Paint Question #135316
03/08/08 07:19 AM
03/08/08 07:19 AM
SailorKJ Offline OP
SailorKJ  Offline OP
Just purchased a 83 H16. Looks like the former owner painted White spray paint over a Red Hull. Not bad overall but starting to wear thru on bottom of hulls. What type of paint is recommended for a fix?? I plan on repainting the bottoms back red.
KJ
Re: Paint Question [Re: SailorKJ] #135317
03/08/08 05:50 PM
03/08/08 05:50 PM
West Virginia
Soapysails Offline
Soapysails  Offline
West Virginia
I have had to repaint a number of boats, paint just can't compete with jel-coat. Having said that, you can find help at any Good Automotive paint store. Let them know what you are planning to paint..(fiberglass) they will be able to help with pre-primers, base primer, and a paint made for glass (these paints tend to flex somewhat) Most of the boats I have painted held up well and maintained a wet look..with any luck, you may get a responce on this forum from others with more knowlege and expertise .. Best of luck and fear not...
Re: Paint Question [Re: Soapysails] #135318
03/09/08 04:43 PM
03/09/08 04:43 PM
Eastern Massachusetts
swanbike57 Offline
swanbike57  Offline
I have an old Hobie that was originally red and the previous owners had painted it blue. I patched and faired the hulls out with West system epoxy and fillers, then painted with Petit Easy Poxy. (It's not really an epoxy, it's a high grade polyurethane.) I used their primer first and then two coats of Bikini Blue. I used a foam roller (do a small area, maybe 2' x 3') followed by a wet brush to knock down the bubbles. It came out really well.
0 registered members (), 2,362 guests, and 286 spiders.
