Hull Painting #145694
06/13/08 05:09 AM
06/13/08 05:09 AM
Geelong, Victoria, Australia
millex5 Offline OP
millex5  Offline OP
For the 2008/9 summer in australia, i am looking at getting the hulls on my taipan repainted. can anyone reccomend:
1: somewhere that will do this for me in either melbourne, sydney or geelong
2: anything (kevlar sheeting..?) that would increase the durability of the paint along the bottom of the hulls, as where we sail, crushed shells and general bits and pieces along the beach have a habit of scratching her viciously.
3: a price estimate of how much this usually costs.
thanks,
Alex
Alex Millington
Taipan 4.9 - Ragnarok
Re: Hull Painting [Re: millex5] #145695
06/13/08 05:55 AM
06/13/08 05:55 AM
Don't do it! Gelcoat.
Re: Hull Painting [Re: fin.] #145696
06/13/08 06:03 AM
06/13/08 06:03 AM
millex5 Offline OP
millex5  Offline OP
Righto.
how much would that cost?
Alex Millington
Re: Hull Painting [Re: millex5] #145697
06/13/08 06:26 AM
06/13/08 06:26 AM
I have no clue as to price, but it is easy enough to do yourself.
Re: Hull Painting [Re: fin.] #145698
06/13/08 06:55 AM
06/13/08 06:55 AM
millex5 Offline OP
millex5  Offline OP
of course, i would love to do it myself, but unfortunately there are a few restrictions...
1. no space - I live in italy, and the boat is stored in a small club over here with no indoors working space
2. no ability - i haven't tried painting/gelcoating anything before, and would be unsure about performing such a major task on a boat that I own at this stage in my sailing career. I'll save gaining that experience for when I have a big shed, and lots of time. :P
Alex Millington
Re: Hull Painting [Re: fin.] #145699
06/13/08 07:46 AM
06/13/08 07:46 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Interesting, and what technique would you recommend? <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: Hull Painting [Re: Buccaneer] #145700
06/13/08 01:49 PM
06/13/08 01:49 PM
Central California
slosail Offline
slosail  Offline
Central California
Is gelcoat being recommended for a small strip along the bottom of each hull, or each whole hull? The latter would seem rather heavy...
Re: Hull Painting [Re: millex5] #145701
06/13/08 01:56 PM
06/13/08 01:56 PM
UK
Cheshirecatman Offline
UK
thanks,
Alex
Do a search and look for a local supply of ceramkote 21(check spelling). It is a sprayable industrial coating of epoxy base with ceramic particles. I understand that it performs extremely well in terms of abrasion resistance and longevity and even a reduction in surface friction but may not give the 'Full Gloss'. If a good cosmetic finish is desirable look to use it on the underside of the hulls only.
I believe sunsail were using it on their charter fleet in the mediterranean in place of antifouling. Rather than have to haul the boats out and repaint anually they just used an in water boat scrub.
Do a catsailor search as I am sure it has been mentioned before and had pictures.
Cheshirecatman
Re: Hull Painting [Re: Buccaneer] #145702
06/13/08 04:07 PM
06/13/08 04:07 PM
I use a roller, wet sand and buff. You can spray it if you like.
Virtually every product thinkable has been used on boats, with varying results. IMO, gelcoat is still the most durable, least expensive, and easiest to apply.
Re: Hull Painting [Re: millex5] #145703
06/13/08 07:02 PM
06/13/08 07:02 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Alex
I see on your signature you have 'Homebuilt' so in that, your boat is timber, and would be painted.
So I would say 2 pak would be the way to go, and could possibly what is on there now.
If you preped the hulls yourself and dropped the hull off at the painters and supplied the paint, thinners etc.. I would guess you could do it for a couple hundred bucks.
If your boat is foam sandwich, and not homebuilt, I would contact Todd Pickering at Geltec in Bendigo and enquire about the best way to go. Chances are Todd built or had a hand in building your boat originally, being with Boyers from the beginning and now owns Geltec Composites.
When I had my boat painted I had the hulls hanging up ready to go, compressor on site, paint, thinners, mixing pot, disposal overalls, paint stirrers, set up on a table, he came, he painted, he left and he charged $70.00
Regards
Re: Hull Painting [Re: Cheshirecatman] #145704
06/13/08 08:35 PM
06/13/08 08:35 PM
UK
UK
thanks,
Alex
Cheshirecatman
Sorry! coating is ceramkote 54
Re: Hull Painting [Re: millex5] #145705
06/13/08 09:16 PM
06/13/08 09:16 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
G'day Alex "Perfection by International" is an extremely hardwearing paint that can only be put on by roller and brush tipping, wearing a respirator. If your paint is basically okay and its only where your hulls make contact with the sand consider taping that area off apply a bit of wessystem with microfibres to repair damage and just paint that area with any single pack marine undercoat and paint. You can do that yourself very easily and twice a season if needed. With single pack the opened can won't go off as quick.
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Hull Painting [Re: JeffS] #145706
06/14/08 12:12 AM
06/14/08 12:12 AM
millex5 Offline OP
millex5  Offline OP
Yes, to clarify my hulls are wooden.
if i was to go with the "perfection by International" option, how long do the hulls need to be out of the weather for?
Alex Millington
Re: Hull Painting [Re: millex5] #145707
06/14/08 05:35 PM
06/14/08 05:35 PM
JeffS Offline
JeffS  Offline
Perfection is a fantastic product but has to be applied perfectly. You would want to dismantle your boat fill and sand all imperfections (this could take weeks if your fussy). Probably 1 coat of sealer then the undercoat probably 2 coats 1 day apart then probably 2 coats of topcoat then no sailing for 2 weeks. All of the coats should be done 1 day apart so that the layers bond and there is no sanding reqired. When I did my stingray it took me weeks to do the fairing but was worth the time and the paint is like new 2 years later. If you type in the name and do a search there is an online tutorial on how to apply. All two pack paints are dangerous you must do it exactly as discribed and wear a good respirator or you may never get to sail it.
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Hull Painting [Re: JeffS] #145708
06/16/08 02:30 AM
06/16/08 02:30 AM
France
tom_in_fire Offline
tom_in_fire  Offline
France
In france, people are talking a lot about a teflon paint used by an F18 (who seemed to do very well). I don't know the details but maybe it is worth checking...
Re: Hull Painting [Re: tom_in_fire] #145709
06/16/08 04:19 AM
06/16/08 04:19 AM
Don't take too long researching it. Its about to be outlawed by the F18 council.
Re: Hull Painting [Re: ] #145710
06/16/08 05:28 AM
06/16/08 05:28 AM
Western Australia
Stewart Offline
Stewart  Offline
Western Australia
this is that new US paint that is an anti-fouling? Their blurb states the growth cant stick...
Actually not sure it will help a F16 with a polished hull but guess some will say it will.. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Hull Painting [Re: Stewart] #145711
06/17/08 12:03 AM
06/17/08 12:03 AM
ncik Offline
ncik  Offline
I got an estimate to 2-pack my cat of about $1000, including sanding and painting. It already has a coat of interprotect which needs a sand and then a coat of primer and a coat of 2-pack.
Find someone that will let you do all the hard work in their shed, mainly the dismantling and sanding. Then they can do the actual painting.
Re: Hull Painting [Re: ncik] #145712
06/17/08 08:30 AM
06/17/08 08:30 AM
JeffS Offline
JeffS  Offline
$1000 for a professional job if theyre going to supply paint, sandpaper, filler, bake it? and do a perfect job with no input from the owner is probably a bargain
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Hull Painting [Re: JeffS] #145713
06/17/08 04:58 PM
06/17/08 04:58 PM
Central California
slosail Offline
slosail  Offline
Central California
$1000 for the whole job seems like a good price if quality work is done...especially if your dollars are still worth something. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
I was looking through some US retailers' paint listings, and the good stuff (2-part) says "not for sale in California." Oh great, do we have to take our hulls across borders now to get good paint on them? (One imagines a nautical version of Cheech and Chong's _Up in Smoke_.) Has anybody out there dealt with this?
0 registered members (), 20,053 guests, and 1,598 spiders.
Most Online22,490
Yesterday at 08:14 AM
