Rating: 3
Hobie 14/16 Delamination picture #14053
12/12/02 09:27 AM
12/12/02 09:27 AM
Norfolk, VA
Dan Berger Offline OP
Norfolk, VA
If you ever wanted to know what is going on when a hull delaminates, this should shed some light.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14054
12/12/02 10:07 AM
12/12/02 10:07 AM
Cambridge MA
Marco Offline
Marco  Offline
Cambridge MA
That is interesting.Thank you Dan.
m.
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14055
12/12/02 10:56 AM
12/12/02 10:56 AM
Brighton, UK
grob Offline
grob  Offline
Brighton, UK
Dan,
You are a wealth of information!
Do you know what the two different layers are made from?
The inner layer looks fairly soft.
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14056
12/12/02 10:57 AM
12/12/02 10:57 AM
Norfolk, VA
Norfolk, VA
I meant to add a comment--I know many people are talking about injecting resin or something into the hull to bind the foam to the fiberglass, but the surfaces just don't seem to be able to be prepped well enough. In all the hulls that I have seen cut up (and it has been a few) the 'foam' does not seperate cleanly. There is a thin layer still attached to the fiberclass shell and there is a gritty or powdery residue all over the place between the layers. It seems to me that you really couldn't get a good bond between the two due to the unclean surfaces!
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14057
12/12/02 11:34 AM
12/12/02 11:34 AM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Thanks for the photos and information Dan.
Jack
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14058
12/12/02 02:03 PM
12/12/02 02:03 PM
catman Offline
catman  Offline
Injecting epoxy does work.....If you do it right and early.
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14059
12/12/02 03:00 PM
12/12/02 03:00 PM
deseely Offline
deseely  Offline
If a layer of foam is still attached to the fiberglass, then I would think that it is not an adheasion problem. I would guess that the shear stresses in the foam exceeded the strength of the foam and the dust is from the two surfaces rubbing together each time the skin flexes. This is only a guess but you test the idea by cutting out a strip from an area that is not seperated and bending it back and forth several times to see if it will cause a failure similar to what you see in the picture.
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14060
12/12/02 03:45 PM
12/12/02 03:45 PM
Maryland, USA
HoldenBeachin Offline
Maryland, USA
The delam shown in your pic is quite uniform along the upper surface. As you noted, this is not usually the case. When I cut my 6 inch deck port holes (to also allow me to repair the hull delam) on my H16, the foam had separated from the upper layer in some areas, and the inner layer in others. The inner glass weave was about 1/2 an inch lower than where it would have been if not damaged. (It looked like a 3D map of mountains and valleys). It would have taken a lot of epoxy to fill in all of the space between the layers!
Mark
1976 H16 sail #19857
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14061
12/13/02 07:21 AM
12/13/02 07:21 AM
The Netherlands (North West Eu...
RobLammerts Offline
RobLammerts  Offline
Hi Dan,
Please be advised that epoxy on polyester does not always work.
If my information is correct your hobie is made of polyester so use polyester.
See also the attachment we used polyester to repair an A-cat from a friend.
And that hull is currently looking brand-new.
The picture attached is when we took it apart to repair the top deck and some “studs?” inside.
Success
Rob Nacra 6.0 European version Nr 090 + Spi
Re: Hobie 14/16 Delamination picture [Re: RobLammerts] #14062
12/13/02 03:09 PM
12/13/02 03:09 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Re my successful repairs of seriously delaminated decks: you MUST remove just about all of the crumbled old brown foam from the underside of the top skin, and from the old foam surface too. If there little left of the stiff white polyurethane foam, replace the foam with new.
If the inner fiberglass cloth skin has fallen off too, the whole thing has to be replaced. Ick! This is what happens after years of sitting uncovered on the beach, full of water!
If so, can one 1. Bend the foam, 2. Epoxy cloth to the concave underside and get it to stick, 3. Glue it into the hole in the deck, 4. then put a new top skin on? Answer- Yeah, but it will (probably) look like a Goat's butt. Big job too.
Dacarls:
Re: Hobie 14/16 Delamination picture [Re: Dan Berger] #14063
12/14/02 01:55 AM
12/14/02 01:55 AM
Surf Offline
Surf  Offline
You should post this on the H16 forum as I think some of the H16 sailors there would be interested in this topic and pics.
0 registered members (), 503 guests, and 53 spiders.
