Help needed #137721
03/25/08 11:35 AM
03/25/08 11:35 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
I need a suggestion on a commercially available, daggerboard that is less than 250mm x 13mm
I think the i20 boards have a shorter cord but dont know on the thickeness.
Can someone measure one up? How about some f18 measurements, an infusion, or Hobie Tiger boards?
Thanks for your help.
Bill Vining.
Re: Help needed [Re: bvining] #137722
03/25/08 11:42 AM
03/25/08 11:42 AM
How about an F16 board or an A cat board? The new L2 design have some really slim boards.
Matt M at Vectorworks,
John P at Stealth Marine (stealthmarine.co.uk),
Hans Klok at Catamaranparts.nl
Marcus Towell at Formlua Catamarans Australia (formulacatamarans.com),
The Lindahls for the L2.
Re: Help needed [Re: Rolf_Nilsen] #137723
03/25/08 12:42 PM
03/25/08 12:42 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
THanks Rolf,
I was looking for dimensions.
Re: Help needed [Re: bvining] #137724
03/25/08 01:58 PM
03/25/08 01:58 PM
claus Offline
claus  Offline
You can get an idea about various board meassurements at www.schrs.com, using CB and VLB. CB/VLB gives you the width in the case of rectangular boards. You have no info about how much of the board disappears in the hull however.
Re: Help needed [Re: claus] #137725
03/25/08 03:06 PM
03/25/08 03:06 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Claus
That doesnt help either, I need to know if an F18 or i20 board will fit in the HT trunk. So, the width and thickness of various boats boards are what I'm after.
Bill
Re: Help needed [Re: bvining] #137726
03/25/08 03:12 PM
03/25/08 03:12 PM
Bill,
I'll measure I20 and '04 Nacra F18 boards tonight.
Re: Help needed [Re: bvining] #137727
03/25/08 04:57 PM
03/25/08 04:57 PM
To me it looked like the Inter 20 boards were skinny-er than the Jav 2 boards. ie. shorter front to back. The Tiger boards might be closer to the Jav. boards.
Re: Help needed [Re: bvining] #137728
03/25/08 06:13 PM
03/25/08 06:13 PM
Claus
Bill
'04 - '07 Nacra F18 (not infusion) are 10" x 1" (~250mm X 25mm)
I20 is roughly 8 1/8" X 7/8" (206mm X 21mm)...I measured this one by approximating the daggerboard well....they're buried in the trailer.
Re: Help needed [Re: Jake] #137729
03/26/08 07:22 AM
03/26/08 07:22 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Thanks Jake, thats exactly what I needed.
The HT boards are 250mm x 23mm, so the i20 boards will work withe a bit of filler in the top and bottom of the case.
Bill
Re: Help needed [Re: bvining] #137730
03/26/08 08:13 AM
03/26/08 08:13 AM
Bill
Good! However, I feel obligated now to measure an actual board instead of the well before you make an investment...I'll dig out a board tonight to make sure.
Re: Help needed [Re: bvining] #137731
03/26/08 08:23 AM
03/26/08 08:23 AM
Are the original Jav 2 board no longer produced? Seems you could get some from the factory. They do weigh quite a bit less than I-20 boards if that's an issue.
Re: Help needed [Re: Timbo] #137732
03/26/08 10:07 AM
03/26/08 10:07 AM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
They are no longer available.
E-Scow
24' ULDB
Re: Help needed [Re: Jake] #137733
03/26/08 10:08 AM
03/26/08 10:08 AM
Lake Murray SC
Lake Murray SC
Bill
as Bill is helping me find boards, thanks for looking into my investment. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
E-Scow
24' ULDB
0 registered members (), 4,674 guests, and 1,069 spiders.
