closed loop spin halyard/retrival #143171
05/13/08 01:11 PM
05/13/08 01:11 PM
roccats Offline OP
roccats  Offline OP
I have a bimare jav2 that was setup with a single closed loop for the spin halyard and retrival. I have always had trouble with dousing the spin with excess resistance in the retrival line. Any thoughts / opinions on keeping the single line system vs a separate 2 line setup?
Bimare Jav2 18HT
Re: closed loop spin halyard/retrival [Re: roccats] #143172
05/13/08 05:54 PM
05/13/08 05:54 PM
ncik Offline
ncik  Offline
There shouldn't be much difference in resistance between the two.
The chute opening is the major component of resistance in the system.
Re: closed loop spin halyard/retrival [Re: roccats] #143173
05/13/08 08:10 PM
05/13/08 08:10 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Do you believe it will be easier to set and retrieve if you just cut the line of your one line setup, so that it becomes a two line setup?
If the answer is "yes", your line is two short - buy a longer one. If your answer is no, your problem is elsewhere.
Luiz
Re: closed loop spin halyard/retrival [Re: Luiz] #143174
05/13/08 08:46 PM
05/13/08 08:46 PM
ncik Offline
ncik  Offline
As a note, you will need more rope for a split system than a continuous system. This could lead to more clutter, depending on how you set it up.
Re: closed loop spin halyard/retrival [Re: roccats] #143175
05/13/08 09:34 PM
05/13/08 09:34 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Do you mean a single line for pulling the tack out & then hoisting the sail? These systems do have some additional resistance, but not that much.
A big factor on my Tornado seems to be where the snuffer opening is placed along the pole...depending on the retrieval patch locations on the sail, you want the sail entering snuffer opening before all 3 (or 2) patches jam up together. Having the opening as close to the forestay as possible was a disaster...the sail would be a huge blob of clothe drapped over the opening...making lots of resistance to enter the ring. Placing the ring 12-18 inches forward allowed the sail to start entry prior to all 3 patches bunching up fully.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: closed loop spin halyard/retrival [Re: Luiz] #143176
05/14/08 07:23 AM
05/14/08 07:23 AM
roccats Offline OP
roccats  Offline OP
Luiz, you just answered my question. I always assumed the line that came with the boat was the correct length.
Bimare Jav2 18HT
0 registered members (), 2,009 guests, and 428 spiders.
