| 1 or 2 Footstraps #141191 04/25/08 10:38 AM 04/25/08 10:38 AM |
Posts: 71 | I want to put footstraps on by Blade. Has anyone used 2 on each side of the boat, one at the very back and one behind the rear crossbar? Are they loose enough for shoes, a particular brand and style? Any photos would be nice.
Thanks,
Stephen Phoenix Az | | | Re: 1 or 2 Footstraps
[Re: Stephen]
#141192 04/25/08 10:42 AM 04/25/08 10:42 AM |
Posts: 6,049 Sebring, Florida. | I use the DaKine windsurfing footstraps available at most cat or windsufring shops or maybe here in the online store. I only use one, at the back, but I race alone most of the time. They are adjustable and you can fit a foot in there while wearing booties.
It would have been nice to have another one for crew on the really windy days though, but going upwind the crew is further forward so I don't know how you would get to the inside of the hull to back the screws.
Blade F16 #777
[Re: Stephen]
#141193 04/27/08 07:30 PM 04/27/08 07:30 PM |
Posts: 1,121 Eastern NC, USA | One should be good. Put the aft end of the strap on the transom (where it turns vertical) - all the way back. P
Tom | | | Re: 1 or 2 Footstraps
[Re: tshan]
#141194 04/27/08 07:50 PM 04/27/08 07:50 PM | Anonymous
| Anonymous
Unregistered | What's involved in actually fitting these things? | | | Re: 1 or 2 Footstraps
[Re: ]
#141195 04/27/08 08:17 PM 04/27/08 08:17 PM |
Posts: 6,049 Sebring, Florida. | I just measured my foot in bootie, marked the hull with a pencil and drilled the two 1/4 in. holes for the stainless steel screws. I put large (1") fender washers on the inside of the hull for support of the lock nut on the back side and a smaller washer on the outside to support the strap. My straps are velcro adjustable. I also put some silicon goop in and around the holes under the straps to prevent leaks.
Blade F16 #777
[Re: Timbo]
#141196 04/28/08 04:23 AM 04/28/08 04:23 AM |
Posts: 2,584 +31NL | These footstraps is what most Tigers get fitted with in Europe: Magic Marine Light footstrapAdvantage is that it allows you to just put your toes in instead of your whole foot. | | | Re: 1 or 2 Footstraps
[Re: Timbo]
#141197 04/28/08 07:35 PM 04/28/08 07:35 PM |
Posts: 1,152 tampa, fl | To mount footstraps on the hull of my I20, I cut 1" square pieces out of a 3" diameter piece of PVC pipe and used that as backing for the bolt instead of flat washers (last time I checked, the inside of my hull was not flat). I superglued a piece of bicycle innertube to the piece of PVC and applied silicone to that. The footstap connections are strong enough to lift the stern of the boat with (I would not try that with just washers, and it does not leak a drop.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | |
389
guests, and 55
