Page 3 of 4 1 2 3 4
Re: rules again [Re: ] #141977
05/05/08 10:45 AM
05/05/08 10:45 AM
Cough cough, Jake explained what I was saying in much better detail quoting the rules.
Dont pay much attention to me, what do I know? I mean after all Murphy has been sailing 15+ yrs. LMAO!
Re: rules again [Re: scooby_simon] #141978
05/05/08 10:47 AM
05/05/08 10:47 AM
Murphy.
That being said, Murph you OWE the ROW its two boat lengths. If its an F16 you must give 32ft of room. If its an I20 that would be 40ft.
Where does that come from?; You do not have to give them the length of the boat x 2 to round.
If the ROW boat, chooses to use the TWO BOAT LENGTH zone he can use it to his advantage, making a tactical mark rounding.
Re: rules again [Re: Robi] #141979
05/05/08 11:43 AM
05/05/08 11:43 AM
Don't confuse me with the facts, my mind is made up. Here is some interesting reading from the ISAF
CASE 84
Rule 18.1 Rounding and Passing Marks and Obstructions: When this Rule Applies.
Discussion of the phrase ‘about to round or pass’, room
Question:
When is a boat ‘about to round or pass’ a mark within the meaning of rule 18.1?
Answer:
The phrase ‘about to round or pass’ has never been defined precisely, nor can it be. In approaching a mark, there is no exact point at which a boat become ‘about to round or pass’ it. Almost always a boat two hull lengths from a mark is ‘about to round or pass’ it, but this is sometimes so at a greater distance too. Not only is the distance from the mark a factor, but the boat’s speed is also important, and other factors such as the conditions of wind and current an the amount of sail handling required before or during the rounding may also be relevant. Moreover the nearer the boat is to the mark the more definitely she is ‘about to round or pass’it. The answer to the question depends upon the particular circumstances of each situation.
Regards
Chet
Re: rules again [Re: Robi] #141980
05/05/08 12:12 PM
05/05/08 12:12 PM
Murphy.
There is nothing in the current rule-set that specifies how much room the inside boat is permitted. It DOES provide definition for the diameter of the "2 length" circle in which several of the rounding rules come into play - but "room" to round a mark is exactly that with no additional dimension.
Re: rules again [Re: Jake] #141981
05/05/08 12:14 PM
05/05/08 12:14 PM
and oh yeah - the current 2005-2008 rules/prescriptions are pretty close to being replaced!
Re: rules again [Re: ] #141982
05/05/08 12:16 PM
05/05/08 12:16 PM
brucat Offline
brucat  Offline
I find it hard to believe you hot shots are unaware that the 2 boat length circle is frequently bigger.
Flame on
aa
Hey Chet,
Not sure of your point here. Do you mean the SIs allow it to be bigger, or that people's perception on the water makes it bigger than it really is?
I have personally seen SIs that use 3 lengths, but nothing more. Not saying it's a bad idea, just haven't seen more than 3 lengths used. However, it is extremely rare, in the northeast US at least, to use anything other than the standard 2 lengths.
I also think people tend to exaggerate the size of the cirle depending on their viewpoint at the time of the incident, so I'm not sure if it would actually help to open it up.
Re: rules again [Re: Jake] #141983
05/05/08 12:19 PM
05/05/08 12:19 PM
brucat Offline
brucat  Offline
That's true, and it was true at the time of the seminar I referenced. However, the interpretation of the applicable rules basically works out that if you're an inside ROW boat (starboard), you can take a tactical rounding.
Still, I haven't heard from any spin boat hotshots whether they would attempt this maneuver in 18+ knots of wind.
Re: rules again [Re: Robi] #141984
05/05/08 12:56 PM
05/05/08 12:56 PM
Murphy.
But that is nothing to do with the room requited TO ROUND THE MARK.
Re: rules again [Re: scooby_simon] #141985
05/05/08 03:34 PM
05/05/08 03:34 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Yah, I know you guys think I'm an IDIOT ...just because I'm not computer literate doesn't mean I do not know the rules ...
Read "Jakes" Post carefully about layline!!!! I think he proved my point.
First; by coming in "above the mark outside the 2 Boatlength circle you simplify the situation to a Port-Starb crossing ... the boat on "port" has NO rights and MUST stay clear. Agreed???
Secondly; After you jybe you will be able to come into the mark "powered up" ... under controll ... and make a nice rounding of turning 270degrees, effectively slingshoting around the mark ... exiting with alot of speed!!!
Know remember what "Jake" posted about the layline ... so let look at the "coming in ON the starboard layline"
First; you come screaming in yelling at the top of your lungs and speeding along physically ... do you really think that you can "douse the spin" and round the mark inside the 2 boatlength circle??? Most likely your speed will carry you well beyond the circle, especially if there is any wind at all!!!
Secondly; you will be trying to make a 360 degree turn ... all at once ... my 25+ years of catamaran racing experience tells me that is really SLOW!!!! You are trying to do TWO manuevers at once ... I find that with my "mear mortal and limited brain power" I am much better if I concentrate on one thing at a time and do it well! How about you guys ... are you guys that good???
How about failure to avoid the collision clause in the "Racing Rules" ... yes you where on Starboard w/ an inside overlapbut does that give you the right to come in "out of controll" ...drive over the layline ... forcing boats who are with-in the 2 boatlength circle to drive off ... maybe ... maybe not ... We quickly get back to the definition of a technical/seamanship rounding of a Mark ... I personally wouldn't want to take the "Starboard boat's position to a "Protest Hearing" especially if there is boat damage!
So if I'm the port boat what would I do ... I'm most likely going to slow down and let your speed carry you past the mark ... next when you attempt the "hard turn" I will "heat my boat up, duck your sterns ... feeding you a BIG knuckle of dirt air to boot ... slowing you down even further ... sling-shot the rounding, leaving you in the dust ... And if anyone is on my sterns they mostlikely will do the same your are now on the outside eating "dirty air as the train of boats leaves you behind ... hows that sound
When I started racing ... no flag ... no protest allowed! The first question you were asked was "Did you display your flag?" And I saw some racers who would take advantage of boats w/ out flags, fouling them knowing full well they couldn't be protested!!! So to this day I still have my flag slung under my boom in a tube ... ready for use ... And I have only used it once ... in all the races I have sailed!!!
Harry
PS: the name is MURPHEY ... if you are going to call me an idiot at least get my name correct
Re: rules again [Re: HMurphey] #141986
05/05/08 04:12 PM
05/05/08 04:12 PM
fin. Offline OP
fin.  Offline OP
Jeez! Calm down dude. Nobody was screaming, there was no collision. Just some friends enjoying a nice day on the water.
For the record, our A cat fleet has some new saiors and we (the tail end of the F16 fleet) are starting to pick some of those new guys off!
Re: rules again [Re: HMurphey] #141987
05/05/08 04:52 PM
05/05/08 04:52 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Harry
I am having trouble with your turns. I am guessing that when you state a 270 degree turn you are actually just heading up from a broad reach to a beat. This would be 90 degrees. A boat enters on port and leaves on port. And the 360 degree turn you refer to is actually 180. A boat entering on starboard and leaving on port. 360 would put you back on the heading you started at.
A 270 degree turn would be entering the mark zone on starboard, gybing over to port and then tacking onto starboard, all while circling the mark.
Are there catsailors with the nads to sail on starboard back into the fleet of down-winding port-tacking spin-boats?
Something about right, dead-right?
Re: rules again [Re: bobcat] #141988
05/05/08 06:02 PM
05/05/08 06:02 PM
brucat Offline
brucat  Offline
This isn't directed at anyone specific, and isn't a rant (just something to consider), so everyone please remain calm...
One thing I have witnessed, especially in light air, is that some spin boat sailors don't / can't appreciate how slow the H16s, 17s, and 18s are, and come in "hot" with nowhere to go. The reason is, we're drifting down to the mark, while the spin boats are cruising. They figure we'll be long gone, but they are so much faster, we're still bobbing around just trying to get there. And if the air is light enough, depending on the positioning of the boats, sometimes we CAN'T get out of the way in time to give you room.
Frustrating for everyone...
Re: rules again [Re: HMurphey] #141989
05/05/08 08:07 PM
05/05/08 08:07 PM
Harry
Murphy, ever since that infamous day rounding Cape Canaveral when two teams went inside the no-go buoys around the launch pad, and the protest was tossed because the protesting team didn't fly a flag and the N20 was 2 inches too long to fall within the new "no protest flag required rule" even though the facts were found that the teams didn't sail the proper course and sailed a short-cut that the race committee could have and should have protested the sailors on....I too carry a protest flag every race....but that's another story!
With regards to the c-mark rights a port boat has over a starboard boat; If you are on port at a rounding and have contact with a starboard boat at the mark, port is at fault and will be tossed. I've studied this quite a bit and in almost every historical precedent I've read, the starboard boat actually loses the protest unless there was contact. The tricky thing to prove is that the port boat did not give enough room to round the mark - only if there was a collision was it evident that the port boat did not yield enough room and port is at fault. Port is really the only one in this scenario with any course options since starboard is committed to passing between the port boat and the mark (with rights). It's a strange scenario, yes...but it's how this rule plays out historically.
A starboard boat can physically gybe-douse around a mark. It's a little tricky to do cleanly but it can be done. It's almost a certainty that the door will be left wide open for the port boat to round close and get the windward advantage in this scenario - so although port has no rights in this situation, there is an option to regain the tactical advantage if the maneuver is timed correctly. If starboard blows the rounding and sails past the layline, the correct action is not to hit them, but to protest them (if it's even worth it after the advantage you just gained on them).
Re: rules again [Re: Jake] #141990
05/05/08 09:58 PM
05/05/08 09:58 PM
HMurphey Offline
HMurphey  Offline
Maybe I should qualify my opinion alittle
1) I will not get or cause anyone else to be HURT/INJURED through my actions or inactions
2) I will not cause damage to another persons boat through my actions or inactions.
3) I try not to put myself in situations where someone else defines the undefined rules/measurements ie: how much room is required to round a mark in a seamanly manner... their definition could and mostlikely is different from mine.
The scenerio I see here is not the port boat hitting the starboard boat but the opposite ... The starboard boat coming in too hot ... ON the starboard layline ( or even below - super hot) ... screwing up the rounding ... going 2-3 boatlengths past the mark ... then T-Boning the port tack boat!!!! At the protest hearing saying ... "but I was on Starboard !!!" At our closing speeds someone can be hurt if there is a collision ....
So I sail a little more conservately ... for me winning isn't worth it if someone gets hurt
These are my rules ... I try to keep racing on a FUN level and not get too "amped up".
I also have a voice that if I "hail" someone at the leeward mark people turn around at the windward mark and go "What's Harry yelling about"
Also if you are running the starboard layline w/spin and boats have rounded in front of you and are now beating upwind on port you can have a head on collision if a puff hits and the spin boat drives off the wind ... Now lets say one of the boats beating upwind decided to tack onto starboard ... both are now on the same tack ... most likely the spin boat will not see the boat starting to cross below the them ... now we have an upwind-downwind/same tack scenerio ...
I just see too many dangers/red flags to justify sailing the Starboard layline ... and "pushing" the rules to the extreme. And if you are ON the starboard layline can you really make a proper technical rounding???
Now if you are sailing in a fleet of VERY good sailors and are good enough to douse/round in 1-2 boats lengths .... have at it ... I'm just not that good (Wouter ... Rolf ... Scooby Simon ... Robbie Daniels, all those gentlemen are ... I'm a pragmatist/realist and a mear mortal )
Harry
Re: rules again [Re: HMurphey] #141991
05/05/08 10:15 PM
05/05/08 10:15 PM
Harry
Harry awesome post man. Good riddens.
BUT with all do respect to you and the names you mentioned; after sailing this last weekend with Robbie Daniels I honestly do not think the fellas mentioned in the same sentence are in the same league. No doubt each is great in there own style of sailing, but Robbie Daniels is in a league of his own. He is #2 to represent the US in the Olympics on the Tornado. That being said IMO he is a step above us all mear mortals.
Re: rules again [Re: Robi] #141992
05/06/08 12:07 AM
05/06/08 12:07 AM
HMurphey Offline
HMurphey  Offline
Yah, I've known Robbie since he was sailing a H21 and had hair!!! He is a gentleman and has always taken the time to educate me on the finer points of catamaran sailing. Ask him about our mutual friend Mr Glenn Ross ... who was my sailing partner until he became too good and bought a Mystere 5.5 from Robbie and Jill ... then he crewed with Robbie on the Tornado ...
It's been awhile since Robbie has come up to the Chesapeak and gave us some lessons ... Mark Schnieder, myself and all the other CRAC members would like to see him!!! The yacht club I belong to, Rock Hall YC is hosting an Regetta on June 21st and 22nd ... we have (4) F16's committed to coming, among them Mr Ed Mills and Mr John "Hollywood" McLaughlin. We would be estatic if the F16's "made class", please pass on my personal invitation for him to come and attend ... We could ask Constantine to lend him his Tiepan as Constantine will be unable to attend... And he could surprise Glenn ...
Harry
Re: rules again [Re: HMurphey] #141993
05/06/08 12:26 AM
05/06/08 12:26 AM
HMurphey Offline
HMurphey  Offline
Yah, it's time for Robbie to see Glenn ... please tell him that for me ... It's time ...
Harry
Re: rules again [Re: HMurphey] #141994
05/06/08 01:45 AM
05/06/08 01:45 AM
Neither Wouter or I have posted our opinions on the topic, so I dont see why we are used as an argument. That is unless you are making a point here.
On the Tornado you dont have time to douse within the two boatlength circle unless you are there alone in weak winds and coming in deep. Even then it would be hard to make a good rounding. Staying out of trouble is fast, and the best sailors stay out of troubly by being around the marks first. That is my experience. (But even then they are sometimes run down by other boats coming in after them)
Interesting how much room there is for discussion and interpretions on the racing rules of sailing.
Re: rules again [Re: Rolf_Nilsen] #141995
05/06/08 06:33 AM
05/06/08 06:33 AM
HMurphey Offline
HMurphey  Offline
Rolf,
I'm sorry if I offended you (or Wouter) Robbie is the finest sailor I know and that is not just because he is 2nd on the Tornado here in the USA... he is smart ... kind ... talented and a gentleman ... as are you.
If "mear mortals" like me and others try to sail too your level the most likely result will be us screwing up and getting someone else hurt! That is my point.
Though I have never had the pleasure of competing against Wouter and you, I look forward to the day I can meet Wouter and you, and shake your hand, sir.
Your admirer and friend,
Harry Murphey
PS: you can build your own F16, can't you??? What plans would you recommend?
Re: rules again [Re: Rolf_Nilsen] #141996
05/06/08 07:12 AM
05/06/08 07:12 AM
The spin boat wouldn't be dousing within the 2 length circle. The douse would have started much earlier than that and, if timed properly, would be finishing up as the boat gybes. You can make a decent rounding gybing around the mark (or within one boat-length of the mark) but it takes some coordination and practice. Spin up or down makes no difference to the rules situation.
I use this maneuver quite often to try and hold an advantage and it usually works if the gybe-douse is clean.
Page 3 of 4 1 2 3 4
