How to remove mold from white sails? #142081
05/04/08 10:38 PM
05/04/08 10:38 PM
Louisiana
Scubajeep Offline OP
Louisiana
So, what is the best way to remove mold from white sails? I was thinking of a little Dawn (dish washing soap) and a soft brush?
Thanks
Todd H
Thibodaux, Louisiana
Sailing a 1980 Hobie-18M with 1990 hulls in Southern Louisiana.
Re: How to remove mold from white sails? [Re: Scubajeep] #142082
05/05/08 12:09 AM
05/05/08 12:09 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Try Oxyclean. (SodiumPerborate)
Santa Monica Bay
Re: How to remove mold from white sails? [Re: Scubajeep] #142083
05/05/08 07:57 AM
05/05/08 07:57 AM
soak them in someone's pool overnight - the chlorine will get it. (find a chlorinated pool - not one of the new fangled salt water filtration systems)
Re: How to remove mold from white sails? [Re: Jake] #142084
05/05/08 08:23 AM
05/05/08 08:23 AM
Louisiana
Louisiana
Jake, Would the chlorine hurt the material?
Todd
Re: How to remove mold from white sails? [Re: Jake] #142085
05/05/08 08:31 AM
05/05/08 08:31 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Hijack alert.....the new fangled salt water systems are actually chlorine generators that convert NaCl (table salt) to NaHCl (chlorine) through an electrolysis process. The end result in the pool is the same as a pool that has chlorine added to it. Damn....I have worked in the aquatics industry for faaar too long.
Re: How to remove mold from white sails? [Re: Jake] #142086
05/05/08 09:25 AM
05/05/08 09:25 AM
Lakewood, Colorado
MUST429 Offline
MUST429  Offline
Lakewood, Colorado
Hopefully withOUT getting arrested.......
Life is not about waiting for the storms to pass...
It's about learning to dance in the rain
Re: How to remove mold from white sails? [Re: MUST429] #142087
05/05/08 12:42 PM
05/05/08 12:42 PM
Ft Myers Beach, FL
walkefmb Offline
walkefmb  Offline
Ft Myers Beach, FL
take out the battens
cedar tornado classic,
sunfish,
1972 morgan 27
optidad
Re: How to remove mold from white sails? [Re: ksurfer2] #142088
05/05/08 01:08 PM
05/05/08 01:08 PM
Damnit. My wife HAD to have a membership at this ONE gym in the area that had the special "salt water filtration system"....still paying through the nose.
Is it cheaper to operate or is it just a marketing scheme?
Re: How to remove mold from white sails? [Re: Jake] #142089
05/05/08 01:46 PM
05/05/08 01:46 PM
Appleton, WI
blockp Offline
blockp  Offline
Appleton, WI
A couple years ago, my brother in Phoenix switched his pool to the salt water version. Said it's a lot cheaper to operate and doesn't dry out your skin like the chlorine did. But Surfer2 says it just turns the salt to chlorine... sounds like the not drying him out is all in him mind <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
Re: How to remove mold from white sails? [Re: blockp] #142090
05/05/08 03:16 PM
05/05/08 03:16 PM
Louisiana
Louisiana
This one time at BandCamp I had this sail that was sooooo crisp and stiff it .....
So what about a 55 gal drum add water, some bleach, some oxyclean and stir, soak, stir, soak... rinse rinse rinse.....
Todd
Re: How to remove mold from white sails? [Re: Scubajeep] #142091
05/05/08 03:34 PM
05/05/08 03:34 PM
i wouldnt use bleach... it can degrade sailcloth and even the threads that are sown into it....
Re: How to remove mold from white sails? [Re: ] #142092
05/05/08 04:23 PM
05/05/08 04:23 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
bleach = chlorine
just don't use too much. Kinda like alchohol, when used in moderation its great, too much then all goes to hell! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Clayton
Re: How to remove mold from white sails? [Re: Clayton] #142093
05/05/08 08:10 PM
05/05/08 08:10 PM
Clayton
What!? Seriously? ~burp~
Re: How to remove mold from white sails? [Re: blockp] #142094
05/05/08 10:12 PM
05/05/08 10:12 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
The salt systems are cheaper to operate but... (I'll get to the but in a minute). No more chlorine tablets and no more smell. The salt system does convert salt to chlorine and is very effective in keeping the pool algae free.
Now the but. The system is made up of two components: the controller and the generator. The entire system can be had on the web for about $1000. The generator will get clogged with minerals in the water. It can be cleaned by soaking it in a mixture of muriatic acid and water to clean but after five years the generator is pretty much toast. A replacement can be had for $395.
So, if you don't like the tablet chlorine smell and don't mind shelling out $395 every five years, a salt system is the way to go. It might be worth while to see how much chlorine would cost over a five year period. The salt system might be cheaper.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: How to remove mold from white sails? [Re: Scubajeep] #142095
05/06/08 05:26 AM
05/06/08 05:26 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
shower mold spray.
