| Re: Hobie bob mast float
[Re: Mary]
#14192 01/31/05 03:40 PM 01/31/05 03:40 PM |
Posts: 851 US Western Continental Shelf | Whoops, I should have said "winglet" rather than "canard." I was refering to the winglets used at the tips of wings to reduce drag that is induced by a wing tip vortex. "grin" Triangular Mast Head Float? But I guess that the location of the masthead bobber is too far from the leech of a square top sail to be used as a winglet. GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Hobie bob mast float
[Re: hobiegary]
#14195 01/31/05 05:27 PM 01/31/05 05:27 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Whoops, I should have said "winglet" rather than "canard." I was refering to the winglets used at the tips of wings to reduce drag that is induced by a wing tip vortex. That's kind of what I thought you meant. Somebody just recently was telling me that Suicide sailors at one time were using endplates on the tops of their masts to reduce vortex drag at the top of the sail (or something like that). But it did not seem to do anything to improve performance, so they stopped using them. | | | Re: Hobie bob mast float
[Re: Mary]
#14196 02/01/05 03:02 PM 02/01/05 03:02 PM |
Posts: 829 Charleston, SC | The key to not turtling, though, is to seal the mast. Back in the day (like 6 years ago), I had a Hobie 16 that had met a power line in a storm. The line burnt a hole in the mast, maybe a 1.5 inches in diameter. Everytime the boat would flip, we'd have to get on the righting line immediately, or the boat would turtle in no time because the mast would fill up with water. I sold the boat shortly after, so no longer my problem. Anyway, I have an I-20, and the mast is sealed, and it takes it awhile to turtle. I can also solo-right the boat. I have a hobie-bob sitting around, but I'm never gonna use it...it just looks so amateur. I understand if you are a beginner that you need the peace of mind it provides, but once you've learned to right the boat even if turtled, then you've got it.
Trey
[Re: NCSUtrey]
#14197 02/01/05 03:18 PM 02/01/05 03:18 PM |
Joined: Apr 2002 Posts: 349 Fort Loramie, Ohio jmhoying
Posts: 349 Fort Loramie, Ohio | I have a hobie-bob sitting around, but I'm never gonna use it...it just looks so amateur. I understand if you are a beginner that you need the peace of mind it provides, but once you've learned to right the boat even if turtled, then you've got it. You have to realize that not everyone sails in 30' deep water. Driving you mast and sails into the bottom is a little hard on equipment. You are correct that a sealed mast is important, but for some of us that sail on shallow waters, a mast float is good insurance. Probably not a "must have" but I'm glad I have it. Jack - proud to be "so amateur" looking Fort Loramie, Ohio P18 with Prindle Bob
Jack Hoying
Fort Loramie, Ohio
[Re: Dean]
#14200 02/01/05 05:33 PM 02/01/05 05:33 PM |
Posts: 805 Gainesville, FL 32607 USA | I am here reminded that the Rave trimarans came without their masts being sealed, allowing rather discomforting pitchpoling. I personally rescued several of them at an important regatta. Even more disconcerting was the cavalier attitude of some owners toward mast sealing beforehand, as they stated that it was neither important nor necessary. I say it was and is. There is so much stuff hanging off a Rave, why would it need a drogue?
[Re: Dean]
#14201 02/01/05 05:36 PM 02/01/05 05:36 PM |
Posts: 12,310 South Carolina | I had a friend of mine that got stuck for a couple of hours turtled on a Viper 21 (21' sport monohull) off Hilton Head. He had to wait until a powerboat would help them pull the boat back on it's side. By then the keel-stepped mast had warbled a big hole in the top of the deck. A little later while cranking up the keel in preparation for putting it on the trailer, the eye pulled out of the top of the keel and it went straight to the bottom.  We later talked about how he might have had some luck by hoisting a couple of life vests or the throwables he had on board up the spinnaker halyard...hindsight is 20/20.
Jake Kohl | | | Re: Hobie bob mast float
[Re: dacarls]
#14202 02/01/05 05:38 PM 02/01/05 05:38 PM |
Posts: 12,310 South Carolina | With the kind of beam on those Raves, do the masts have a chance of keeping the boat from going turtle?
#14203 02/01/05 05:49 PM 02/01/05 05:49 PM |
Posts: 805 Gainesville, FL 32607 USA | Raves go over frontwards-- from flying out of the water at speed if altitude is poorly controlled, then coming down nose first. Result is a rapid, acute dive, as the inverted T-foils hit first and present a negative angle of attack while still going fast. The center hull fills immediately, stern is straight up.
[Re: dacarls]
#14204 02/01/05 06:03 PM 02/01/05 06:03 PM |
Posts: 12,310 South Carolina | OK....but do they stay there (whether it be on it's nose or on it's side) or do they turtle naturally?
[Re: samevans]
#14206 02/01/05 07:46 PM 02/01/05 07:46 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Sam, I wasn't comparing a bob to a bicycle helmet. It was just to illustrate that in both cases some non-users think of users as wimps. I don't think it is good to discourage people from using safety features by saying it makes them look like amateurs.
If you had seen as many boats turtling, many instantaneously, as I have over the past 16 years, maybe you would feel differently -- especially, as I said, if you are taking children or grandchildren out on your boat. | | | Re: Hobie bob mast float
[Re: Brian_Mc]
#14208 02/02/05 08:56 AM 02/02/05 08:56 AM |
Posts: 12,310 South Carolina | Hey, Don't drag me into this - I have nothing against the Hobie Bob...it's just that his brother 'Bill' up there looks kind of funny.  Usually the first thing I do when we capsize is to make sure neither of us is under the sails and mast, then check to make sure nobody sustained any injuries, and then try to keep the boat from going turtle. So far, the F18 has prooven very resistant to turtling even without a Bob or Bill.
[Re: Andinista]
#14211 02/02/05 10:37 AM 02/02/05 10:37 AM |
Posts: 324 South Florida | What a silly statement to say that having a Bob on your mast looks amateur. It's a safety device!!
I'm sure there are still people out there that think wearing personal flotation devices look amateur.
I'd say if you feel "amateur" because of a Bob you're probably a moron anyway and should stick to land. Did the guy who said this also say his mast met power lines in a storm?????!!!!!!
I rest my case.
Fred F
(ex Hobie 18)
18,330
guests, and 871
