What to use to mark Dagger Boards with lines #138511
03/31/08 03:43 PM
03/31/08 03:43 PM
M
Mappy Offline OP
Mappy  Offline OP
M
What should I use to make markings on the dagger board. Paint? Gelcoat? I would like to make markings or lines indicating how high to pull the board flush with the deck and also 1/3 up for the crew.
Re: What to use to mark Dagger Boards with lines [Re: Mappy] #138512
03/31/08 03:48 PM
03/31/08 03:48 PM
Vancouver, WA
TJP Offline
TJP  Offline
Vancouver, WA
Sharpie!
Re: What to use to mark Dagger Boards with lines [Re: TJP] #138513
03/31/08 03:51 PM
03/31/08 03:51 PM
Sharpie!
2nd! Sharpie.
Re: What to use to mark Dagger Boards with lines [Re: Mappy] #138514
03/31/08 04:00 PM
03/31/08 04:00 PM
Seattle,Wa
Don_Atchley Offline
Don_Atchley  Offline
Seattle,Wa
The BIG fat ones
<img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Phat Sharpie
Hobie Tiger 2003
Re: What to use to mark Dagger Boards with lines [Re: Don_Atchley] #138515
03/31/08 04:54 PM
03/31/08 04:54 PM
Vancouver, WA
TJP Offline
TJP  Offline
Vancouver, WA
The BIG fat ones
Phat Sharpie
Ooooh even better, Industrial Sharpie !
Re: What to use to mark Dagger Boards with lines [Re: Jake] #138516
03/31/08 06:37 PM
03/31/08 06:37 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Sharpie!
2nd! Sharpie.
No, no... you want to use a sharpie.
F18 USA 242
http://www.solarwind.solar
Re: What to use to mark Dagger Boards with lines [Re: David Ingram] #138517
03/31/08 06:51 PM
03/31/08 06:51 PM
JACKFLASH Offline
JACKFLASH  Offline
sharpie....isn't that a breed of dog. Well at least they are good for something. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Collin Casey
Re: What to use to mark Dagger Boards with lines [Re: JACKFLASH] #138518
03/31/08 07:22 PM
03/31/08 07:22 PM
West Virginia
Soapysails Offline
Soapysails  Offline
West Virginia
Red and Green Sharpies !
Re: What to use to mark Dagger Boards with lines [Re: Soapysails] #138519
03/31/08 10:59 PM
03/31/08 10:59 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Rainbow Sharpies!!
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: What to use to mark Dagger Boards with lines [Re: Mappy] #138520
04/01/08 04:56 AM
04/01/08 04:56 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Get a router and machine out a 10mm x 2mm deep band around the daggerboard in exactly the right position. Mask up the edge of the rout and infill the exposed area with a contrasting gelcoat colour. carefully wet and dry the new gel down until flush and then polish the whole daggerboard........ April fool, forget that and just get a pen!
I also like to write abusive messages below the band so that they can be read as you fly a hull past someone - they soon wear off and you have to think of some new ones!
Re: What to use to mark Dagger Boards with lines [Re: TEAMVMG] #138521
04/01/08 06:40 AM
04/01/08 06:40 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Or, buy colored electrical tape and cut triangular shapes to place along the trailing edge to indicate specific depths.
Green, full down, yellow, half down, and red, full up.
It looks better than sharpie artwork.
Re: What to use to mark Dagger Boards with lines [Re: arbo06] #138522
04/01/08 06:58 AM
04/01/08 06:58 AM
couldn't resist it
Codblow Offline
Codblow  Offline
couldn't resist it
and creates more drag
Re: What to use to mark Dagger Boards with lines [Re: Codblow] #138523
04/01/08 03:18 PM
04/01/08 03:18 PM
Clermont, FL, USA
Clermont, FL, USA
But it's pretty.
F18 USA 242
Re: What to use to mark Dagger Boards with lines [Re: TEAMVMG] #138524
04/01/08 03:21 PM
04/01/08 03:21 PM
April fool's my butt....that's a great idea!
Re: What to use to mark Dagger Boards with lines [Re: Jake] #138525
04/01/08 04:14 PM
04/01/08 04:14 PM
I suggest you insert the boards and create a few lines in pencil on each side first.... mark where the boart is flush with the hull (again on each side).
Then you can use a ruler and work up more lines with the sharpie... You will have to re-draw the lines every season, as they fade with exposure, but it is a good idea.
Re: What to use to mark Dagger Boards with lines [Re: Codblow] #138526
04/01/08 08:33 PM
04/01/08 08:33 PM
arbo06 Offline
arbo06  Offline
Wow.. I never considered that, maybe if I remove those damn tape marks I can beat the fleet to C mark. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
0 registered members (), 619 guests, and 655 spiders.
