Page 3 of 5 1 2 3 4 5
Re: How important is relative boat weight? [Re: Wouter] #138065
03/31/08 06:48 AM
03/31/08 06:48 AM
UK
Cheshirecatman Offline
UK
Do you want to just check up on Uffa Fox and correct comments?
Uffa Fox did wonders for the development of lightweight planing dinghies. I dont think Bruce Kirby will be too pleased about about the laser comment either.
Re: How important is relative boat weight? [Re: Cheshirecatman] #138066
03/31/08 07:09 AM
03/31/08 07:09 AM
I haven't looked it up but I may well be wrong about Uffa Fox having designed the laser.
The rest of my posts still stands however.
Re: How important is relative boat weight? [Re: Wouter] #138067
03/31/08 07:23 AM
03/31/08 07:23 AM
Mary Offline OP
Mary  Offline OP
Bruce Kirby designed the Laser.
Re: How important is relative boat weight? [Re: Wouter] #138068
03/31/08 07:24 AM
03/31/08 07:24 AM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Its a lot simpler than that buddy. You can have as little or as much friction as you want. It doesn't really matter. Is all about the sum of the forces (F) which includes your very impressive friction component.
So i F equals 1 newton just for aguments sake. Then that will acclerate 1 kg at 1 m/ssq. The more mass an object has the slower it accelerates. Simple physics. Forget your crazy friction analysis it doesn't mean [censored] in the end.
So if your boat is heavier. Your going to have to come up with that extra power to keep up with the lighter boat coming off the start line and in general manouvers around the race course. Thats how real life works Wouter. We dont race in straight lines in some dutch test tank.
Sue
Aido
Viper 288
Re: How important is relative boat weight? [Re: Wouter] #138069
03/31/08 07:28 AM
03/31/08 07:28 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I was sailing on a really narly day in Newport, it was the day that one of the 40ft racing tri's went head over.
We stuffed it going up wind and my crew stuck the trap ring thru the hull getting the boat back up.
Upwind on the tack with the hull with the hull full of water was unbelieveable. The boat was fast and flat in 30knots, with bigger puffs, Luckily we sailed back on a tack with the holed hull in the air, but the hole was forward, and we kept the bow up, and the hole out of the water, so the water that was in the hull stayed in the hull. Back at the ramp we discovered that the hull was almost FULL of water. Unbelieveable, I cant believe we didnt lose the shrouds with that much weight.
I've always thought we could/should have a way to suck up water on the tack and use that as ballast in the windward hull.
Bill
Re: How important is relative boat weight? [Re: Aido] #138070
03/31/08 08:46 AM
03/31/08 08:46 AM
Sue,
Are you explaining junior grade secondairy education physics to me and then misapplying it ?
You really have no idea of what I do in my professional life do you ?
of which the drag forces are an very important part as the accelleration is only the result of the net difference between drag forces and drive forces. When both are equal and opposite to eachother the boat stops accellerating and had achieves max sustained speed (=topspeed).
Newtons second law of motion is therefor not a factor with respect to sustained straight line speed (=topspeed) which is what racing catamarans spend by far most of their time doing.
Of course, in reverse, a heavier boat decellerates (slows down) less then a lighter boat in the lulls and when encountering waves. A light boat may win at the start-line but will loose in the lulls by the same token.
You cherry pick concepts and then simply ignore the reverse effects to argue your case. A failing grade skill level even for a junior secondairy level pupil/student.
Re: How important is relative boat weight? [Re: Wouter] #138071
03/31/08 08:52 AM
03/31/08 08:52 AM
I would like to know what Sue is doing in her professional life though.
It is well known to the regulars here what Wouter do <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: How important is relative boat weight? [Re: bvining] #138072
03/31/08 09:06 AM
03/31/08 09:06 AM
Basically the loss of performance due to increased weight was more then offset by the increase in performance due to ability to hold down a more powered up rig. According to Uffa this is comparable to sailing a steamroller.
I rest my case.
Re: How important is relative boat weight? [Re: Aido] #138073
03/31/08 09:07 AM
03/31/08 09:07 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Sue,
Life is not as simple as you say. But okay, I will use your simple formula f=m*a.
If your boat accelerates slower because it is neavier, then it deaccelerates also slower.
Let us assume, both boats (one is 10% heavier) sail with 17kts. Both boats are hit by a wave (or a lull or make a manoeuvre or whatever) at the same time.
The speed of the normal boat slows down to 15kts. (17kts - 2kts/s * 1s)
The heavier boat slows only down to 15.2kts, right? (17kts-0.9 * 2kts/s * 1s)
Now the boats accelerate again.
After one second the normal boat reaches again 17 kts. (15kts + 2kts/s * 1s)
The heavier boat accelerates slower, but because it has only lost 10% less speed, both boats reaches at the same time the speed of 17kts. (15.2kts + 0.9 * 2kts/s * 1s)
During all this time, the heavier boat had have an equal or a higher speed than the lighter one, and hence traveled a longer distance.
It is logic that a boat has to accelerate after each de-accelertaion. Hence from start to finish we have n de-accelertions and n+1 (the +1 is at the start of the race) accelerations. So the hevaier boat makes n times something good and looses only one time something.
Of course life is not only F=m*a, the hydro- and aerodynamic characteristics cannot be neglected. But even in your simple model, a heavier boat is faster.
Not only to Sue:
So far, it is an interesting discussion with good arguments from all participants. Let us discuss in civilised way, without insulting each other please.
Cheers,
Klaus
Re: How important is relative boat weight? [Re: Wouter] #138074
03/31/08 10:15 AM
03/31/08 10:15 AM
Australia
macca Offline
macca  Offline
Australia
Apparently Uffa Fox (designer of the laser dinghy) didn't look around too much.
I think you will find that Bruce Kirby was the designer of the Laser.... But I might be wrong.... I have been known to spread crazy talk in the past <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
________________________
http://aus300.blogspot.com
Re: How important is relative boat weight? [Re: Wouter] #138075
03/31/08 10:25 AM
03/31/08 10:25 AM
Australia
macca Offline
macca  Offline
Australia
Many racing mono's have waterballast (Volvo ocean, Classe Mini (the open fleet), large cats and tri like Orange). Many competition landyachters put (bags of) sand in their **** during days with strong windsI guess the designers of all these championship craft are just misguided.
The designers of the above craft were not misguided, they just had an understanding of how sail boats work... unlike some on this forum...
I will attempt to explain but dont freak out if you get lost along the way, its complex and involves thought <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
on a Displacement boat (not a performance catamaran/multihull as the displacement rules dont fully apply to such a craft) once you reach hull speed then weight is good. it helps stabilise the boat and allows you to carry more power. it also helps with keeping speed during direction changes such as tacking. more momentum into a tack equals more speed on the way out.
in the AC boats they have huge water bladders to fill with ater once the wind speed is such that the boat will be travelling at hull speed upwind. On the Farr 40's we put as much water as allowed in the bilge if the wind is strong enoug for us to reach our max VMG upwind.
Re: How important is relative boat weight? [Re: Smiths_Cat] #138076
03/31/08 10:42 AM
03/31/08 10:42 AM
Will_R Offline
Will_R  Offline
Here, I have a simple way to look at this and exclude the discussions about physics, fluid dynamics etc.
Look at the US Sailing Portsmouth numbers and compare these three boats; M20, CFR20 and I20. They have different rigs (uni vs. sloop) but carry similar sail areas both upwind and down wind (I know the M20 is 1' wider but it's still a good reference point). I probably should have pulled the Texel numbers and compared the I20 to the Eagle 20 Carbon but.... I did this....
Key
Boat - weight, SA up x SA Down, Portsmouth numbers
M20 - ~255lbs, 24m^2 x 25m^2, 58.0 61.0 59.0 57.5 55.0
CFR - ~265lbs, 24m^2 x 25m^2, 58.0 61.5 58.2 58.1 57.3
I20 - ~390lbs, 24.25m^2 x 24m^2, 59.3 62.0 60.2 58.5 57.5
Notice that in light/med conditions the light boats are rated faster. As wind speed goes up the gap closes for the I20 and the CFR but not the M20 (the beam starts paying off).
I think the conclusion should be obvious. Lighter is faster. (don't rake me over the coals a/b the sloop vs. uni, I know I know....)
One more anecdotal account. I have sailed with some upper upper level sailors. If weight didn't matter, I don't think they would be so anal about using small light lines and keeping the garbage off the boat.
Re: How important is relative boat weight? [Re: Wouter] #138077
03/31/08 11:49 AM
03/31/08 11:49 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
well... yanno..
Uffa Fox was as instrumental as Bethwaite Snr, Charles Sparrow, John Spenser, Ben Lexcen and Richard Court in the development of high speed sailing. Debate all you want but I am confident the marine architects will back my statement.
Uffa if I recall basically made the International Canoe class the speed machine it is.. He was the father of the modern planing dinghy with his International 14 "Avenger". Her record stands today winning almost all the races in the first year she entered. Only Darkie is in her class as a 14teen legend. He was involved in developing the trapeze..
Maybe if land yachts used a trapeze they wouldn't need the sand ballast.
Im not an engineer.. I only vaguely recall my sckoolin but isnt there a formula that equates force is equal to mass times acceleration? So for a given force the greater the mass the less the acceleration..
<img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: How important is relative boat weight? [Re: Wouter] #138078
03/31/08 12:38 PM
03/31/08 12:38 PM
UK
UK
From http://stanschreyer.com/?cat=7
"Of course, the C-Class is now most widely known because of the wing sails which all boats use. The first wing sail appeared at a C-Class championship in 1974 on Miss Nylex, and it was made of spruce and balsa. Miss Nylex won the title that year, but was defeated by a soft sail boat (Aquarius V) the following year, mostly because Aquarius V was lighter."
So the less efficient rig with greater drag from the rig beats the more efficient boat with no hull drag penalty and weight has nothing to do with it! Or maybe they weren't sailing in a tank and had a non- uniform wave pattern. Maybe like me when I go sailing I cannot optimise my hull shape for different crew weights. I have to cope with the non-optimised increase in drag. At a 10 knot average your 1kg example still gives a significant boatlength difference. let alone the opportunity for position on the water. I am sure that most sailors would not quibble about your 1kg difference but 10, 15 or even 20kg! I do however find that when I have a lighter crew/boat combination I power up earlier and once overpowered I can use rig control to reduce power and drag from the rig.
Re: How important is relative boat weight? [Re: Cheshirecatman] #138079
03/31/08 03:40 PM
03/31/08 03:40 PM
Trondheim, Norway
jimi Offline
jimi  Offline
Trondheim, Norway
Your posts are very interesting, Wouter. Could you send me a pm where you do a complete analysis of the drag forces and the driving forces acting on a cat moving through the water? thanks!
Re: How important is relative boat weight? [Re: Cheshirecatman] #138080
03/31/08 03:56 PM
03/31/08 03:56 PM
srm Offline
srm  Offline
One important point to keep in mind is that weight can not be considered by itself. You have to consider the power to weight ratio. Look at two of the fastest sailing craft in the world- Yellow Pages and the windsurfers. One weighs about 350lb and the other weights about 30. Both have achieved virtually the same speed while the first being about 10 times heavier than second. It's all about power-to-weight.
This is why having a heavy boat is generally not beneficial, because the added weight contributes mostly to drag and little to righting moment (which equals power). However having a heavier crew (movable weight) contributes to more power generated from the rig (as long as the wind is strong enough to support the fully hiked crew).
sm
Re: How important is relative boat weight? [Re: srm] #138081
03/31/08 04:11 PM
03/31/08 04:11 PM
Trondheim, Norway
jimi Offline
jimi  Offline
Trondheim, Norway
No doubt that the power to weight ratio is important, but comparing beach cats to a windsurfer or yellow pages to me seems wrong. Yellowpages travels at nearly 50 knots, and as the wind-drag goes by the velocity squared, the wind-drag is by far the biggest drag component in those speeds. At 15-20 knots however, I think the picture is rather different.
Re: How important is relative boat weight? [Re: jimi] #138082
03/31/08 04:24 PM
03/31/08 04:24 PM
srm Offline
srm  Offline
Air and water are both fluids, so the hull drag goes up with respect to velocity squared as well. That's why planing and hydrofoiling craft are able to get up to these high speeds- they reduce surface area as their speed increases. So in this case, a catamaran does not act the same way as a planing craft because it's surface area does not decrease with increased speed.
My point however was that you can't look at weight alone because here we have two craft (YPE and windsurfer) that are able to travel at roughly the same speed yet one weighs about 10 times as much as the other. We could throw Hydroptere into the equasion and probably have another boat that weighs about 10 times what YPE weighs.
The critical issue (and one that effects catamarans as well as any other sailboat) is that the total weight essentially contributes to both drag and power. The trick is to maximise the power-to-weight(drag) ratio something that YPE and windsurfers have done quite well. This means having minimum boat weight, but not necessarily minimum overall weight.
sm
Re: How important is relative boat weight? [Re: jimi] #138083
03/31/08 05:45 PM
03/31/08 05:45 PM
Sorry, insufficient spare time.
Besides I've typed up large sections of it already on this forum in the past; maybe do a search ?
Also writing out a COMPLETE analysis of drag and drive forces is a major project in itself.
Re: How important is relative boat weight? [Re: srm] #138084
03/31/08 05:52 PM
03/31/08 05:52 PM
... During all this time, the heavier boat had have an equal or a higher speed than the lighter one, and hence traveled a longer distance.
The critical issue (and one that effects catamarans as well as any other sailboat) is that the total weight essentially contributes to both drag and power. The trick is to maximise the power-to-weight(drag) ratio ...
Finally some persons who are using their brains !
You guys are spot on, Smiths_cat and SRM !
And both of you give perfect example of where an overly simplified rule of thumb like "less weight is always better" falls flat.
0 registered members (), 4,680 guests, and 1,088 spiders.
