clear coat suggestions? #135615
03/10/08 08:17 AM
03/10/08 08:17 AM
Columbia South Carolina, USA
dave mosley Offline OP
now that I have sanded the paint off of my carbon beams and applied a coat of West, what do I apply for a clear coat UV protectant? There are plenty of wood protectants, but I cant seem to find a clear epoxy covering/protectant. What you got for me?
Re: clear coat suggestions? [Re: dave mosley] #135616
03/10/08 09:35 AM
03/10/08 09:35 AM
not epoxy - it turns yellow with UV exposure.
I've used their tinted 2 part coatings before and they work really well. I would imagine their clear is pretty good too. It's pretty easy to find to - West Marine might carry it.
System Three Linear Polyurethane
PS - do NOT paint clear in direct sunlight.
Re: clear coat suggestions? [Re: Jake] #135617
03/10/08 11:24 AM
03/10/08 11:24 AM
portsmouth, va
U
usa263 Offline
usa263  Offline
U
portsmouth, va
Use the Awlgrip product Awl-Brite. This stuff is the ticket.
Re: clear coat suggestions? [Re: Jake] #135618
03/10/08 11:35 AM
03/10/08 11:35 AM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
If your beam is really fair use Awlgrip clear modified-acrylic urethane. The problem with carbon beams and masts is pin air which leaves open carbon. If your beam is raw and rough spray (or brush) with Awlgrip 545 primer to seal up. Then fair, and spray.
Hope that helps!
Re: clear coat suggestions? [Re: dave mosley] #135619
03/10/08 12:26 PM
03/10/08 12:26 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I just clear-coated a new carbon spin pole yesterday. I used a product I found called Famowood Dura-Tuff
The product description states it works well on epoxy surfaced needng UV & abrasion protection.
Went on really nicely and made a beautiful glossy finish. I could touch the surface within 90 min. If it holds up well, I will re-finish my carbon tiller connector, which is now showing loads of flaking/peeling of the original Awlgrip (applied by Marstrom).
Mike Dobbs
Tornado CAN 99 "Full Tilt"
0 registered members (), 4,060 guests, and 544 spiders.
