| Re: rule of thumb for rivets?
[Re: Clayton]
#145890 06/16/08 08:04 AM 06/16/08 08:04 AM |
Posts: 12,310 South Carolina | yup - monel...though stainless will work fine. Goop up the rivet and hole with 5200 before setting it...it won't necessarily stop the electrolysis but it will keep water from pooling between the materials.
Jake Kohl | | | Re: rule of thumb for rivets?
[Re: SurfCityRacing]
#145893 06/16/08 03:24 PM 06/16/08 03:24 PM |
Posts: 5,590 Naples, FL | You might find it helpful to use something like Calpico tape under the hardware to curb the corrosion between the mast and fitting. And glue/seal in rivet caps before you set the rivet if you want to make sure it's water tight. Not sure I understand that "glue/seal in rivet caps before you set the rivet" Care to elaborate?
3,041
guests, and 357
