| Re: Rudder composition
[Re: Sunvista]
#137356 03/22/08 06:51 PM 03/22/08 06:51 PM |
Joined: Jul 2004 Posts: 125 Clinton, Mississippi rattlenhum
Posts: 125 Clinton, Mississippi | Set one sounds like either fiberglass racing rudders (gelcoated) or EPOs (epoxy). Either of these are of foam sandwich construction and far superior to the others. Set two sounds like standard plastic (sometimes referred to as lexan). Set three could be ABS...Hobie made ABS rudders for a while.
Jerome Vaughan Hobie 16 Clinton, Mississippi
[Re: rattlenhum]
#137357 03/23/08 08:21 AM 03/23/08 08:21 AM |
Joined: Sep 2004 Posts: 99 Virginia Beach Sunvista OP
Posts: 99 Virginia Beach | Set one sounds like either fiberglass racing rudders (gelcoated) or EPOs (epoxy). Either of these are of foam sandwich construction and far superior to the others. Set two sounds like standard plastic (sometimes referred to as lexan). Set three could be ABS...Hobie made ABS rudders for a while. Well, the first set is attached to the later model adjustable tiller arms with the sliding set screw so I guess that's the ones I'll use. What is ABS? | | | Re: Rudder composition
[Re: Sunvista]
#137358 03/23/08 12:19 PM 03/23/08 12:19 PM |
Posts: 1,884 Detroit, MI | ABS - Acrylonitrile Butadiene Styrene
It's a common thermoplastic used to make light, rigid, molded products such as piping, musical instruments (most notably recorders and plastic clarinets), golf club heads (used for its good shock absorbance), automotive body parts, wheel covers, enclosures, protective head gear, vballs [reusable paintballs], and toys including LEGO bricks.
It was the original Hobie rudder, unfortunately, they tend to get brittle over time and break off right below the rudder casting. | | | Re: Rudder composition
[Re: Sunvista]
#137362 05/31/08 06:59 AM 05/31/08 06:59 AM |
Posts: 99 Virginia Beach | Well we were trapped out yesterday in a 12-15 knot wind and my starboard rudder snapped off. This was set number one that was hard and light. There doesn't appear to be any structural component (fiber or laminations) in it so I'm assuming it was just some cheapo plastic like ABS. I'm going to replace it with one from set two, the hard, heavy rudder set. Does anyone have an opinion on whether I should replace rudders in pairs? Other than, if my starboard rudder sheared then the port rudder can't be far behind. Also, after I cleaned the dirt off set number two I found an "M" embossed between the two holes and, above that, the letters "XX 1" and "AH" engraved on them. Anyone have a clue what that means?
2,009
guests, and 428
