| Re: Lowering mast on Hobie 16
[Re: obsurfersocal25]
#144183 05/27/08 12:06 PM 05/27/08 12:06 PM |
Posts: 321 Albuquerque NM | 1) Do not release all 3 shrouds!!!!
2) You MUST use a stepping link H shaped piece of metal with 2 fairly slender rods that holds the mast to the stepping base.
3) have one person on the tramp pushing the mast a bit forward while the second person releases the Forstay.
4) the person that releases the forstay should than move to the back of the boat to catch the mast as the person on the tramp slowly lowers it(the mast)
There are many variations on this, but this is the simplist.
BE SURE YOU HAVE THE STEPPING LINK IN PLACE!!!!!!
[b] Sail Like you have a Pair
#144187 05/28/08 06:13 AM 05/28/08 06:13 AM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | Sounds like you might have been missing the hinged link that should have pivited up to the hole on the mast, so you could put the screw driver through before releasing the forestay.
Have any pictures of the mast damage? If you're lucky you can get away with a $300 comp tip.
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
#144188 05/28/08 09:07 AM 05/28/08 09:07 AM |
Posts: 321 Albuquerque NM | Check ebay, craig's list, catsailor.com, thebeachcats.com all have a for sale section. There is a guy here in ABQ that has at least one mast for less than $500.00 I believe. I know shipping is a problem but....
Good luck and post those pictures as a comptip just might fix the problem.
Sam
#144190 05/29/08 08:40 PM 05/29/08 08:40 PM |
Posts: 321 Albuquerque NM | Two things,
1 have you looked into the comptip idea? 2 if the comptip thing won't work, I need a new/different mast base and 2 hole tang. If you are going to scrap the mast and the tang is a 2 holer, and/or your base is in decent shape, I will buy them from you.
3,175
guests, and 228
