| Re: What to use to mark Dagger Boards with lines
[Re: Mappy]
#138514 03/31/08 04:00 PM 03/31/08 04:00 PM |
Posts: 334 Seattle,Wa | The BIG fat ones <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> Phat Sharpie Hobie Tiger 2003 | | | Re: What to use to mark Dagger Boards with lines
#138516 03/31/08 06:37 PM 03/31/08 06:37 PM |
Posts: 3,906 Clermont, FL, USA | No, no... you want to use a sharpie.
[Re: David Ingram]
#138517 03/31/08 06:51 PM 03/31/08 06:51 PM |
Posts: 291 | sharpie....isn't that a breed of dog. Well at least they are good for something. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: Mappy]
#138520 04/01/08 04:56 AM 04/01/08 04:56 AM |
Posts: 1,203 uk | Get a router and machine out a 10mm x 2mm deep band around the daggerboard in exactly the right position. Mask up the edge of the rout and infill the exposed area with a contrasting gelcoat colour. carefully wet and dry the new gel down until flush and then polish the whole daggerboard........ April fool, forget that and just get a pen! I also like to write abusive messages below the band so that they can be read as you fly a hull past someone - they soon wear off and you have to think of some new ones!
[Re: Codblow]
#138523 04/01/08 03:18 PM 04/01/08 03:18 PM |
[Re: TEAMVMG]
#138524 04/01/08 03:21 PM 04/01/08 03:21 PM |
Posts: 12,310 South Carolina | Get a router and machine out a 10mm x 2mm deep band around the daggerboard in exactly the right position. Mask up the edge of the rout and infill the exposed area with a contrasting gelcoat colour. carefully wet and dry the new gel down until flush and then polish the whole daggerboard........ April fool, forget that and just get a pen! I also like to write abusive messages below the band so that they can be read as you fly a hull past someone - they soon wear off and you have to think of some new ones! April fool's my butt....that's a great idea!
Jake Kohl | | | Re: What to use to mark Dagger Boards with lines
#138525 04/01/08 04:14 PM 04/01/08 04:14 PM | Anonymous
| Anonymous
Unregistered | I suggest you insert the boards and create a few lines in pencil on each side first.... mark where the boart is flush with the hull (again on each side).
Then you can use a ruler and work up more lines with the sharpie... You will have to re-draw the lines every season, as they fade with exposure, but it is a good idea. | | |
407
guests, and 47
