| Ants Marching... #138672 04/01/08 09:25 AM 04/01/08 09:25 AM |
Posts: 3,969 | OK, the timing is bad, but this is NOT an April Fools thing (I only wish)...
What's the strangest thing(s) you've ever found in your sail box?
This past weekend, I was taking out my sails to see how they look for the season. The boat hasn't left the yard since the H16 NAs in 2006 (due to new baby), and has been parked under oak trees (except when in the front yard covered in Christmas lights).
Anyway, I got to my spare (old BRU Cat) sails, and the main was completely infested with black (Carpenter?) ants. Not wanting to use bug spray for fear that it would eat through the sail, I spent a good half hour with a shop vac getting rid of them.
I emptied the whole box, but there weren't any ants anywhere else. The new sail bag is zippered, maybe that kept them out?
Anyway, I'm assuming they didn't damage the sail, because I didn't see any holes or anything. Very creepy though...
Mike | | | Re: Ants Marching...
[Re: brucat]
#138674 04/01/08 09:40 AM 04/01/08 09:40 AM |
Posts: 12,310 South Carolina | OK, the timing is bad, but this is NOT an April Fools thing (I only wish)...
Mike Those aren't necessarily carpenter ants. When I bought my used monohull and removed the rub rail, it was completely infested with those little blank ants. My RV also had a similar issue but I quickly identified a squished jelly pack in one of the utensil draws, removed and cleaned that drawer thoroughly, and just before I put down ant killer, they completely disappeared. Make sure there's not a left-over snack bar in the box or something.
Jake Kohl | | | Re: Ants Marching...
[Re: tami]
#138677 04/01/08 10:56 AM 04/01/08 10:56 AM |
Posts: 3,969 | Forgot to mention, the box is fiberglass, there was no wood or food in there, and it was pretty dry. There was a cardboard box (holding spare rudders), which was damp, but wasn't showing signs of having been ant lunch.
I do have wood under the box, spanning across the trailer to support the middle of the box, but that is 2-year old PT wood and I'd like to doubt that the ants would be eating that and surviving.
They were the big black ants, the bigger ones were 3/4 inch long. Some of them had a brownish color to their big section (in case we have any bug experts here).
Come on, no poisonous snake stories???
[Re: brucat]
#138681 04/01/08 11:49 AM 04/01/08 11:49 AM |
Joined: Oct 2006 Posts: 119 Bernhards Bay, N.Y. popeyez7
Posts: 119 Bernhards Bay, N.Y. | Maybe they wanna go sailin????? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION'' ~17,18 Hobies, ~Jet boat~Speedster 150 ~2 Kayaks~ ~~~~VIETNAM VET. 69-71~~~~
[Re: brucat]
#138682 04/01/08 12:22 PM 04/01/08 12:22 PM |
Posts: 1,307 Asuncion, Paraguay | Come on, no poisonous snake stories???
No snakes so far, but once we found thousands of bees nested inside a H16 hull. This was really dangerous. Final solution: a cork in the drain plug.
Luiz
[Re: popeyez7]
#138683 04/01/08 12:34 PM 04/01/08 12:34 PM |
Joined: Aug 2007 Posts: 342 Indianapolis, IN - Midwest USA... IndyWave
Posts: 342 Indianapolis, IN - Midwest USA... | I get a lot of **** in my wooden sailbox. It's near the shore, by some trees and underbrush; and I built it with a 1/4" gap on the bottom of the sides for drainage/ventilation. They do like to get into the rolled-up sail. Often as I raise the sail, they'll come raining down on me. I just have to make sure my wife doesn't see them, or she wouldn't come near the boat.
What - Me Worry?
2006 Hobie Wave 7358 "Ish Kabibble"
[Re: fin.]
#138686 04/01/08 09:09 PM 04/01/08 09:09 PM |
Posts: 57 Minneapolis | the ants go marching one by one.....
Dave Foster Minneapolis Nacra F16
[Re: Mpls_Nacra]
#138687 04/02/08 07:42 AM 04/02/08 07:42 AM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | I'm trying to figure out how a kitten would get into an TheMightyHobie18 hull.......
I had a hornets' hive in my trailer tube when i bought the boat. I took the lid off and did a double take when I saw the hornets.....I ran faster than I've ever run in my life.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
[Re: brucat]
#138691 04/02/08 02:29 PM 04/02/08 02:29 PM |
Posts: 215 Ohio | Carpenter ants are mostly looking for moisture... so the wet cardboard was probably what they were after. They are a great study in random behavior on a massive scale in finding food/water. The scouts travel around laying a scent trail in random patterns around the main nest. When they find food or water, they immediately return to the nest. Eventually enough of them have returned from a consistent source of food or water to the nest to leave a strong trail for others to follow. That probably happened to your sail box and you have the ones that were just there temporarily drinking... kind of like sailors randomly sailing a windward-leeward course and ending up at the bar at night.
To eliminate them, you really must find the main nest. Probably in a nearby LIVE tree... they depend on the tree drawing moisture out of the ground and up the trunk for the nest to survive. If not a tree, find any constant supply of moisture... leaking pipes, downspouts into foundations, etc.
Mike, Ohio Former H16, H18, N20, N17, M4.3
20,946
guests, and 759
