Mast rotation 4 boomless cats necessary 4 racing? #138211
03/29/08 12:25 PM
03/29/08 12:25 PM
Lake Murray SC
FasterDamnit Offline OP
Lake Murray SC
Your thoughts, please. Is a forced rotation setup a big benefit w/ a boomless main. G-Cat 5.7 rig.
Gracias.
E-Scow
24' ULDB
Re: Mast rotation 4 boomless cats necessary 4 racing? [Re: FasterDamnit] #138212
03/29/08 12:28 PM
03/29/08 12:28 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
For downwind, yes definitely.
Re: Mast rotation 4 boomless cats necessary 4 racing? [Re: pitchpoledave] #138213
03/29/08 12:32 PM
03/29/08 12:32 PM
virginia beach, VA
dsltrc Offline
dsltrc  Offline
virginia beach, VA
on my supercat 19 i use a mast limiter.... and down wind i use it to rotate the mast more.....
Jason DiPietro supercat 19
Re: Mast rotation 4 boomless cats necessary 4 racing? [Re: FasterDamnit] #138214
03/29/08 12:39 PM
03/29/08 12:39 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Gracias.
Definitely a plus on boomless Nacras up and downwind.
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: pitchpoledave] #138215
03/29/08 12:41 PM
03/29/08 12:41 PM
Lake Murray SC
Lake Murray SC
How about w/ a spin? The traveller is not out very far on spin boats off the wind.
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: FasterDamnit] #138216
03/29/08 01:51 PM
03/29/08 01:51 PM
I have trouble conceptualizing (?) the issue of mast rotation downwind because people set it as if the wind were really coming from the side when, especially with the spin, it actually isn't by the time you have apparent wind. So, according to wind flow, it should just be a little out from where it is upwind but everyone seems to blow it completely and let it go almost 90 degrees. Who knows though, just thoughts...
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: PTP] #138217
03/29/08 02:17 PM
03/29/08 02:17 PM
Minneapolis
Mpls_Nacra Offline
Mpls_Nacra  Offline
Minneapolis
Could someone post some photos of the system. I am interested in installing one on my N 5.8.
Dave Foster
Minneapolis
Nacra F16
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: FasterDamnit] #138218
03/29/08 02:53 PM
03/29/08 02:53 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Nacra 14sq the rotation becomes needed downwind in the light. Once the wind is up enough to force it around you are better off concentrating on not making mistakes and keeping your head out of the boat.
Up wind the in-haul is what sets the mast rotation so do not give it a thought as far as the spanner is concerned. Get the in-haul and main tension right and you are sweet. Again, less mistakes and mucking about inboard is faster.
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: FasterDamnit] #138219
03/29/08 03:38 PM
03/29/08 03:38 PM
Actually, you MUST have it with a spin. Otherwise, you can't control the mast rotation and it could rotate to weird angles and cause breakage. On a boat with a boom, that can force positive rotation with sheet pressure, it's not necessary to lock in the mast rotation.
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: Jake] #138220
03/29/08 03:43 PM
03/29/08 03:43 PM
Lake Murray SC
Lake Murray SC
Thanks. Any preference which way to mount the rotator? facing aft or forward?
E-Scow
24' ULDB
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: FasterDamnit] #138221
03/29/08 05:25 PM
03/29/08 05:25 PM
rexdenton Offline
rexdenton  Offline
I had a 5.5 with a spin. Mast rotator worked fine, but you have to watch it and limit downward movement, as it could get caught on the spi pole.
Nacra F18 #856
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: rexdenton] #138222
03/29/08 05:35 PM
03/29/08 05:35 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
An eyestrap about a foot above the mast rotator on the front of the mast with a rope or wire leading down to both corners of the rotator arm to hold the rotator up will solve that problem.
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: wildtsail] #138223
03/29/08 07:39 PM
03/29/08 07:39 PM
rexdenton Offline
rexdenton  Offline
yep, but I used a bungee
Nacra F18 #856
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: Mpls_Nacra] #138224
03/31/08 11:47 PM
03/31/08 11:47 PM
jcasto1 Offline
jcasto1  Offline
I have rotation-inducing hardware on both my 5.7 and 5.5uni, generally considered mandatory for downwind control of sail shape on boomless rigs. I'll take a picture wednesday & post.
I mount the rotator facing forward. And you must have lines to keep jib sheets from tangling.
Cleat position for rotator should be where you can easily release just before a jibe. I have a continuous line, so I can cleat & uncleat from either side, using H240 swivel cleats and bullseye fairleads. You'll need a special mounting pad to mount the swivel cleat on the NACRA round beam.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: jcasto1] #138225
04/01/08 09:45 AM
04/01/08 09:45 AM
mikekrantz Offline
mikekrantz  Offline
I made my own contoured mounting pads by cutting the material out with a hole saw. Then I taped 60 grit to the beam, and rubbed the pad back and forth. In just a couple of minutes the base pad contour matched the beam's contour.
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: mikekrantz] #138226
04/01/08 09:34 PM
04/01/08 09:34 PM
jcasto1 Offline
jcasto1  Offline
cool idea, thanks.
I recently took my swivel cleat & pads off to service the old swivel cleat, and noticed corrosion on the aluminum beam under the pad. Any ideas on how to avoid corrosion like this? I'm used to seeing corrosion where SS screws go into Aluminum, but this was a 2" diameter circle that will eventually eat through my beam!
What about cleaning it before mounting, then using silicone or something to seal it and keep salt water out?
Jim Casto
Austin TX
Lake Travis
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: jcasto1] #138227
04/01/08 09:57 PM
04/01/08 09:57 PM
West Virginia
Soapysails Offline
Soapysails  Offline
West Virginia
A simple and cheap way to stop this problem..clean the effected area, apply a thin film of "Calsium Starite" a polimer based grease.(clear lithium will work too) These soap based greases resist water and will stay put forever ! clean around the area after re-assemble with MEK or 111 tricloro.
Find a DuBois Chemical or Johnson-Diversey rep in your area..he or she will be happy to give you a small sample (-1oz.)if that fails, I will mail you some myself..
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: Soapysails] #138228
04/02/08 08:15 AM
04/02/08 08:15 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Another significant advantage (almost as important as the increase in speed!) is the Mast rotation limiters purpose as a depowering tool. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: Buccaneer] #138229
04/02/08 12:03 PM
04/02/08 12:03 PM
Lake Murray SC
Lake Murray SC
Pics wold be much appreciated!
E-Scow
24' ULDB
Re: Mast rotation 4 boomless cats necessary 4 raci [Re: FasterDamnit] #138230
04/02/08 06:15 PM
04/02/08 06:15 PM
White Bear Lake, MN
h17racer Offline
h17racer  Offline
White Bear Lake, MN
Jim, attached pic is how I setup my 5.5 Uni. Front rotator, blocks and front crossbar mounting blocks.
I over-rotate downwind. Only use upwind when I need to induce a rotation angle.
Sail fast, Tom G
0 registered members (), 2,639 guests, and 380 spiders.
12 hours ago
