| Re: How important is relative boat weight?
[Re: Cheshirecatman]
#138066 03/31/08 07:09 AM 03/31/08 07:09 AM |
I haven't looked it up but I may well be wrong about Uffa Fox having designed the laser.
The rest of my posts still stands however.
[Re: Wouter]
#138068 03/31/08 07:24 AM 03/31/08 07:24 AM |
Posts: 242 Brisveagas | Wouter,
Its a lot simpler than that buddy. You can have as little or as much friction as you want. It doesn't really matter. Is all about the sum of the forces (F) which includes your very impressive friction component.
So i F equals 1 newton just for aguments sake. Then that will acclerate 1 kg at 1 m/ssq. The more mass an object has the slower it accelerates. Simple physics. Forget your crazy friction analysis it doesn't mean [censored] in the end.
So if your boat is heavier. Your going to have to come up with that extra power to keep up with the lighter boat coming off the start line and in general manouvers around the race course. Thats how real life works Wouter. We dont race in straight lines in some dutch test tank.
Sue
Aido Viper 288
[Re: Wouter]
#138069 03/31/08 07:28 AM 03/31/08 07:28 AM |
Posts: 1,226 Atlanta | I was sailing on a really narly day in Newport, it was the day that one of the 40ft racing tri's went head over.
We stuffed it going up wind and my crew stuck the trap ring thru the hull getting the boat back up.
Upwind on the tack with the hull with the hull full of water was unbelieveable. The boat was fast and flat in 30knots, with bigger puffs, Luckily we sailed back on a tack with the holed hull in the air, but the hole was forward, and we kept the bow up, and the hole out of the water, so the water that was in the hull stayed in the hull. Back at the ramp we discovered that the hull was almost FULL of water. Unbelieveable, I cant believe we didnt lose the shrouds with that much weight.
I've always thought we could/should have a way to suck up water on the tack and use that as ballast in the windward hull.
Bill | | | Re: How important is relative boat weight?
[Re: Aido]
#138070 03/31/08 08:46 AM 03/31/08 08:46 AM |
Posts: 9,582 North-West Europe | Sue, Are you explaining junior grade secondairy education physics to me and then misapplying it ? You really have no idea of what I do in my professional life do you ? Is all about the sum of the forces (F)
of which the drag forces are an very important part as the accelleration is only the result of the net difference between drag forces and drive forces. When both are equal and opposite to eachother the boat stops accellerating and had achieves max sustained speed (=topspeed). Newtons second law of motion is therefor not a factor with respect to sustained straight line speed (=topspeed) which is what racing catamarans spend by far most of their time doing. Of course, in reverse, a heavier boat decellerates (slows down) less then a lighter boat in the lulls and when encountering waves. A light boat may win at the start-line but will loose in the lulls by the same token. You cherry pick concepts and then simply ignore the reverse effects to argue your case. A failing grade skill level even for a junior secondairy level pupil/student. Wouter
[Re: bvining]
#138072 03/31/08 09:06 AM 03/31/08 09:06 AM |
Posts: 9,582 North-West Europe | Basically the loss of performance due to increased weight was more then offset by the increase in performance due to ability to hold down a more powered up rig. According to Uffa this is comparable to sailing a steamroller.
I rest my case.
[Re: Aido]
#138073 03/31/08 09:07 AM 03/31/08 09:07 AM |
Posts: 571 Hamburg | Sue,
Life is not as simple as you say. But okay, I will use your simple formula f=m*a. If your boat accelerates slower because it is neavier, then it deaccelerates also slower. Let us assume, both boats (one is 10% heavier) sail with 17kts. Both boats are hit by a wave (or a lull or make a manoeuvre or whatever) at the same time. The speed of the normal boat slows down to 15kts. (17kts - 2kts/s * 1s) The heavier boat slows only down to 15.2kts, right? (17kts-0.9 * 2kts/s * 1s) Now the boats accelerate again. After one second the normal boat reaches again 17 kts. (15kts + 2kts/s * 1s) The heavier boat accelerates slower, but because it has only lost 10% less speed, both boats reaches at the same time the speed of 17kts. (15.2kts + 0.9 * 2kts/s * 1s) During all this time, the heavier boat had have an equal or a higher speed than the lighter one, and hence traveled a longer distance. It is logic that a boat has to accelerate after each de-accelertaion. Hence from start to finish we have n de-accelertions and n+1 (the +1 is at the start of the race) accelerations. So the hevaier boat makes n times something good and looses only one time something.
Of course life is not only F=m*a, the hydro- and aerodynamic characteristics cannot be neglected. But even in your simple model, a heavier boat is faster.
Not only to Sue:
So far, it is an interesting discussion with good arguments from all participants. Let us discuss in civilised way, without insulting each other please.
Cheers,
Klaus | | | Re: How important is relative boat weight?
[Re: Wouter]
#138074 03/31/08 10:15 AM 03/31/08 10:15 AM |
Posts: 1,021 Australia | Apparently Uffa Fox (designer of the laser dinghy) didn't look around too much.
I think you will find that Bruce Kirby was the designer of the Laser.... But I might be wrong.... I have been known to spread crazy talk in the past <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | | Re: How important is relative boat weight?
[Re: Wouter]
#138075 03/31/08 10:25 AM 03/31/08 10:25 AM |
Posts: 1,021 Australia | Many racing mono's have waterballast (Volvo ocean, Classe Mini (the open fleet), large cats and tri like Orange). Many competition landyachters put (bags of) sand in their **** during days with strong windsI guess the designers of all these championship craft are just misguided.
The designers of the above craft were not misguided, they just had an understanding of how sail boats work... unlike some on this forum... I will attempt to explain but dont freak out if you get lost along the way, its complex and involves thought <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> on a Displacement boat (not a performance catamaran/multihull as the displacement rules dont fully apply to such a craft) once you reach hull speed then weight is good. it helps stabilise the boat and allows you to carry more power. it also helps with keeping speed during direction changes such as tacking. more momentum into a tack equals more speed on the way out. in the AC boats they have huge water bladders to fill with ater once the wind speed is such that the boat will be travelling at hull speed upwind. On the Farr 40's we put as much water as allowed in the bilge if the wind is strong enoug for us to reach our max VMG upwind. | | | Re: How important is relative boat weight?
[Re: Smiths_Cat]
#138076 03/31/08 10:42 AM 03/31/08 10:42 AM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | Here, I have a simple way to look at this and exclude the discussions about physics, fluid dynamics etc.
Look at the US Sailing Portsmouth numbers and compare these three boats; M20, CFR20 and I20. They have different rigs (uni vs. sloop) but carry similar sail areas both upwind and down wind (I know the M20 is 1' wider but it's still a good reference point). I probably should have pulled the Texel numbers and compared the I20 to the Eagle 20 Carbon but.... I did this....
Key Boat - weight, SA up x SA Down, Portsmouth numbers
M20 - ~255lbs, 24m^2 x 25m^2, 58.0 61.0 59.0 57.5 55.0 CFR - ~265lbs, 24m^2 x 25m^2, 58.0 61.5 58.2 58.1 57.3 I20 - ~390lbs, 24.25m^2 x 24m^2, 59.3 62.0 60.2 58.5 57.5
Notice that in light/med conditions the light boats are rated faster. As wind speed goes up the gap closes for the I20 and the CFR but not the M20 (the beam starts paying off).
I think the conclusion should be obvious. Lighter is faster. (don't rake me over the coals a/b the sloop vs. uni, I know I know....)
One more anecdotal account. I have sailed with some upper upper level sailors. If weight didn't matter, I don't think they would be so anal about using small light lines and keeping the garbage off the boat. | | | Re: How important is relative boat weight?
[Re: Wouter]
#138078 03/31/08 12:38 PM 03/31/08 12:38 PM |
Posts: 266 UK | From http://stanschreyer.com/?cat=7"Of course, the C-Class is now most widely known because of the wing sails which all boats use. The first wing sail appeared at a C-Class championship in 1974 on Miss Nylex, and it was made of spruce and balsa. Miss Nylex won the title that year, but was defeated by a soft sail boat (Aquarius V) the following year, mostly because Aquarius V was lighter." So the less efficient rig with greater drag from the rig beats the more efficient boat with no hull drag penalty and weight has nothing to do with it! Or maybe they weren't sailing in a tank and had a non- uniform wave pattern. Maybe like me when I go sailing I cannot optimise my hull shape for different crew weights. I have to cope with the non-optimised increase in drag. At a 10 knot average your 1kg example still gives a significant boatlength difference. let alone the opportunity for position on the water. I am sure that most sailors would not quibble about your 1kg difference but 10, 15 or even 20kg! I do however find that when I have a lighter crew/boat combination I power up earlier and once overpowered I can use rig control to reduce power and drag from the rig. | | | Re: How important is relative boat weight?
[Re: jimi]
#138083 03/31/08 05:45 PM 03/31/08 05:45 PM |
Posts: 9,582 North-West Europe | Your posts are very interesting, Wouter. Could you send me a pm where you do a complete analysis of the drag forces and the driving forces acting on a cat moving through the water? thanks!
Sorry, insufficient spare time. Besides I've typed up large sections of it already on this forum in the past; maybe do a search ? Also writing out a COMPLETE analysis of drag and drive forces is a major project in itself. Wouter
[Re: srm]
#138084 03/31/08 05:52 PM 03/31/08 05:52 PM |
Posts: 9,582 North-West Europe | ... During all this time, the heavier boat had have an equal or a higher speed than the lighter one, and hence traveled a longer distance. It is logic that a boat has to accelerate after each de-accelertaion. Hence from start to finish we have n de-accelertions and n+1 (the +1 is at the start of the race) accelerations. So the hevaier boat makes n times something good and looses only one time something.
The critical issue (and one that effects catamarans as well as any other sailboat) is that the total weight essentially contributes to both drag and power. The trick is to maximise the power-to-weight(drag) ratio ...
Finally some persons who are using their brains ! You guys are spot on, Smiths_cat and SRM ! And both of you give perfect example of where an overly simplified rule of thumb like "less weight is always better" falls flat. Wouter
1 registered members (FredL),
2,799
guests, and 283
