Stiletto 27 (aka larger beachcat) cruise to Mexico #144850
06/05/08 10:04 AM
06/05/08 10:04 AM
Near SLC, Utah
tomthouse Offline OP
Near SLC, Utah
I thought some of you might enjoy reading about our Stiletto 27, (a.k.a. over-sized beachcat) trip to Mexico.
For laughs, here's a crewman's version, with some pictures.
http://vaughnemett.blogspot.com/
You may have to scroll down his blog to Thursday, May 22, 2008.
If you click on any of the pictures, they should automatically enlarge.
For some balance, I've also included my version of the story.
Surprisingly enough, both versions seem to have some similarities.
My version:
Wow!
You guys are going to have to try out this kind of an adventure.....
Once you swallow the 1,000-mile drive from SLC, Utah to get to the launch point in San Carlos, Mexico ...the 300 miles under sail from there to Santa Rosalia and back is a great adventure.
Our first try to sail the 90 miles of open-ocean across the Sea Cortez was in fairly light wind conditions. That changed to no wind at all.
That resulted in having to use our 15 hp outboard engine.
However, it decided to quit after only a couple of hours of motor sailing.
We had tools etc., but I felt hanging off the back of the hard deck, across the abyss was a poor option to figure out and attempt to fix the engine's unknown problem.
We were only thirty miles into the 90 mile crossing to the Baja, so having not hit the halfway point or point of no return, we decided to untie the dinghy from where it was secured on the front tramp, secure it along side the Stiletto and use the dinghy’s 1 hp to push us back to our launch point at San Carlos.
Upon arrival, a quick check by an outboard mechanic disclosed the plugs were terribly fowled.
After cleaning and clearing the plugs, the outboard ran like a champ for the remainder of the trip.
We pushed back off and about a mile or so out to sea, the wind picked up for some great sailing, which lasted for a few hours.
As the wind increased and the sunset, for safety purposes, we reefed the main and changed the Genoa in favor of the blade jib.
The boat ran very well, the sun set was outstanding and a moonless sky gave a fantastic view of the Milky way and shooting stars.
By 11:00 PM a storm caught us by surprise on this 90-mile open ocean trip.
Well it was not a complete surprise, but the storm was much more intense than expected.
When we arrived at our destination, the port captain said his wind gauge showed 40 knots at the storm's height and some of the crew said they estimated the wave, aka, giant chop and breaking waves, at 8 to 12 feet.
That of course was no problem for us...we were right in the middle of the Sea of Cortez, about 45 miles from any place to hide out.
Bummer..!
At about 2:00 AM the wind somewhat subsided and the crew was tiring.
I guessed the slight lull was when the low past over us.
The good news is there was very little for 50 miles around us to hit in the night.
The other good news was as the low past, it provided the perfect time to stop practicing heavy air sailing with our blade jib and reefed main...sailing as close to the wind as possible without staling and to then practice using our storm parachute sea anchor.
That parachute really settled the boat down and it lay pinned to the sea. The boat was rock solid and road very well.
We rigged the Sea anchor's top to a large dock fender with about 100 feet of line.
The other end of the set up was attached to a swivel, attached to our Dansford anchor, where its rode attaches to the anchor's twenty feet of chain.
The entire set up put a large "belly" in the sea anchor's rode that acted like a shock absorber when each breaking wave hit the boat.
The result was to take up the initial shock of any breaking wave hitting us and then pull the boat through the boiling water and foam.
The Stiletto 27 has a great "wave piercing" bows that also have lots of reserve buoyancy aft of the bow's prow section.
That put water boarding the bow's decks, but dissipated the boarding water quickly....as the reserve buoyancy kicked in, well before the water came our way, where we sat in the aft section of the boat's main deck, well behind the mast.
The upside down dingy and its inflatable collar, secured to the forward trampoline, also helped with reserve buoyancy and dissipating the boarding water.
Later, we tried retrieved the Sea anchor by motoring towards the floating fender. However, a loose line stalled the motor as it wrapped around the prop.
The seas were still fairly rough so we manhandled the parachute anchor back on board.
Next time we'll rig a floating trip line from the floating fender to back to the boat.
I'm sure dragging the parachute, top end first, to collapse it, would be much easier than dragging it by its rode and shroud lines through the water back to the boat.
After getting it back aboard, we plotted our position and found our drift during the eight hours hove to a sea anchor was about eight miles.
Once we hoisted the main and small jib, the boat sailed like a beach cat...fast and flat, just flying through the wind and waves...
Waaaa hoooo....!
What an awesome sail....at one point, right through the middle of a huge pod of whales, blowing, breeching and rolling.
They stayed with us or we with them for an hour.
Once across the sea, we arrived at the Santa Rosalia marina around 5 PM.
The facilities are less than a year old and gave us a place for the boat while we dried out in a hotel. Later we explored the small city, including a church built by the same Eifel as the one who designed and built the Eifel Tower in France.
The next day we again set sail for our return to San Carlos.
About midnight, in an ink black sea under a canopy of stars, we began seeing large random streaks of light in the inky depths of the sea.
They dances and streaked in random directions, all over the place.
As we got closer, they turned out to be dolphins playing and gliding in the night’s seas.
There was some kind of luminescence in the water, that caused the sea to illuminate when churned by prop or bow wash and by these fast swimming mammals.
The illuminated streaks continued behind the sources some fifty or sixty feet.
That was way cool.
Due to Mother's Day, we cut our sailing a bit short. We feared reprisal for not including the wives in this trip and possibly not getting home in time for the traditional "husband's cook every thing that day" at home.
After breaking the boat down for trailering on the highway, we hit the USA border just after the truck crossing closed for the night, at 11 PM.
The main crossing in Nogales, Mexico let us through but we were stopped by the US border guards, who would not allow us or any truck, RV or trailer traffic back into the US through this main Nogales crossing.
They made us wait until the Mariposa truck crossing opened the next morning at 6 AM, seven hours after we hit Nogales.
Rather than kill time in the "real" slummy section of the border city, near the crossing, we drove back out towards Santa Anna, Mexico and slept on the main highway in a truck stop next to a Pemex gas station.
After crossing the border, and being pleased to be back in the USA, it was a steak and eggs breakfast at an American Ihop restaurant.
All went well until we spun trailer axle bearing just outside Mesquite, Nevada.
That was a mild inconvenience and it allowed us to take full advantage of my Auto club towing insurance...
they put the boat and trailer on a flatbed truck trailer, taking it to St. George, Utah.
I left the boat and trailer at my brother's house. It should give his Home Owner's Association something to talk about for the next week or so.
I pulled the entire axle off the trailer so I could get it fixed here in SLC where there are many more options and services.
I'll be back down there next week anyway, so that will give a chance to have it repaired and then replace when I next visit. Hopefully I can get him to buy dinner.
Isn't family just the best?
I believe the bearing problem was the result of having the trailer's tongue too low.
I'd guess that kept putting more weight on the front axle, each time the rig went over various uneven sections of the highway, causing the rig to dip and sway a bit..
Next time we'll ensure the loaded tow vehicle and trailer are leveled better with an adjustable hitch.
The only other addition to this adventure is the tranny in the Jeep quite about ten miles from home.
We've had that vehicle forever and put lots of miles on it.
I've been meaning to replace that car for some time....now I have an excuse.
In some ways this trip was like an old western: The storm of the century hits, the good guys are pinned down by circumstances, the wagon breaks down and then even the horse dies.
Indeed the storm of the century did hit, but we were well prepared with reefing and storm anchor.
We were pinned down by not being allowed back into the US exactly when we wanted and the wagon (carrying the boat) did break down, but AAA was easily available.
Indeed, it appears our horse may have died...but before doing so it had stereo, movies if we wanted, and AC ....
We've have gotten about every mile possible out of that horse (the Cherokee Grand) and we have been planning and preparing to replace it anyway.
When buy any new vehicle, we do so with cash, saved for that purpose.
We gain the cash reserve by making payments to ourselves in anticipation of that vehicle’s future replacement...
What a great trip...!
Is life just the finest or what..?...
The adventure continues.....
Re: Stiletto 27 (aka larger beachcat) cruise to Me [Re: tomthouse] #144851
06/05/08 09:55 PM
06/05/08 09:55 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
Very cool.
So does the stiletto 27 have a toilet?
Re: Stiletto 27 (aka larger beachcat) cruise to Me [Re: Tri_X_Troll] #144852
06/06/08 08:44 AM
06/06/08 08:44 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Mine does!!! <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Nice write up Tom!
Clayton
0 registered members (), 448 guests, and 272 spiders.
