F18 Spin Sheets #136155
03/13/08 09:25 AM
03/13/08 09:25 AM
southern Ontario
Twister Offline OP
Twister  Offline OP
southern Ontario
Looking to replace my very old original spin sheets.
Any suggestions on length, diameter and material would be great.
They are for an F18 (Mystere) with mid-pole snuffer and a second set of forward turing blocks on front beam.
Ryan
Ryan
Dart 18 #4860
Re: F18 Spin Sheets [Re: Twister] #136156
03/13/08 12:24 PM
03/13/08 12:24 PM
Measure the length you have now. Diameter shouldn't be less than 5/16 IMO and you can go with $$$$ like endurabraid, warpspeed, swiftcord or $$$ like salsa/Apex or $ like bzzz, trophy braid. Ultralight would work also, though I like the idea of single braids for the spin sheets. Bzzz is good stuff though not as durable as the others and probably absorbs more water (trophy absorbs a lot). I have personally used trophy, bzzz, and salsa. Salsa and bzzz seems equivalent to me really though the salsa is probably better.
If you aren't highly competitive then go with the bzzz. 0.67c a foot, don't see it in the online catsailor store though.
Re: F18 Spin Sheets [Re: PTP] #136157
03/13/08 12:50 PM
03/13/08 12:50 PM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
Anyone know the length needed to run the sheet in the "/\/\" form? My current one isn't long enough and holding it in good wind can be rigorous.
Re: F18 Spin Sheets [Re: BLR_0719] #136158
03/13/08 12:52 PM
03/13/08 12:52 PM
mikekrantz Offline
mikekrantz  Offline
I personally like 7mm or 8mm Robline Racing Sheet
http://www.layline.com/product/2598/707
It has great hand, holds very little water. We put eye splices in the end, and use an 18" 1/8" spectra luggage tag to attach the the spin clew.
Re: F18 Spin Sheets [Re: BLR_0719] #136159
03/13/08 12:52 PM
03/13/08 12:52 PM
southern Ontario
Twister Offline OP
Twister  Offline OP
southern Ontario
I think its 55ft, but my old sheets are in my trailer box, under a few feet of snow...
Ryan
Dart 18 #4860
Re: F18 Spin Sheets [Re: Twister] #136160
03/13/08 05:01 PM
03/13/08 05:01 PM
stuartoffer Offline
stuartoffer  Offline
IMHO the type of sheet and thickness of the sheet will depend on the type of sailing you will be doing eg if its long distance racing personally I use a slightly fatter sheet than if im racing windward leeward.
Personally I prefer maffioli swiftcord but the Alpha line is very good too....but generally I agree with mikekrantz 7 or 8 mm personally 8mm
Re: F18 Spin Sheets [Re: stuartoffer] #136161
03/13/08 05:11 PM
03/13/08 05:11 PM
Wuss. 6mm FSE Robline for me - I also like the Swiftcord.
Re: F18 Spin Sheets [Re: John Williams] #136162
03/13/08 06:32 PM
03/13/08 06:32 PM
JACKFLASH Offline
JACKFLASH  Offline
My crew says swiftcord is the way to go. That is what he has and I don't touch his line per his request.
Collin Casey
Re: F18 Spin Sheets [Re: John Williams] #136163
03/13/08 08:13 PM
03/13/08 08:13 PM
6mm!? Jeebus.
Re: F18 Spin Sheets [Re: Jake] #136164
03/13/08 08:20 PM
03/13/08 08:20 PM
He must wear double gloves! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Re: F18 Spin Sheets [Re: Jake] #136165
03/13/08 08:24 PM
03/13/08 08:24 PM
if you gonna go 6, why not lose more weight and just go 7/64 amsteel.
Re: F18 Spin Sheets [Re: Timbo] #136166
03/13/08 08:26 PM
03/13/08 08:26 PM
Nope - the Swiftcord and similar lines have a nice feel and the 6mm runs really nice through the 57mm Harken Autos. I also double-block the 'chute and make sure the ratchets are set right; loads are really not bad.
Jake - that's the same sheet you had in your hands for Tradewinds the year we did it on my boat. Of course, we finished better the year we were on your boat, so draw your own conclusions. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: F18 Spin Sheets [Re: PTP] #136167
03/13/08 08:30 PM
03/13/08 08:30 PM
Mark Smith was famous among crews for having the same downhaul line on his Nacra 6.0 for years. In the bar, we called it "the Saw." Had a life of its own. He tried to put it onto his first Nacra 20 - I bought him a new line. He complained because the new line was so limp and he could "see it stretch." I'd bet Amsteel would feel the same as the Saw only slipperier! Bad combo...
Re: F18 Spin Sheets [Re: John Williams] #136168
03/13/08 08:58 PM
03/13/08 08:58 PM
Hmmm...yeah....but I was driving both times (except for that one quasi-pitchpole where you instinctually grabbed the tiller as I went by) so my not noticing the cable-saw spin sheet is not surprising. I'm looking forward to one of those where you're on the back of the boat. I can't tell the story well enough to relay the shear hilarity but I still chuckle of the Captain Kirk double take at our huge leap on split tacks and you screaming "THAT'S RIGHT F*****R!!!!"
Re: F18 Spin Sheets [Re: Timbo] #136169
03/13/08 09:06 PM
03/13/08 09:06 PM
rexdenton Offline
rexdenton  Offline
6 mm!! Ouch! Self-flagellation went out in the middle ages... (What's the basis of the penance? Blow too many snuffs at the leeward mark?
Nacra F18 #856
Re: F18 Spin Sheets [Re: rexdenton] #136170
03/17/08 11:52 AM
03/17/08 11:52 AM
I know for a fact i have 45' on my mystere 5.5 (f-18 spin) but wouldnt mind a few more feet so i could trap with the sheet (just a few feet short).
0 registered members (), 4,163 guests, and 576 spiders.
