Trapeze systems #136642
03/16/08 04:11 AM
03/16/08 04:11 AM
New Zealand
G
GoGecko Offline OP
GoGecko  Offline OP
G
New Zealand
When I have my trapeze lines set up for normal sailing they are too short ( I am too high on the wire ) for when when I am sailing back on the boat behind the rear beam on a reach.
If I have enough rope to be effective from the rear there is way too much rope on the tramp??
I have an adjustable pulley ayatem. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Any solution to this
Go Gecko NZ
Re: Trapeze systems [Re: GoGecko] #136643
03/17/08 09:16 AM
03/17/08 09:16 AM
What boat are you sailing? Are you sure you have it rigged correctly?
Most people can stand on the beam trapped (or close) with an adjustable system.
Re: Trapeze systems [Re: GoGecko] #136644
03/17/08 12:21 PM
03/17/08 12:21 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Old school solution was to use the two-ring loops...one circular ring welded to an elongated loop. Then you can select the shorted one for close hauled work or the longer one for getting aft.
Most teams now use an on-the-wire adjustable setup. It's a simple matter of pulling/easing the line to change the trap height while still hanging off the boat.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
0 registered members (), 4,553 guests, and 295 spiders.
