| Re: Brainstorming help please PICTURE HOLDER
[Re: grob]
#141801 05/06/08 10:22 AM 05/06/08 10:22 AM |
Joined: Jul 2001 Posts: 851 US Western Continental Shelf hobiegary OP
Posts: 851 US Western Continental Shelf | Nice idea. I presume that the tiny "nub" on the back of my Garmin Etrex Legend is a gortex covered hole. As you are brainstorming, and I have no idea if this would work, but how about covering a hole with a waterproof breathable material like Goretex?
Gareth
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Brainstorming help please
[Re: Keith]
#141802 05/06/08 10:52 AM 05/06/08 10:52 AM |
Posts: 1,307 Asuncion, Paraguay | This inexpensive homemade valve can be used to relief compressed air from a hull. I guess it is easy to modify for your specific purpose. This is what is done on the floats (amas) of Corsairs/F-boats. My F-27 has one on each float near the front beam. I have one per watertight compartment per float, six in total.
Luiz
[Re: hobiegary]
#141803 05/06/08 11:13 AM 05/06/08 11:13 AM |
Posts: 1,200 Vancouver, BC | I think you'd be better off with the larger/higher flow rate (~150 cc/min) unit: TA242-1 A hull has an awful lot of volume in it and the mini valves are really designed for small electronic-type enclosures. I found these a while back when looking for solutions for my centerboard & rudder vents. The Marstrom blades are hollow (not foam cored) and have tiny holes in them that I need to remember to tape off. It is just another thing to forget and I frequently did (still do!). Ultimately decided against the breather vavles...didn't want the protruding bits sitting where the current holes are...interfered with blade pivoting.
[Re: Tornado]
#141804 05/07/08 01:40 PM 05/07/08 01:40 PM |
Posts: 15 SE Utah | Will be sailing at 4000 feet in cold water, then trailering back up to house at 7400+. This keeps me busy with the plugs. When you guys try some of these valves, please post the results.
Pearson Ensign, Hobie 16, Hobie Bravo and a stack of sailboards
[Re: CHAS]
#141805 05/07/08 01:47 PM 05/07/08 01:47 PM |
Posts: 6,049 Sebring, Florida. | Why not just install the standard 1" drain plugs on the transoms?
Blade F16 #777
[Re: Timbo]
#141806 05/07/08 01:57 PM 05/07/08 01:57 PM |
Posts: 12,310 South Carolina | My Boyer a-cat has a small pin hole just under the top rudder gudgeon for pressure equalization...but then again, I don't plan on crossing any oceans with it.
Jake Kohl | | | Re: Brainstorming help please
#141807 05/07/08 03:25 PM 05/07/08 03:25 PM |
Posts: 851 US Western Continental Shelf | In case anyone is wondering which direction I've headed: After looking at all the ideas we've generated, I've decided to go with my original plan of drilling a hole and using duct tape if I want it covered. Since duct tape was invented for waterproofness reference, the history of *DUCK* tape that's good enough for me. I don't really expect that I'll need to cover the hole, but may do it on long outings, only after the hulls have have cooled. (my water temperature average is somewhere in the neighborhood of 60ºF) I've drilled and refilled a 1/8" hole and will re-drill with 1/32". Not sure if I'll get enough flow through there; tests will tell. If not, I'll go with something larger. If I have to go larger than 3/8", then I'll probably just mount a standard drain hole, high on the transom. (probably the windsurfer type that was mentioned early in the thread) Test reports will follow, in time. GARY
[Re: hobiegary]
#141808 05/08/08 11:42 AM 05/08/08 11:42 AM |
Posts: 1,200 Vancouver, BC | Recommend against regular duct tape...it falls apart rather quickly and leave an nasty sticky mess. 3M now sells an much better outdoor clear duct tape...has reinforcing fibre, holds up for months at a time and comes off without the mess.
I use it in many places on my boat...especially for the sharp edges on the mast hounds/shackles where the spinny might contact.
[Re: hobiegary]
#141809 05/08/08 12:57 PM 05/08/08 12:57 PM |
Posts: 12,310 South Carolina | In case anyone is wondering which direction I've headed: After looking at all the ideas we've generated, I've decided to go with my original plan of drilling a hole and using duct tape if I want it covered. Since duct tape was invented for waterproofness reference, the history of *DUCK* tape that's good enough for me. I don't really expect that I'll need to cover the hole, but may do it on long outings, only after the hulls have have cooled. (my water temperature average is somewhere in the neighborhood of 60ºF) I've drilled and refilled a 1/8" hole and will re-drill with 1/32". Not sure if I'll get enough flow through there; tests will tell. If not, I'll go with something larger. If I have to go larger than 3/8", then I'll probably just mount a standard drain hole, high on the transom. (probably the windsurfer type that was mentioned early in the thread) Test reports will follow, in time. GARY That will be plenty large enough.
Jake Kohl | | |
2,526
guests, and 167
