Are you after advice on the striker or the strap?
The easiest way to install the striker is to get a large wall thickness tube. Slot it through the bottom of the beam (so its against the top of the beam) and weld it in place. A simple length adjustment can be made with a bolt a nut (two lock nuts are even better). Size the bolt so its a reasonable fit in the striker tube and then use the nut to adjust how much is sticking out at any given time. The applicable strap size is dependant on vessel weight, beam, striker length etc...... Fasten the strap at the ends with multiple small machine screws. When working out your necessary striker length go for a minimum strap to beam angle of about 8 degrees (higher if you have enough freeboard).
Good luck and if you need more info please ask.
