| The A cat wing sighted. #137279 03/21/08 09:05 AM 03/21/08 09:05 AM |
Joined: Jan 2005 Posts: 6,049 Sebring, Florida. Timbo OP
Posts: 6,049 Sebring, Florida. | Ben Hall was at the Gulfport A Cat/F 16 regatta last weekend and there are now picutures available. If you want to see a very creative way to "reef" a wing sail, check out the photos of Ben on Saturday, when it was blowing a steady 20+ with many gusts into the 30's. Thanks for taking these photos Travis! http://travisedwards.smugmug.com/gallery/4535964_vfZxD#267137936 I was impressed, and thanks for coming Ben. I wonder if we will see wings or soft sails on the DoG cats?
| | | Re: The A cat wing sighted.
[Re: mbounds]
#137282 03/21/08 12:34 PM 03/21/08 12:34 PM |
Posts: 6,049 Sebring, Florida. | I don't know but I'll be the loose trap line and the wrinkles are the result of the same thing, a crash! Just a guess though. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Blade F16 #777
[Re: Karl_Brogger]
#137284 03/21/08 01:17 PM 03/21/08 01:17 PM |
Posts: 6,049 Sebring, Florida. | Now that you mention it, I did see a very small amount of water inside a couple of the lower flap panels, not enough to keep you from righting it. Ben said he was going to put some Goldfish in there! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I was surprised there weren't some small drain holes already on the trailing edges like they use on airplanes to keep moisture from puddling there.
Blade F16 #777
[Re: Rolf_Nilsen]
#137288 03/21/08 05:03 PM 03/21/08 05:03 PM |
Posts: 291 | I am curious what a regular A cat sail weighs versus the wing. I know the wing is built light but how light can you make it?
[Re: Timbo]
#137290 03/21/08 07:15 PM 03/21/08 07:15 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I'm not going to knock it till I've tried it....Ben is doing small cat sailing a great service so lets not criticize too much. MP*MULTIHULLS | | | Re: The A cat wing sighted.
[Re: ncik]
#137294 03/22/08 06:49 AM 03/22/08 06:49 AM |
Posts: 6,049 Sebring, Florida. | The more I look at the wrinkle on the half wing, I think if the full wing were on, the top half would be pushing off to leeward and forcing the bottom half (where the wrinkle is) to move slightly to windward, eliminating the wrinkle.
With the half wing setup, you can see the support wires all attach at the very top (what would be midpoint on the full wing) so in the half wing configuration there is no leverage or wires keeping it from bowing slightly to leeward. This is also why we don't run our shrouds and forestays to the very top of our masts, there would be no support to keep the mast from bowing out other than the diamond wires, (not enough) and not at all on a Prindle or Hobie 16.
I think it either needs a stiffer, box type, spar or maybe a wire mounting point down a bit from the halfway point?
Blade F16 #777
[Re: JACKFLASH]
#137295 03/22/08 07:07 PM 03/22/08 07:07 PM |
Posts: 118 St. Louis, MO | I am curious what a regular A cat sail weighs versus the wing. I know the wing is built light but how light can you make it? 75 kilos(165 lbs) is the class minimum. In Ben's case I believe his wing was @ 12 lbs heavier than a "normal" rig & sail, and he just had the platform made a little lighter. If I recall correctly he weighed in within a kilo either way at Worlds.
JL
N20 # 1041 "Lucille"
A-cat USA 44
[Re: JoeLeonard]
#137296 03/22/08 08:33 PM 03/22/08 08:33 PM |
Posts: 6,049 Sebring, Florida. | Joe, it was great to meet you at Gulfport, sorry you had to leave, I hope you had a safe trip back. I hope we see you next year or sooner. Tim.
Blade F16 #777
[Re: ncik]
#137297 03/23/08 09:23 AM 03/23/08 09:23 AM |
Posts: 1,226 Atlanta | there is a tube running the whole length of the mast which would be the structural element, so the buckling of the fairing probably isn't a problem. yes, there is a structural tube that suppports the wing, the leading edge isnt structural. Good to see the wing can get banged up and still sail. | | | Re: The A cat wing sighted.
[Re: JoeLeonard]
#137298 03/23/08 12:03 PM 03/23/08 12:03 PM |
Posts: 19 | From a Seahorse article on the A-Cat worlds
Hall’s 29ft wing measured in at slightly less than the class maximum of 150ft2, and weighed in heavier than standard at 52lb. However,when Hall weighed everything he took off when fitting the wing, standard rig, plus sail, battens, mainsheet system and so on, he found the comparable figure was some 46lb. Hall’s boat is still at rule minimum and still carries correctors. A standard A-Cat rig has traveller, mainsheet, outhaul, downhaul, rotation, over-rotation and diamond controls. There are only four controls for the slotted wing. Hall’s wing has an upper and a lower element, each with a twist control. The wing has four controls: a 2:1 mainsheet, camber control (that adjusts flap angle from 0 to 35 degrees), twist for the main element and twist for the flap element. The wing sheets in particularly easily around the leeward mark when Hall can trim on with a single pull. | | |
522
guests, and 41
