Sail pulls out of slot in mast on Hobie Wave #139141
04/04/08 04:08 PM
04/04/08 04:08 PM
Turks and Caicos Islands
rumsailsman Offline OP
Has anyone experienced and had any success fixing a mast slot (sorry I don't know the terminology very well) that seems to be spread too wide at the top of the mast? Our club has 20 or so sails for our 5 Hobies Waves and one mast only always comes back in with the top of the sail hanging out about 2'. Any suggestions on a fix? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
You sailin' or bailin'?
Re: Sail pulls out of slot in mast on Hobie Wave [Re: rumsailsman] #139142
04/04/08 04:55 PM
04/04/08 04:55 PM
West Virginia
Soapysails Offline
Soapysails  Offline
West Virginia
Assuming you have confirmed the spacing in the slot to be wider at a given point,sail ropes are even and that no one has fooled with the appature,you may well have a factory blem.. that being the case, I would think the Hobie Corp. would be happy to replace that mast extrusion. Perhaps Rick White at Catsailor could better direct your efforts with Hobie.
Re: Sail pulls out of slot in mast on Hobie Wave [Re: rumsailsman] #139143
04/04/08 06:10 PM
04/04/08 06:10 PM
srm Offline
srm  Offline
Does the Wave have a short section of aluminum luff track at the top of the comptip like the larger Hobies? If the luff track is all plastic, it may be cracked and be spreading open when pressure is applied and thus letting the bolt rope pull out. You might try popping the luff track off the comptip and flipping it end for end.
sm
Re: Sail pulls out of slot in mast on Hobie Wave [Re: srm] #139144
04/04/08 07:26 PM
04/04/08 07:26 PM
brucat Offline
brucat  Offline
Matt Miller will hopefully chime in here...
I looked quickly at the Wave parts diagram on the www.hobiecat.com website, but there isn't a part number listed specifically for a comptip track for the Wave...
Re: Sail pulls out of slot in mast on Hobie Wave [Re: brucat] #139145
04/04/08 07:56 PM
04/04/08 07:56 PM
California
mmiller Offline
mmiller  Offline
California
A) Use the standard Hobie halyard system
B) Check the track for cracks
The track may be split, but the key is actually in the halyard hook system. If you bypass the halyard hook system and use a rope halyard that does not have the wire and swedge to lock in the hook up top... the sail will not be properly held in at the head. The leech loads will pull to heavily on the plastic luff track and the head can pull out as described.
The track replacement part is #38584001
Instructions are here: http://www.hobiecat.com/support/pdfs/38584001.pdf
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Sail pulls out of slot in mast on Hobie Wave [Re: mmiller] #139146
04/11/08 09:01 AM
04/11/08 09:01 AM
Thanks for all of your replies guys. Sorry for not getting back to you til now. I will do more investigation and research with your recommendations.
Happy sailing!
0 registered members (), 501 guests, and 631 spiders.
