| Re: Prod, prod, prod
[Re: Rolf_Nilsen]
#143987 05/24/08 05:54 PM 05/24/08 05:54 PM | Anonymous
| Anonymous
Unregistered | Have a look at some photos of 12' skiff prods, they all have a dolphin striker. It allows for a reduction in tube size, and probably takes some load off the bows. | | | Re: Prod, prod, prod
[Re: Smiths_Cat]
#143991 05/25/08 03:52 AM 05/25/08 03:52 AM |
Posts: 9,582 North-West Europe | Spot on Smithscat !
[Re: taipanfc]
#143995 05/25/08 12:06 PM 05/25/08 12:06 PM |
Posts: 9,582 North-West Europe | Taipanfc,
I'm sorry to say that your comments are utter nonsense.
First of all the pelican striker (as the setup in the picture is called) is whole fitted to the pole itself and therefor can not improve the displacement of the pole tip under load. The shown setup still wholely dependents on the pole tip and bridle support wires to limit tip movement and as such is absolutely no different from a setup without the pelican striker.
Secondly, I have no seen a F16 yet where the tip is displaced 100 mm under (spi) load. If that is the case for a given F16 spi setup then an error has been made in constructing it. A simple 40x2 mm alu tube with 3 or 4 mm dyneema support line to the tip and midsection of the pole is enough to lock the pole up in quite a stiff sense.
[Re: phill]
#144002 05/26/08 03:50 AM 05/26/08 03:50 AM |
Posts: 539 | Wouter, Have you forgotten about the compression strut above the pole that goes to the bridle wires?
The way I see it this set up will allow the spi pole to be carried lower or make the setup stiffer for the height the pole is carried.
As the pole is lowered the spi pole bridle is less affective at taking the vertical loading while quite adequate at handling the horizontal loading. So the striker below the pole will help transfer the vertical loading on the tip of the pole to the standard fore stay bridle wires via the compression strut above the pole between the spi pole and the normal bridle.
Just the way I see it.
Regards, Phill Explained it better than I Phil. The lower the pole at the bow, the less effect the front bridles will have. Perhaps they are also using new cut kites that are flatter and closer to a Code Zero and require extra assistance in keeping the luff tight and consistent. The Pelican striker is a good option to assist in achieving this. | | | Re: Prod, prod, prod
[Re: Rolf_Nilsen]
#144003 05/26/08 04:18 AM 05/26/08 04:18 AM |
Posts: 3,528 Looking for a Job, I got credi... | We sailed with less mast rake than most, mega rake did not work for us, and probably the lowest spi pole in the fleet. What Phill describes was an issue solved by fine tuning the lower bridle wires for good performance to windward. It was quite visible when beating if these were not perfect, but not while using the spi as far as I remember. Pre-bend in the spi pole was our way of lowering the tip while keeping the compression strut at the same length.
Will be interesting to find out where the advantage is and how well it works. Rolf, Not sure what you mean by tuning the lower Bridals for windward work. Surely they are D12(or similar) so streach more than the wire of the upper bridals?
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Prod, prod, prod
[Re: scooby_simon]
#144004 05/26/08 05:03 AM 05/26/08 05:03 AM |
Joined: May 2003 Posts: 4,451 West coast of Norway Rolf_Nilsen OP
Posts: 4,451 West coast of Norway | I dont remember what line we used there. It was some synthetic line (4mm, no uncover, silver colored) but I do remember the need to tune them to make the lower part of the jib set properly going to windward. Lining up the spi pole so it was straight and perfecting tension and length of the lines was a chore. The hulls also flex to a certain degree, so you rarely get perfect trim on the lower part of the jib even if perfections is the goal.
I think a flatter kite would give better VMG around the course, but there are limits due to measurement rules. Spis have been the area for most experimentation, but it is still the Gran Segel MK4 which is the choice. The sail John and Charlie use in the picture is a Performance cut. Interestingly enough, the reason the Gran mark 4 is the weapon of choice is that you can go quite high with it. Gran themselves say a slightly deeper and different cut will be faster VMG wise around the course if there are no other boats there. Contradicts my opening statement of course but that is part of the fun with sailing.
If the question is "do a flatter cut spi need less movement of the tip of the spi pole?" I would say the movement is so small already today that it dont make much of a difference.
That picture turned into an interesting discussion for us gearheads <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> | | |
1 registered members (Seanziepop),
676
guests, and 84
