The A cat wing sighted. #137279
03/21/08 09:05 AM
03/21/08 09:05 AM
Timbo Offline OP
Timbo  Offline OP
Ben Hall was at the Gulfport A Cat/F 16 regatta last weekend and there are now picutures available. If you want to see a very creative way to "reef" a wing sail, check out the photos of Ben on Saturday, when it was blowing a steady 20+ with many gusts into the 30's. Thanks for taking these photos Travis!
http://travisedwards.smugmug.com/gallery/4535964_vfZxD#267137936
I was impressed, and thanks for coming Ben. I wonder if we will see wings or soft sails on the DoG cats?
Re: The A cat wing sighted. [Re: Timbo] #137280
03/21/08 10:35 AM
03/21/08 10:35 AM
srm Offline
srm  Offline
If you look at the leading edge of the reefed wing, it's all wrinkled. I'm wondering if this has something to do with his reefing the sail or if maybe it's the skin material deflecting due to the high wind. In either case, it doesn't look too good. Nice pics though, thanks.
sm
Re: The A cat wing sighted. [Re: srm] #137281
03/21/08 11:48 AM
03/21/08 11:48 AM
It looks more like compression buckling - the wing is flexing to leeward and the wrinkles are mostly on the windward side.
He's also got a trapeze wire loose.
Re: The A cat wing sighted. [Re: mbounds] #137282
03/21/08 12:34 PM
03/21/08 12:34 PM
Timbo Offline OP
Timbo  Offline OP
I don't know but I'll be the loose trap line and the wrinkles are the result of the same thing, a crash! Just a guess though. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Re: The A cat wing sighted. [Re: Timbo] #137283
03/21/08 01:04 PM
03/21/08 01:04 PM
One thing I thought of looking at those pictures, if one of those sections in the sail filled with water while capsized you'd never get it back up.
Re: The A cat wing sighted. [Re: Karl_Brogger] #137284
03/21/08 01:17 PM
03/21/08 01:17 PM
Timbo Offline OP
Timbo  Offline OP
Now that you mention it, I did see a very small amount of water inside a couple of the lower flap panels, not enough to keep you from righting it. Ben said he was going to put some Goldfish in there! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
I was surprised there weren't some small drain holes already on the trailing edges like they use on airplanes to keep moisture from puddling there.
Re: The A cat wing sighted. [Re: Timbo] #137285
03/21/08 01:35 PM
03/21/08 01:35 PM
Is this the picture you are discussing?
http://travisedwards.smugmug.com/gallery/4535964_vfZxD#268308072_sLfk8-X3-LB
Very strange "buckling" on the leading edge and flap, but it dont look at all like it is structural? Who calls Ben and asks him what was happening and how the wing is built in those areas <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: The A cat wing sighted. [Re: Rolf_Nilsen] #137286
03/21/08 04:13 PM
03/21/08 04:13 PM
Also look at his windward shrouds, they have some slack in them. CRAZY! I talked to some of the A cat sailors that weekend and they indeed confirmed this happens.
Re: The A cat wing sighted. [Re: Robi] #137287
03/21/08 04:16 PM
03/21/08 04:16 PM
I suppose the explanation for that is the crew on trapeze is pulling the wing to windward with his weight. We observed the same thing on the Tornado and always took it as a sign to power up <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: The A cat wing sighted. [Re: Rolf_Nilsen] #137288
03/21/08 05:03 PM
03/21/08 05:03 PM
JACKFLASH Offline
JACKFLASH  Offline
I am curious what a regular A cat sail weighs versus the wing. I know the wing is built light but how light can you make it?
Collin Casey
Re: The A cat wing sighted. [Re: Rolf_Nilsen] #137289
03/21/08 05:52 PM
03/21/08 05:52 PM
North Europe, Sweden, Uppsala
Hakan Frojdh Offline
When you have twin forestays and sheet the main hard (in light to medium winds) the mast get enough support from the twin forestays and the main sheet which makes the shrouds to lose tension. This happens even when you are fully powered up.
/hakan
Re: The A cat wing sighted. [Re: Timbo] #137290
03/21/08 07:15 PM
03/21/08 07:15 PM
Mark P Offline
Mark P  Offline
I'm not going to knock it till I've tried it....Ben is doing small cat sailing a great service so lets not criticize too much.
MP*MULTIHULLS
Re: The A cat wing sighted. [Re: Mark P] #137291
03/21/08 07:23 PM
03/21/08 07:23 PM
Would this be considered boomless? <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: The A cat wing sighted. [Re: srm] #137292
03/21/08 08:10 PM
03/21/08 08:10 PM
It doesn't really reef. The top section comes off, kinda like lego blocks.
Re: The A cat wing sighted. [Re: fin.] #137293
03/21/08 08:23 PM
03/21/08 08:23 PM
ncik Offline
ncik  Offline
The leading edge of carbon fairing is definitely buckling. It looks like there is a tube running the whole length of the mast which would be the structural element, so the buckling of the fairing probably isn't a problem.
You can see how much it is deflecting here...
Wing mast deflection
Re: The A cat wing sighted. [Re: ncik] #137294
03/22/08 06:49 AM
03/22/08 06:49 AM
Timbo Offline OP
Timbo  Offline OP
The more I look at the wrinkle on the half wing, I think if the full wing were on, the top half would be pushing off to leeward and forcing the bottom half (where the wrinkle is) to move slightly to windward, eliminating the wrinkle.
With the half wing setup, you can see the support wires all attach at the very top (what would be midpoint on the full wing) so in the half wing configuration there is no leverage or wires keeping it from bowing slightly to leeward. This is also why we don't run our shrouds and forestays to the very top of our masts, there would be no support to keep the mast from bowing out other than the diamond wires, (not enough) and not at all on a Prindle or Hobie 16.
I think it either needs a stiffer, box type, spar or maybe a wire mounting point down a bit from the halfway point?
Re: The A cat wing sighted. [Re: JACKFLASH] #137295
03/22/08 07:07 PM
03/22/08 07:07 PM
St. Louis, MO
JoeLeonard Offline
JoeLeonard  Offline
St. Louis, MO
75 kilos(165 lbs) is the class minimum. In Ben's case I believe his wing was @ 12 lbs heavier than a "normal" rig & sail, and he just had the platform made a little lighter. If I recall correctly he weighed in within a kilo either way at Worlds.
JL N20 # 1041 "Lucille" A-cat USA 44
Re: The A cat wing sighted. [Re: JoeLeonard] #137296
03/22/08 08:33 PM
03/22/08 08:33 PM
Timbo Offline OP
Timbo  Offline OP
Joe, it was great to meet you at Gulfport, sorry you had to leave, I hope you had a safe trip back. I hope we see you next year or sooner. Tim.
Re: The A cat wing sighted. [Re: ncik] #137297
03/23/08 09:23 AM
03/23/08 09:23 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
yes, there is a structural tube that suppports the wing, the leading edge isnt structural.
Good to see the wing can get banged up and still sail.
Re: The A cat wing sighted. [Re: JoeLeonard] #137298
03/23/08 12:03 PM
03/23/08 12:03 PM
U
USA197 Offline
USA197  Offline
U
From a Seahorse article on the A-Cat worlds
Hall’s 29ft wing measured in at slightly less than the class maximum of 150ft2, and weighed in heavier than standard at 52lb. However,when Hall weighed everything he took off when fitting the wing, standard rig, plus sail, battens, mainsheet system and so on, he found the comparable figure was some 46lb. Hall’s boat is still at rule minimum and still carries correctors.
A standard A-Cat rig has traveller, mainsheet, outhaul, downhaul, rotation, over-rotation and diamond controls. There are only four controls for the slotted wing. Hall’s wing has an upper and a lower element, each with a twist control. The wing has four controls: a 2:1 mainsheet, camber control (that adjusts flap angle from 0 to 35 degrees), twist for the main element and twist for the flap element. The wing sheets in particularly easily around the leeward
mark when Hall can trim on with a single pull.
1 registered members (Damon Linkous), 2,526 guests, and 167 spiders.
