| Re: Help needed
[Re: bvining]
#137724 03/25/08 01:58 PM 03/25/08 01:58 PM |
Posts: 160 | You can get an idea about various board meassurements at www.schrs.com, using CB and VLB. CB/VLB gives you the width in the case of rectangular boards. You have no info about how much of the board disappears in the hull however. | | | Re: Help needed
[Re: bvining]
#137726 03/25/08 03:12 PM 03/25/08 03:12 PM |
Posts: 12,310 South Carolina | Bill,
I'll measure I20 and '04 Nacra F18 boards tonight.
Jake Kohl | | | Re: Help needed
[Re: bvining]
#137727 03/25/08 04:57 PM 03/25/08 04:57 PM |
Posts: 6,049 Sebring, Florida. | To me it looked like the Inter 20 boards were skinny-er than the Jav 2 boards. ie. shorter front to back. The Tiger boards might be closer to the Jav. boards.
Blade F16 #777
| | | Re: Help needed
[Re: bvining]
#137728 03/25/08 06:13 PM 03/25/08 06:13 PM |
Posts: 12,310 South Carolina | Claus That doesnt help either, I need to know if an F18 or i20 board will fit in the HT trunk. So, the width and thickness of various boats boards are what I'm after.
Bill '04 - '07 Nacra F18 (not infusion) are 10" x 1" (~250mm X 25mm) I20 is roughly 8 1/8" X 7/8" (206mm X 21mm)...I measured this one by approximating the daggerboard well....they're buried in the trailer.
[Re: bvining]
#137730 03/26/08 08:13 AM 03/26/08 08:13 AM |
Posts: 12,310 South Carolina | Thanks Jake, thats exactly what I needed.
The HT boards are 250mm x 23mm, so the i20 boards will work withe a bit of filler in the top and bottom of the case.
Bill Good! However, I feel obligated now to measure an actual board instead of the well before you make an investment...I'll dig out a board tonight to make sure.
[Re: bvining]
#137731 03/26/08 08:23 AM 03/26/08 08:23 AM |
Posts: 6,049 Sebring, Florida. | Are the original Jav 2 board no longer produced? Seems you could get some from the factory. They do weigh quite a bit less than I-20 boards if that's an issue.
Blade F16 #777
| | | Re: Help needed
[Re: Timbo]
#137732 03/26/08 10:07 AM 03/26/08 10:07 AM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | They are no longer available.
E-Scow 24' ULDB
| | | Re: Help needed
#137733 03/26/08 10:08 AM 03/26/08 10:08 AM |
Posts: 531 Lake Murray SC | Thanks Jake, thats exactly what I needed.
Bill Good! However, I feel obligated now to measure an actual board instead of the well before you make an investment...I'll dig out a board tonight to make sure. as Bill is helping me find boards, thanks for looking into my investment. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
E-Scow 24' ULDB
14,951
guests, and 734
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online15,709 11 minutes ago | | |
