4 years and counting #141094
04/23/08 08:27 PM
04/23/08 08:27 PM
Central Coast NSW Australia
TonyJ Offline OP
TonyJ  Offline OP
It was brought to my attention last week, that I started building 002 before I went off to Zandervort in May 2004.
This on again, off again project will get completed. Just not sure when.
Some progress shots.
The hull ready for the main deck.
Teach them how to think. Not what to think. Aus Blade 002
Re: 4 years and counting [Re: TonyJ] #141095
04/23/08 08:32 PM
04/23/08 08:32 PM
TonyJ Offline OP
TonyJ  Offline OP
Adding some SP335.
Nice & easy no mess.
Re: 4 years and counting [Re: TonyJ] #141096
04/23/08 08:36 PM
04/23/08 08:36 PM
TonyJ Offline OP
TonyJ  Offline OP
The deck on.
Its still over hanging, and needs planing back.
Some pallet strapping to help me hold it in place while screwing it down.
Re: 4 years and counting [Re: TonyJ] #141097
04/24/08 12:03 AM
04/24/08 12:03 AM
TonyJ Offline OP
TonyJ  Offline OP
Just weighed the hull on the freshly calibrated scales.
26.3 kgs
Re: 4 years and counting [Re: TonyJ] #141098
04/29/08 01:46 AM
04/29/08 01:46 AM
TonyJ Offline OP
TonyJ  Offline OP
It's a good feeling when you can see a little more progress.
I let it cure in the loft over the long weekend before I took the screws out yesterday and planned it back today.
Still needs the holes filled and a small amount of fairing.
Onto the next hull, for a change.
Re: 4 years and counting [Re: TonyJ] #141099
05/02/08 02:48 AM
05/02/08 02:48 AM
TonyJ Offline OP
TonyJ  Offline OP
Ahhhhh
I just love it when I can see some progress.
Possibly a week of filling and sanding, including some fairing of the keel I didn't finish.
Then the fore deck.
TJ
Re: 4 years and counting [Re: TonyJ] #141100
05/15/08 07:37 PM
05/15/08 07:37 PM
TonyJ Offline OP
TonyJ  Offline OP
A quick update.
I have been fairing and sanding madly. I am over it, but resigned to the fact that the bows still need some more of both. Plus once the fore decks go on, the finishing touches will need to be completed.
The sterns are complete as are the beam landings.
Iam still on track to have both hulls ready for paint by the end of May. [Linked Image]
Re: 4 years and counting [Re: TonyJ] #141101
05/17/08 12:30 AM
05/17/08 12:30 AM
Tornado_ALIVE Offline
Hi Tony,
So this is why we have not seen you on the water for so long.
Looking good and can't wait to see the final product on the water. Best of luck with it.
Stephen
Re: 4 years and counting [Re: Tornado_ALIVE] #141102
05/18/08 05:29 PM
05/18/08 05:29 PM
TonyJ Offline OP
TonyJ  Offline OP
Thanks Steve
I didn't plan on taking so long.
But I replaced sailing with a crusing motorcycle, and it just got away from me.
Looking forward to doing both next season.
Re: 4 years and counting [Re: TonyJ] #141103
05/19/08 02:10 AM
05/19/08 02:10 AM
TonyJ Offline OP
TonyJ  Offline OP
Hi Tech steaming.
http://H:\Blade\steams 001.jpg[/image]
I have tried to attach photo so you dont have to click on it.
I give up for now.
Re: 4 years and counting [Re: TonyJ] #141104
05/19/08 05:21 AM
05/19/08 05:21 AM
Marcus F16 Offline
Marcus F16  Offline
Did you really need to steam the decks in place.?
My memory must be fading, but I cant recall doing this on the 2 blades we built here in SA.!
Marcus Towell
Re: 4 years and counting [Re: Marcus F16] #141105
05/19/08 04:49 PM
05/19/08 04:49 PM
TonyJ Offline OP
TonyJ  Offline OP
Hi Marcus
I poured boiling water ovet the deck, lots of steam coming up. Each time I tightened up the ratchets just a litte.
Then put the pallet strapping on to tighted up the deck in between. Will leave in place for 3 days now. And work on the SB hull.
I weighed the hull with the ply on it. 25.85 kgs.
Re: 4 years and counting [Re: TonyJ] #141106
05/22/08 09:36 PM
05/22/08 09:36 PM
TonyJ Offline OP
TonyJ  Offline OP
Glued down 1 fore deck yesterday, thanks to Phill coming along and prodding me.
This photo shows the deck screwed down with over hangs, to be planned off next week. The block of foam on the nose will be glued down later and sanded (more sanding <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> )to the shape of the fore-deck.
I have allocated 4 more afternoons next week to work on the boat.
After that I have to get to know ny family again.
And spend 3 or 4 hours a week.
Revised date for ready for paint. End of June. [Linked Image]
Re: 4 days and counting [Re: TonyJ] #141107
05/26/08 05:16 PM
05/26/08 05:16 PM
TonyJ Offline OP
TonyJ  Offline OP
Up Date
Both fore-decks are glued down. Port hull screwed down. SB hull is roughly sanded. Ready for fairing( <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />)The foam blocks are glued to the bow as well. They need to be sanded to the shape of the fore-deck.
This afternoon I trim the port hull and an have it ready for fairing.
The count down is on to have it ready by Thursday afternoon. [Linked Image]
Re: 3 days and counting [Re: TonyJ] #141108
05/27/08 05:01 PM
05/27/08 05:01 PM
TonyJ Offline OP
TonyJ  Offline OP
The problem with tortured ply, is that there are a lot of highs and lows. That means lots of filling and sanding. To date I have applied 12kgs of filler and sanded off between 10 and 11 kgs of it.
What that shows me, is that Iam not very good at fairing. <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> Iam confident that I would have had a painted platform if I was better at fairing.
Any way this photo shows that it is getting very close. All the major work will be done by Thursday arvo.But on closer inspection, there is a lot of highs and lows that need to be addressed.
Re: 4 years and counting [Re: TonyJ] #141109
07/31/08 10:52 PM
07/31/08 10:52 PM
TonyJ Offline OP
TonyJ  Offline OP
Just a quick update.
Started working on boat again this week. Decks are partially glassed and looking good.
By the end of next week, should be ready for mounting beams.
So far I have collected a spinnaker kit, Main and jib, rudders and stocks, I already have centre boards.
I hope to have a broken carbon mast in my possesion soon, to see if it can be fixed.
Regards Tony
1 registered members (JesperS), 759 guests, and 38 spiders.
