| Re: Where to get a custom carbon mast?
[Re: Todd Berget]
#137613 03/25/08 07:58 AM 03/25/08 07:58 AM |
Posts: 6,049 Sebring, Florida. | If you could buy a "better" aerodynamic shaped alum. wing type mast, would the better aerodynamics on the leading edge of the sail offset the heavier weight?
Talk amongst yourselves.... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Blade F16 #777
[Re: Frozen]
#137614 03/25/08 08:29 AM 03/25/08 08:29 AM | Anonymous
| Anonymous
Unregistered | And a ginpole makes it even easier. I used to use one on my TheMightyHobie18.( An E-Z mast stepper ). Yes they do make stepping easier but they take about 15 minutes or more to get on your boat properly and my rigging time is already over an hour. I have so many lines, wires and "stuff" goin on at the front of my cat with my spin, anchor lines, bridal etc… getting in there to fiddle with the mounting of the ginpole is a pain and a ½. Another problem with that is my trailer is set up to put my boat on sterns facing my car. This allows me to have the mast at an angle for easier stepping and i would have to move the "trailer beams" around since the rear ones have cradles and not rollers. I have found with a “helper” line tied to my halyard, If I find someone on the beach to give me a little help the line… it is much more manageable. I can handle it without to much a risk of a hernia. I was just curious about the carbon mast. I can’t see spending 2x on the mast, compared to what I paid for the entire catamaran… but I can always dream. | | | Re: Where to get a custom carbon mast?
[Re: Todd Berget]
#137615 03/25/08 08:46 AM 03/25/08 08:46 AM |
Posts: 12,310 South Carolina | The masts are made by Southern Spars (who acquired Omohundro in 2001). They originally were made at Omohundros facility that I think was in California or nevada (they also made Farr 40 masts). Southern then sent the tooling to New Zealand and just last year sent it to South Africa. With each move, the cost has gone up.
I had written a letter to the Class Assoc. (I think it went to Mark Biggers) expressing my concern and recommending Forte as a more economical alternative. I think Mark sent it on to Performance. I definitely agree that the cost of the new boat needs to come down in order for the class to survive, but I also don't want to see the class splintered by going to a stick that does not perform. I was however very surprised at the price of a new F17 with the aluminum mast. If the 20 saw a similar reduction, it certainly couldn't hurt the class.
Perhaps all of those interested should express our opinions to Performance. I know it is not a member run class, but it can't hurt that the manufacturer knows where the class stands.
T I'm not convinced there would be a lessening in the performance of the boat - just because it's carbon doesn't make it fast and I'm certain that given enough time and development, an aluminum stick could be made as fast or faster than the carbon stick. However, there will be some performance difference and that is not good for the class - but it's better than death. If you went to a different carbon mast supplier, I think you are still going to see some differences as the production methods, tooling, and/or materials will experience some differences. Either way, you're going to have to deal with some sort of change.
Jake Kohl | | | Re: Where to get a custom carbon mast?
[Re: Todd Berget]
#137619 03/25/08 09:57 AM 03/25/08 09:57 AM |
Posts: 2,490 On the Water | Capt. Kirk quoted the new price at $19,600 without trailer two weeks ago at Mid Winters.
Philip USA #1006 | | | Re: Where to get a custom carbon mast?
#137622 03/25/08 10:24 AM 03/25/08 10:24 AM |
Posts: 9,582 North-West Europe | just because it's carbon doesn't make it fast and I'm certain that given enough time and development, an aluminum stick could be made as fast or faster than the carbon stick.
Really funny to see my talking points being expressed by my greatest opponents. I guess I was just too much ahead of my time when I was rediculed for expressing such views. Wouter
#137623 03/25/08 11:39 AM 03/25/08 11:39 AM |
Posts: 833 St. Louis, MO, | The N20 mast is pretty heavy for a carbon stick and it's not terribly stiff - BUT one could argue that it is pretty darn durable. I've only seen a few break and most of those reasons were pretty obviously not the mast's fault (flipping in the surf).
Well I can't say that they are that durable. I broke one at Nationals in Tybee one year. I was surfing down a wave and slammed into the wave in front. My crew blew the chute but the stress of the stop was too much and the mast snapped. I wasn't too pleased about it since I had chartered the boat. Anyway I picked up and stepped that F16 blade mast and was amazed at how light that aluminum mast was. I could almost pick it up and step it like a laser. I don't want to go back to a 60lbs mast. That wouldn't be acceptable in my book. Stepping my P19, H20, and N6.0 masts were a beast. Mike Hill | | | Re: Where to get a custom carbon mast?
[Re: Mike Hill]
#137624 03/25/08 11:44 AM 03/25/08 11:44 AM |
Posts: 1,226 Atlanta | The i20 mast shape could be improved as well, a pear shape is fatter than a true wing shape, so it you make a mast in a wing shape its going to have less surface area and less material, (alum or carbon) so it will be lighter in that regard. Its also going to be stiffer by nature, more material in the fore/aft axis. If the i20 class does go to Forte, they should demand a true wing mast shape, dont go with the T section he's using now.
I'm a fan of the Forte stuff, its durable and less expensive. A $1000 wing mast secion would be awesome, think about a second mast for you Acat to go out in a blow, or to use when its windy, make it stffer. Anyway a Forte wing mast would be a good thing.
Bill | | | Re: Where to get a custom carbon mast?
[Re: Mike Hill]
#137625 03/25/08 11:46 AM 03/25/08 11:46 AM |
Posts: 12,310 South Carolina | The N20 mast is pretty heavy for a carbon stick and it's not terribly stiff - BUT one could argue that it is pretty darn durable. I've only seen a few break and most of those reasons were pretty obviously not the mast's fault (flipping in the surf).
Well I can't say that they are that durable. I broke one at Nationals in Tybee one year. I was surfing down a wave and slammed into the wave in front. My crew blew the chute but the stress of the stop was too much and the mast snapped. I wasn't too pleased about it since I had chartered the boat. Anyway I picked up and stepped that F16 blade mast and was amazed at how light that aluminum mast was. I could almost pick it up and step it like a laser. I don't want to go back to a 60lbs mast. That wouldn't be acceptable in my book. Stepping my P19, H20, and N6.0 masts were a beast. Mike Hill Yeah, your's sucked but it was the only boat-standing breakage I've ever seen on an I20 stick though.
#137626 03/25/08 11:52 AM 03/25/08 11:52 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | If the i20 class does go to Forte, they should demand a true wing mast shape, dont go with the T section he's using now.
Well since the question became (and sorry about the hijack) "how to keep costs down so the class survives" then we need to examine how to keep the class alive as it relates to the mast. I don't think that changing the mast drastically would promote class health. If huge performance gains are made by changing the stick, you've obsoleted every used boat out there until it goes to the new stick. | | | Re: Where to get a custom carbon mast?
[Re: ThunderMuffin]
#137628 03/25/08 12:37 PM 03/25/08 12:37 PM |
Posts: 1,226 Atlanta | I don't think that changing the mast drastically would promote class health. If huge performance gains are made by changing the stick, you've obsoleted every used boat out there until it goes to the new stick. My point was that if you are going to change, make it a wing mast. | | | Re: Where to get a custom carbon mast?
[Re: bvining]
#137630 03/25/08 04:05 PM 03/25/08 04:05 PM |
Posts: 1,383 Kingston SE South Australia | G'day Bill I understand the alloy being stronger in a wingmast without much mast rotation but doesnt it bend excessively if you've got a fair bit of rotation and main on hard? I had heard that the main benefit of carbon was its quick snap back into position after a gust etc would the new alloys match that? regards
[Re: Brian_Mc]
#137631 03/25/08 09:47 PM 03/25/08 09:47 PM |
Joined: Jun 2001 Posts: 305 toronto, canada basket.case
Posts: 305 toronto, canada | I think I can safely say I'd recommend this shop too. I know Mark, and in addition to being a catsailor, he's devoted to his work, and craftsmanship. His crew is a good bunch too. mark is a good [censored]. spent a long time working with him. | | |
21,303
guests, and 1,018
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,788 Yesterday at 09:11 PM | | |
