember it is measured from the trailers lights I believe ...
Now if someone runs into the back of your trailer and you are "in-violation" what do you think his Insurance Co is going to try and do ???
If you are going to trailer with "rudders On" get some RED rudder covers ... if you are going to take them off, get rudder covers as there is more damage done in the box being beat while driving then on the boat.
Don't forget the mast ...
Check out Murrays, OK.
Sail Flat, Sail Fast
Harry Murphey
H18mag/#9458, Fleet54, Div11
P19mx w/spin /#86, CRAC
Re: Trailer - Rudders On or Off? [Re: HMurphey] #135212
03/08/08 04:05 PM
03/08/08 04:05 PM
With our Hobie 18, like you said, we tied the tiller crossbar down securely to the rear beam, and that held the rudders in the up position. With our Nacra 6.0, we had a skinny piece of line with a loop in the end of it for each rudder. Put the loop over the tip of the rudder blade and tied it up somehow to the rear beam so the rudder could not fall down.
I don't know the rules about overhangs. Just that you cannot obscure your trailer lights. And I know if the mast extends beyond a certain length, you are supposed to tie a red flag to the end of it.
Re: Trailer - Rudders On or Off? [Re: HMurphey] #135213
03/08/08 04:25 PM
03/08/08 04:25 PM
Commerce, MI
tigerboy1 Offline
tigerboy1  Offline
Commerce, MI
HMurphey...
I added some red pinstripe tape to the port rudder arm and port side of the tiller crossbar. Takes the guesswork out of reinstalling your rudders correctly after removing them for transport.
Mary...
Most states have a 6 foot overhang law measured from the rear support of the trailer (rear hull cradles/rollers/etc.) to the end of rudders/mast/hulls (whichever protrudes the most). Anything beyond that requires a red clearance flag. Some states even require a red clearance light to be attached for night travel. Check your state trailering regs and make sure you're legal.
Re: Trailer - Rudders On or Off? [Re: tigerboy1] #135214
03/08/08 05:12 PM
03/08/08 05:12 PM
Make sure we're legal???
It's way too late for us to make sure we're legal. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Trailer - Rudders On or Off? [Re: Mary] #135215
03/09/08 06:05 AM
03/09/08 06:05 AM
Commerce, MI
tigerboy1 Offline
tigerboy1  Offline
Commerce, MI
Mary...
I know what you mean <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I've had a couple of run ins with law enforcement while pulling a boat. When I was coming back from the 1996 H17 Continentals (La Salle, MI) we detoured to Milwaukee, WI to visit family. I was pulling a triple stack of 17's. As soon as I crossed the IL-WI border I was followed by a WI state trooper. He pulled me over, pulled out a tape measure <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> and checked the width of the boat on the bottom rack (I was carrying the wings in the hull sockets). He measured from the elbow of one wing to the other. I was 1 inch OVER the WI width limit <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> I negotiated with him, removed the wings, tied them to the top rack and avoided a ticket.
The second time was on the same trip and it was my fault. I didn't have time to renew my trailer registration before hitting the road. I was pulled over TWICE <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> by the California Highway Patrol within 100 miles of home...after driving 5000 miles! They didn't hesitate to write me up. Those guys have keen eyes...better than the WI state troopers <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Trailer - Rudders On or Off? [Re: tigerboy1] #135216
03/09/08 07:06 AM
03/09/08 07:06 AM
We have several trailer registrations, and we renew them every year, but somehow we never seem to manage to get all the stickers on the plates and we have no idea what registration goes with what trailer. So we make copies of all the registrations and put all of them in all of our vehicles, so no matter what trailer we are pulling with no matter what vehicle, we always have a trailer registration that will match up with something. We HOPE. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Trailer - Rudders On or Off? [Re: Mary] #135217
03/09/08 10:56 AM
03/09/08 10:56 AM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
I usually leave the rudders on for short distances. The other day the distance was so short (200 m) that I didn't even bother attaching them to avoid side to side swinging. The parking entrance was not much wider than the cat, delimited by some soft bushes, no problem if they touched the hulls. But ovbiously (after it happened of course) a little branch made the rudders swing to one side and as the cross bar moved to the side it entered more into the bushes and broke. Even if I was driving slow and looking back all the time, I didn't realize what was happening until I heard the noise.
I will still leave the rudders on for short distances, but certainly attached..
Re: Trailer - Rudders On or Off? [Re: Andinista] #135218
03/09/08 08:47 PM
03/09/08 08:47 PM
Williamston, sc
h18catsailor Offline
Williamston, sc
I think for some boats it is just a personal preference. I never had them offmy first hobie 18. The one I have now we always remove them. I have not seen any difference in wear.
Some of the higher end carbon may be different.
David Strickland
Hobie 18
HEAVY air crew on a J22
Re: Trailer - Rudders On or Off? [Re: h18catsailor] #135219
03/10/08 12:19 AM
03/10/08 12:19 AM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
I suspect that trailering really really heavy Hobie rudders ON results in droopy Trailex trailers: These are well-used aluminum trailers that are humped in the middle, the kind that used to be seen...inexplicably often....at "Rick's Place".
Dacarls:
Re: Trailer - Rudders On or Off? [Re: dacarls] #135220
03/10/08 02:49 AM
03/10/08 02:49 AM
You're kidding right? It is obvious to me that when traveling at high speeds, the rudders, because of their aerodynamic shape, actually provide lift to both boat and trailer, thereby effectively lightening the load. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
In fact, I fear that if we had hydrofoils of any kind attached to the boat when trailering, the whole rig would start to fly. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: Trailer - Rudders On or Off? [Re: Mary] #135221
03/10/08 08:33 AM
03/10/08 08:33 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
The 5.2 has no effective way of keeping the rudders in the up position(at least not with the bungeesystem), so off they go! Its safer for the boards anyway
Page 2 of 3 1 2 3
0 registered members (), 10,827 guests, and 639 spiders.
Most Online11,466
3 seconds ago
