What to use to fill areas of compressed foam core? #140643
04/19/08 11:22 AM
04/19/08 11:22 AM
Lake Murray SC
FasterDamnit Offline OP
Lake Murray SC
What should I use to fill the spots on the 18HT hulls that are dimpled or compressed from the core collapsing? These hulls shave been bopping around in various storage places for years, and have quite a few small concave areas.
Thanks.
E-Scow
24' ULDB
Re: What to use to fill areas of compressed foam core? [Re: FasterDamnit] #140644
04/19/08 01:56 PM
04/19/08 01:56 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Low density epoxy filler [West microlight] would be my choice.
Re: What to use to fill areas of compressed foam core? [Re: TEAMVMG] #140645
04/19/08 03:07 PM
04/19/08 03:07 PM
Southern Ontario
fredsmith Offline
fredsmith  Offline
Southern Ontario
I watched some of A cat sailors use a hair dryer to take out the dimples on their Bims.You have to be very careful with the heat.If you could get in touch with Bob Hodges,he was very good at it,could explain the technique.
Re: What to use to fill areas of compressed foam c [Re: fredsmith] #140646
04/19/08 04:34 PM
04/19/08 04:34 PM
Lake Murray SC
Lake Murray SC
So you are forcing the foam to expand?
Re: What to use to fill areas of compressed foam c [Re: FasterDamnit] #140647
04/19/08 04:44 PM
04/19/08 04:44 PM
Southern Ontario
fredsmith Offline
fredsmith  Offline
Southern Ontario
yes that is the idea it will get out the minor dimples,large dings are fill and sand effort.
Re: What to use to fill areas of compressed foam c [Re: fredsmith] #140648
04/19/08 04:51 PM
04/19/08 04:51 PM
Lake Murray SC
Lake Murray SC
Have plenty of both. Thanks
Re: What to use to fill areas of compressed foam c [Re: FasterDamnit] #140649
04/19/08 05:07 PM
04/19/08 05:07 PM
The core of the HT is kinda hard to explain but it doesn't seem foam like. But then again, don't know for sure. It has the consistency of sawdust really... which I guess could be foam.
If the hair drier thing works.. Please let me know!
Re: What to use to fill areas of compressed foam c [Re: PTP] #140650
04/19/08 05:14 PM
04/19/08 05:14 PM
Southern Ontario
fredsmith Offline
fredsmith  Offline
Southern Ontario
be careful with the heat
Re: What to use to fill areas of compressed foam c [Re: FasterDamnit] #140651
04/19/08 07:46 PM
04/19/08 07:46 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Jim,
I would be very careful with heat, it might delaminate the skin from the core.
The HT has a gel coat finish, so, you could repair small dimples with more get coat. Gel coats a bit finicky to apply and needs to be sanded and polished smooth, but that would give good results if you did it right. Try a small area and see how it goes before you start on larger areas.
The core on the HT is foam, and I've heated foam, it can start to melt if you get it too hot, and I've melted it, or burned it rather with a heat gun.
Bill
Re: What to use to fill areas of compressed foam core? [Re: fredsmith] #140652
04/19/08 07:59 PM
04/19/08 07:59 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Fred,
Doesnt Bob have an a2? Thats nomex core. Are you sure he did it with a Bim?
A nomex core boat has little air pockets and a hair dryer might cause the air in the nomex cells to expand and the dimple to expand.
I dont see how this would work with foam, but if it works, thats a neat trick.
Bill
Re: What to use to fill areas of compressed foam c [Re: bvining] #140653
04/19/08 09:30 PM
04/19/08 09:30 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
I've actually done dent removal successfully with Bimare fiberglass products Bimm 2000, Javelin (and 18HT is the same)
1. I use my heat gun set on low, push the gun straight at the dent, then withdraw it.
2. Pass your other hand quickly over the surface of the dent to check its temperature.
3. If the surface gets a little too hot to keep your hand on, its the correct heating rate.
4. Repeat until the dent comes SLOWLY out: there is a delay to this, so take your time. About a minute per dent.
5. Do NOT pass the heat gun side to side, as you will swell the surface around the dent.
This works great. Newer Carbon boats I dunno.
Dacarls:
Re: What to use to fill areas of compressed foam c [Re: FasterDamnit] #140654
04/20/08 07:02 AM
04/20/08 07:02 AM
you CAN most certainly melt it!
Re: What to use to fill areas of compressed foam c [Re: Jake] #140655
04/20/08 04:07 PM
04/20/08 04:07 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Looks like a monkey's ash tray!
0 registered members (), 477 guests, and 37 spiders.
