Nacra Hull repair #137635
03/24/08 02:06 PM
03/24/08 02:06 PM
Minneapolis
Mpls_Nacra Offline OP
Minneapolis
I have an 84 Nacra 8.5. One of the hulls leaks a fair amount. the tops of both hulls are soft. I think i know how to fix the hull tops. but i am looking for a good way to get inside the hulls to perform some repair. Is there any good documentation out there on the Nacra? Thanks
Dave Foster
Minneapolis
Nacra F16
Re: Nacra Hull repair [Re: Mpls_Nacra] #137636
03/24/08 04:33 PM
03/24/08 04:33 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Take the decks of with a thin putty knife/blade.
Re: Nacra Hull repair [Re: TEAMVMG] #137637
03/24/08 04:47 PM
03/24/08 04:47 PM
Minneapolis
Minneapolis
do i just scrape them off or apply heat?
Re: Nacra Hull repair [Re: Mpls_Nacra] #137638
03/24/08 05:07 PM
03/24/08 05:07 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I think they come off as solid pieces.
Re: Nacra Hull repair [Re: warbird] #137639
03/24/08 05:10 PM
03/24/08 05:10 PM
Minneapolis
Minneapolis
Are there access holes underneath them?
Dave Foster
Minneapolis
Nacra F16
Re: Nacra Hull repair [Re: Mpls_Nacra] #137640
03/24/08 05:26 PM
03/24/08 05:26 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I am not sure if this cat is new enough but yes I think they cover large apertures.
I will go through my files to see what I can find.
right, I have these two photos.
I think the knife may be what was used and the blood tax for getting the job done. : )
Re: Nacra Hull repair [Re: Mpls_Nacra] #137641
03/24/08 05:29 PM
03/24/08 05:29 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Re: Nacra Hull repair [Re: warbird] #137642
03/24/08 05:40 PM
03/24/08 05:40 PM
Minneapolis
Minneapolis
That is awesome information. if you could find out the year they started those it would help. but I feel pretty good about just going forward. Do you know if i wreck one of the decks, can they be replaced?
Dave Foster
Minneapolis
Nacra F16
Re: Nacra Hull repair [Re: Mpls_Nacra] #137643
03/24/08 05:43 PM
03/24/08 05:43 PM
JACKFLASH Offline
JACKFLASH  Offline
Performance sells them but it is my understanding from another thread here that they have misplaced the molds (not sure if it is the same Nacra or not). I would suggest makeing a mold off of one of yours before you attempt to take it off.
Collin Casey
Re: Nacra Hull repair [Re: JACKFLASH] #137644
03/24/08 05:59 PM
03/24/08 05:59 PM
Minneapolis
Minneapolis
What are the decks made of? assuming i neeed to replace one. FGlass?
Dave Foster
Minneapolis
Nacra F16
Re: Nacra Hull repair [Re: Mpls_Nacra] #137645
03/24/08 06:22 PM
03/24/08 06:22 PM
Minneapolis
Minneapolis
Thinking about it, my boat may be to old for these access holes. Can i get the deck plates and then cut the holes? and then back fill? the cut out area?
Dave Foster
Minneapolis
Nacra F16
Re: Nacra Hull repair [Re: Mpls_Nacra] #137646
03/24/08 06:49 PM
03/24/08 06:49 PM
Dave-
I don't know if you are squeamish like I am about doing fibreglass work but Aquarius is supposed to be the best in the area for repairs. Tom Haberman is who I've talked to there. But I'm squeamish.
Also if you're looking for people to sail with check out www.Fleet444.com We're mostly a Hobie Fleet, but we're open to other boats for any of the fun events just not at the regatta.
Re: Nacra Hull repair [Re: Mpls_Nacra] #137647
03/24/08 08:20 PM
03/24/08 08:20 PM
If your boat has deck patches like what was removed in these pictures, then you have these holes. There's no other reason to put on a deck patch unless there is a hole under it.
Re: Nacra Hull repair [Re: Mpls_Nacra] #137648
03/25/08 04:54 AM
03/25/08 04:54 AM
Clear Lake,Texas
TreyG Offline
TreyG  Offline
Clear Lake,Texas
The pictures with the decks removed were from a Nacra 5.2. I have a 83 Nacra 5.2 that I removed the decks on for repairs. I used a chisel to get under the lip of the deck and then used a large knife and gasket scraper to get to the middle of the deck. If you have remove the rear deck, there will be a lot of resin around the daggerwell to break loose if your boat has them. Make sure Performance has decks for your boat. I still haven't heard if they found the molds for my 5.2 decks. I have found a used deck to install on mine though.
Trey
Nacra 5.2 "Silver Bullet" #333
TCDYC
Re: Nacra Hull repair [Re: Mpls_Nacra] #137649
03/25/08 07:46 AM
03/25/08 07:46 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
You have to beat the scraper/knife with a hammer to break the adhesive.
I'm pretty sure that the decks are made from a solid polyester/fiberglass lay-up with gelcoat finish.
If you muller the deck, you can take a mold off of the other hull before you get stuck into it
paul
Re: Nacra Hull repair [Re: TEAMVMG] #137650
03/25/08 02:48 PM
03/25/08 02:48 PM
Minneapolis
Minneapolis
FYI, i just ordered new decks from Cat House. so they are still avaiable.
Dave Foster
Minneapolis
Nacra F16
Re: Nacra Hull repair [Re: Mpls_Nacra] #137651
03/27/08 08:27 AM
03/27/08 08:27 AM
Minneapolis
Minneapolis
Changing gears a bit. any good tricks to getting a Tramp tight?
Dave Foster
Minneapolis
Nacra F16
Re: Nacra Hull repair [Re: Mpls_Nacra] #137652
03/27/08 08:28 AM
03/27/08 08:28 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Dang thats a loaded question! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Clayton
Re: Nacra Hull repair [Re: Clayton] #137653
03/27/08 08:38 AM
03/27/08 08:38 AM
I am not sure of the tramp configuration on your boat but the Uptight Trampoline Tool works fantastic.
Re: Nacra Hull repair [Re: ] #137654
03/27/08 10:03 AM
03/27/08 10:03 AM
Minneapolis
Minneapolis
I have seen that tool, what is the technique?
Dave Foster
Minneapolis
Nacra F16
0 registered members (), 694 guests, and 148 spiders.
Posts267,056
