| Mast rotation 4 boomless cats necessary 4 racing? #138211 03/29/08 12:25 PM 03/29/08 12:25 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit OP
Posts: 531 Lake Murray SC | Your thoughts, please. Is a forced rotation setup a big benefit w/ a boomless main. G-Cat 5.7 rig.
Gracias.
E-Scow 24' ULDB
| | | Re: Mast rotation 4 boomless cats necessary 4 racing?
[Re: pitchpoledave]
#138213 03/29/08 12:32 PM 03/29/08 12:32 PM |
Posts: 93 virginia beach, VA | on my supercat 19 i use a mast limiter.... and down wind i use it to rotate the mast more.....
Jason DiPietro
supercat 19
[Re: FasterDamnit]
#138214 03/29/08 12:39 PM 03/29/08 12:39 PM |
Posts: 1,459 Annapolis,MD | Your thoughts, please. Is a forced rotation setup a big benefit w/ a boomless main. G-Cat 5.7 rig.
Gracias. Definitely a plus on boomless Nacras up and downwind. | | | Re: Mast rotation 4 boomless cats necessary 4 raci
[Re: pitchpoledave]
#138215 03/29/08 12:41 PM 03/29/08 12:41 PM |
Posts: 531 Lake Murray SC | For downwind, yes definitely. How about w/ a spin? The traveller is not out very far on spin boats off the wind. | | | Re: Mast rotation 4 boomless cats necessary 4 raci
[Re: PTP]
#138217 03/29/08 02:17 PM 03/29/08 02:17 PM |
Posts: 57 Minneapolis | Could someone post some photos of the system. I am interested in installing one on my N 5.8.
Dave Foster Minneapolis Nacra F16
[Re: FasterDamnit]
#138219 03/29/08 03:38 PM 03/29/08 03:38 PM |
Posts: 12,310 South Carolina | For downwind, yes definitely. How about w/ a spin? The traveller is not out very far on spin boats off the wind. Actually, you MUST have it with a spin. Otherwise, you can't control the mast rotation and it could rotate to weird angles and cause breakage. On a boat with a boom, that can force positive rotation with sheet pressure, it's not necessary to lock in the mast rotation.
Jake Kohl | | | Re: Mast rotation 4 boomless cats necessary 4 raci
#138220 03/29/08 03:43 PM 03/29/08 03:43 PM |
Posts: 531 Lake Murray SC | Thanks. Any preference which way to mount the rotator? facing aft or forward?
E-Scow 24' ULDB
[Re: FasterDamnit]
#138221 03/29/08 05:25 PM 03/29/08 05:25 PM |
Posts: 297 | Thanks. Any preference which way to mount the rotator? facing aft or forward? I had a 5.5 with a spin. Mast rotator worked fine, but you have to watch it and limit downward movement, as it could get caught on the spi pole.
Nacra F18 #856
[Re: Mpls_Nacra]
#138224 03/31/08 11:47 PM 03/31/08 11:47 PM |
Posts: 217 | I have rotation-inducing hardware on both my 5.7 and 5.5uni, generally considered mandatory for downwind control of sail shape on boomless rigs. I'll take a picture wednesday & post. I mount the rotator facing forward. And you must have lines to keep jib sheets from tangling. Cleat position for rotator should be where you can easily release just before a jibe. I have a continuous line, so I can cleat & uncleat from either side, using H240 swivel cleats and bullseye fairleads. You'll need a special mounting pad to mount the swivel cleat on the NACRA round beam.
[Re: mikekrantz]
#138226 04/01/08 09:34 PM 04/01/08 09:34 PM |
Posts: 217 | cool idea, thanks.
I recently took my swivel cleat & pads off to service the old swivel cleat, and noticed corrosion on the aluminum beam under the pad. Any ideas on how to avoid corrosion like this? I'm used to seeing corrosion where SS screws go into Aluminum, but this was a 2" diameter circle that will eventually eat through my beam! What about cleaning it before mounting, then using silicone or something to seal it and keep salt water out?
[Re: Soapysails]
#138228 04/02/08 08:15 AM 04/02/08 08:15 AM |
Posts: 1,479 Thailand | Another significant advantage (almost as important as the increase in speed!) is the Mast rotation limiters purpose as a depowering tool. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
[Re: Buccaneer]
#138229 04/02/08 12:03 PM 04/02/08 12:03 PM |
Posts: 531 Lake Murray SC | Pics wold be much appreciated!
E-Scow 24' ULDB
2,481
guests, and 481
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online7,715 11 hours ago | | |
