| Re: New to F16 - Best type of boat
[Re: fin.]
#144395 05/30/08 05:38 AM 05/30/08 05:38 AM |
Joined: Mar 2008 Posts: 201 Adelaide, South Australia simonp
Posts: 201 Adelaide, South Australia | Hi Dave,
Being in Melbourne you are lucky to have the option to try all three boats that you mentioned before you buy.
After sailing all 3 I decided on the blade partly because of the superior build quality of the boat but mainly because at my weight 98kg I knew I needed the lightest possible boat I could get. The thought of being 25-30kg over before i even step on the boat wasn't appealing to me. My uneducated opinion is choose
- taipan to get into the class quite cheaply, and if you want the option of sailing one design as well - viper to get a good new boat at a reasonably good price but know that you are carrying a large weight penalty. - homebuilt blade if you enjoy that sort of thing, however I don't think you will save massive amounts of money - FCA blade if you want the best at the minimum weight.
There are claims that the Viper can carry heavier weight because of it's higher hull volume but after my test sail I'm not sure.
Disclaimer: I am getting an FCA blade, and will be seeing Marcus from Formula Catamarans Australia, on the weekend and he is bigger than me!!
Simon BLADE F16 AUS405
[Re: self_inflicted]
#144396 05/30/08 05:42 AM 05/30/08 05:42 AM |
Joined: Mar 2008 Posts: 65 Geelong, Victoria, Australia millex5
Posts: 65 Geelong, Victoria, Australia | I second the taipan reccomendation. it's a good solid boat, and you can pick up a good second hand one for very little (Mine was $5500) If you're looking for one to try out, then by all means come and get a feel for it on mine. (based in geelong, and will be here all the time from now until the 19th)
Alex Millington Taipan 4.9 - Ragnarok | | | Re: New to F16 - Best type of boat
[Re: Tornado_ALIVE]
#144399 05/30/08 01:39 PM 05/30/08 01:39 PM |
Posts: 3,528 Looking for a Job, I got credi... | I would say Blade if you can afford it, Tiapan if not.
I cannot suggest you buy a Viper, at 25kg over min weight it's just too heavy.
Come sale time, if there are two boats available, one on-or-about min weight and one thats considerably heavier, which one will someone buy if all the other factors are the same. The lighter one.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: New to F16 - Best type of boat
#144400 05/30/08 04:44 PM 05/30/08 04:44 PM |
Posts: 13 | The blade and viper are F16 and seem to need the kite to work there magic Richard, can you elaborate on this comment ? Do you mean those boat are not as good without a kite ? | | | Re: New to F16 - Best type of boat
[Re: daveaus]
#144401 05/30/08 05:11 PM 05/30/08 05:11 PM |
Posts: 461 Victoria, Oztralia | Hi Dave Port Melbourne has heaps of Taipans, and I think Greg Goodall sails out of there as well, while Bendigo has no water. Frankston has a few sailing out there as well with couple sailing often with kites. And check out www.taipan.asn.au for new or used boats. Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: westcat]
#144403 05/31/08 01:11 AM 05/31/08 01:11 AM |
Posts: 94 australia | The blade and viper are F16 and seem to need the kite to work there magic Richard, can you elaborate on this comment ? Do you mean those boat are not as good without a kite ? They seem to need the kite to get downwind fast,I can only speak for sailing against the blade,not sure on the viper but with them sharing the same theorys it could be case.As for going to windward they all seem to have the same boat speed,I think it's the beam width on the boats that could make them different I always think it's the nut holding the tiller that makes them go Just my 2 cents worth Richard | | |
667
guests, and 117
