Hi Thom
I'm a S C fan also and have a S C 15 the kids and I sail on the lake , along with other cat racing .
The idea of taking S C 20 hulls and building a Formula 20 type cat that any could race in a large fleet of spin rigged 20s really appeals to me and sure many others .The wonderfull folks at Aquarious Sails are the only ones I know of currently that would build a boat to customer specs in a number of variations on its design ,with really excellent quality .
But , ---the actual across the line finish is listed from the T B site for the S C places it 10TH across the line ,--approx 25 minutes behind the T-sailed by Robbie . The S C 20 -tall rig version being sailed with 12 ft beam certainly has the same speed potential as the T .The sailors on it this time are some of the best and were 3rd near the start but must have encountered course or tactical nav problems to drop back to 10th.
Because this cat is seldom raced it is given a very favorable handicap advantage under P-rating, that seems unrealistic again given this boats larger mast sails and beam .-The handicap moves it from 10th to 3rd ,--go figure ?
Another example of how P rating breaks down as applied to distance racing it was never intended for .
Also scoring spin and non spin boats together in distances where spin may or may not be used is completely invalid.
-We need to race boats in classes as a truer test of sailing skill. Add a handicap rating system for added overall for fun ,--but lets revise this system for distance racing and get it right ,
There are 2 other systems used with great success at major races around the globe ,-one with 600 boat starts .
Here is a copy from the I S A F handicap web site for cats -
-Whilst it is accepted that the ideal Rating system is one which uses historical results, a Portsmouth Yardstick type system, it has proved difficult to obtain sufficient data to validate such a system around the World. The SCHRS enables new designs to be rated quickly, and allows International regattas to take place with a common handicapping system for many types of Catamaran.
It is recognized that one-design and level rating are generally a more realistic test of sailing skill. For events organised under these regulations, organizing authorities may consider separate arrangements for one-design or level rating classes present in sufficient numbers.
end ISAF -
http://www.schrs.com/ -Lets score boats by class ,-and lets objectively compare and perfect the rating system for distance racing in N A
question -has anyone adjusted the numeric scale between P-rating and ISAF rating ,-.so any could compare these different rating systems at a glance based on similar numbers, there are similar spreads between the extremes ,-from waves to T .
The different rating systems use different calcs. and different points of beginning -Finding consistant commonalities between the 2 would be the basis then a numeric scale could be adjusted to one or the other for direct comparison . A few recalcs of N A version boats is also needed but minor differences ,-more and more boats are commonly sailed with Formula type classes emerging .
Racing with classes as priority is needed for results to have any real meaning . Add a handicap overall if needed ,but call it what it really is ,and do not confuse it with actual or real results .
Silly people keep attacking others personally when they draw attention to these realities and problems of rated racing .
No one has all the answers ,-but lets learn grow and keep trying to improve in all aspects of this great sport .
-We will get there .
Happy Holidays
Carl
-edit added ---actual Sat race finishes
unofficial Steeplechase boat finishes --actual -
Robbie Daniel - Tornado
Matt Struble - F18HT - 7:45 back
Tommy Bahama - I-20 - 9:57 back
Team Tybee - I-20 - 14:40 back
John Casey - I-20 - 15:27 back
Rick Bliss - Nacra 6.0 - 20:12 back
Richard Feeney - Nacra 6.0 - 22:20 back
Dan Lawrence - Nacra 6.0
Kirk Newkirk - I-20
Eric Roberts - Supercat
Dave Ingram - I-20
Rick Loewen - I-20
Clive Mayo - Nacra 6.0
Nacra 6.0
#112 - Nacra 6.0
#30 - Nacra 6.0 Express
146 Nacra 6.0
Brian Lambert - F18 HT
Nacra 6.0
Mark Lavine - I-20
Brian Carr - I-20
John McGlocklin - I-20
Jay Roth - I-20
Dave White - Nacra 6.0
Loyd Barry - Hobie 21
Terry Green I-18
Todd Hart - I-20
Chris Runge - I-20
Mike Krantz - F18 HT
Prindle 19 MX
Boog Newkirk - I-18
Mark Hernendene - I-20
#274 Nacra 6
