| What to use to fill areas of compressed foam core? #140643 04/19/08 11:22 AM 04/19/08 11:22 AM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit OP
Posts: 531 Lake Murray SC | What should I use to fill the spots on the 18HT hulls that are dimpled or compressed from the core collapsing? These hulls shave been bopping around in various storage places for years, and have quite a few small concave areas.
Thanks.
E-Scow 24' ULDB
| | | Re: What to use to fill areas of compressed foam core?
[Re: FasterDamnit]
#140644 04/19/08 01:56 PM 04/19/08 01:56 PM |
Posts: 1,203 uk | Low density epoxy filler [West microlight] would be my choice.
[Re: FasterDamnit]
#140651 04/19/08 07:46 PM 04/19/08 07:46 PM |
Posts: 1,226 Atlanta | Jim, I would be very careful with heat, it might delaminate the skin from the core.
The HT has a gel coat finish, so, you could repair small dimples with more get coat. Gel coats a bit finicky to apply and needs to be sanded and polished smooth, but that would give good results if you did it right. Try a small area and see how it goes before you start on larger areas.
The core on the HT is foam, and I've heated foam, it can start to melt if you get it too hot, and I've melted it, or burned it rather with a heat gun.
Bill | | | Re: What to use to fill areas of compressed foam c
[Re: bvining]
#140653 04/19/08 09:30 PM 04/19/08 09:30 PM |
Posts: 805 Gainesville, FL 32607 USA | I've actually done dent removal successfully with Bimare fiberglass products Bimm 2000, Javelin (and 18HT is the same) 1. I use my heat gun set on low, push the gun straight at the dent, then withdraw it. 2. Pass your other hand quickly over the surface of the dent to check its temperature. 3. If the surface gets a little too hot to keep your hand on, its the correct heating rate. 4. Repeat until the dent comes SLOWLY out: there is a delay to this, so take your time. About a minute per dent. 5. Do NOT pass the heat gun side to side, as you will swell the surface around the dent. This works great. Newer Carbon boats I dunno.
#140655 04/20/08 04:07 PM 04/20/08 04:07 PM |
Posts: 1,203 uk | Looks like a monkey's ash tray!
875
guests, and 38
