rule of thumb for rivets? #145888
06/16/08 07:09 AM
06/16/08 07:09 AM
Virginia Beach
Sunvista Offline OP
Sunvista  Offline OP
Virginia Beach
Is there a "rule of thumb" for blind riveting two dissimilar materials like stainless to aluminum? For example, riveting a stainless mast hinge or block hanger to an aluminum mast or boom. Would I use an aluminum or stainless rivet?
Re: rule of thumb for rivets? [Re: Sunvista] #145889
06/16/08 07:31 AM
06/16/08 07:31 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Monel
Re: rule of thumb for rivets? [Re: Clayton] #145890
06/16/08 08:04 AM
06/16/08 08:04 AM
yup - monel...though stainless will work fine. Goop up the rivet and hole with 5200 before setting it...it won't necessarily stop the electrolysis but it will keep water from pooling between the materials.
Re: rule of thumb for rivets? [Re: Sunvista] #145891
06/16/08 11:16 AM
06/16/08 11:16 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Just dont rivet aluminum to carbon, and dont use aluminum rivets in carbon.
Too far apart on the electron swapping scale.
Re: rule of thumb for rivets? [Re: bvining] #145892
06/16/08 02:24 PM
06/16/08 02:24 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
You might find it helpful to use something like Calpico tape under the hardware to curb the corrosion between the mast and fitting. And glue/seal in rivet caps before you set the rivet if you want to make sure it's water tight.
Re: rule of thumb for rivets? [Re: SurfCityRacing] #145893
06/16/08 03:24 PM
06/16/08 03:24 PM
Not sure I understand that "glue/seal in rivet caps before you set the rivet"
Care to elaborate?
Re: rule of thumb for rivets? [Re: waterbug_wpb] #145894
06/16/08 03:50 PM
06/16/08 03:50 PM
Santa Cruz, CA
Santa Cruz, CA
This is a rivet cap or casing. Most rivets used on beach cats are 3/16" monel rivets. A common use is to attach tangs and other fittings on hollow extrusions (masts). To keep water from going through the mandrel hole on the rivet, most manufactures/ repair guys etc. use rivet caps. It's a little more reliable than a dab of silicone. These go under the hardware and require that you use a 13/64" drill rather than a 3/16". The rivets then go into these caps. I always dab silicone on them before putting them in. Another benefit is that there is aluminum contacting your aluminum mast, and the cap, not the mast will act as the sacrificial anode--sort of.
Hope that helps.
Re: rule of thumb for rivets? [Re: SurfCityRacing] #145895
06/16/08 04:01 PM
06/16/08 04:01 PM
U
ucfsailor19 Offline
ucfsailor19  Offline
U
You would want to use a stainless steel rivet, and the reason for that is the cathode to anode ratio. Since aluminum is the anode when mated with stainless, a small aluminum rivet compared to a much larger piece of stainless will make the aluminum rivet corrode fast.
http://www.ocean.udel.edu/seagrant/publications/corrosion.html
Re: rule of thumb for rivets? [Re: ucfsailor19] #145896
06/16/08 04:57 PM
06/16/08 04:57 PM
Virginia Beach
Sunvista Offline OP
Sunvista  Offline OP
Virginia Beach
Thanks for the explanation. I would have thought the opposite though for another reason. In other words, one would want the formed, blind side of the rivet to be the same as the material being riveted. I'm attaching a stainless block hanger to an aluminum boom. The galvanic action would be nil at the attachment or grip point if both the aluminum rivet and boom are the same material. Wouldn't the grip point of the fastener be the most critical area rather than the head of the rivet?
Re: rule of thumb for rivets? [Re: Sunvista] #145897
06/16/08 08:50 PM
06/16/08 08:50 PM
catman Offline
catman  Offline
You might also try tef-gel to coat the rivet/ alum. joint.
Re: rule of thumb for rivets? [Re: catman] #145898
06/17/08 05:13 AM
06/17/08 05:13 AM
Ljubljana, Slovenia
mayhem Offline
mayhem  Offline
Ljubljana, Slovenia
See earlier discussion about rivets and dissimilar materials.
http://www.catsailor.com/forums/showflat...true#Post142319
0 registered members (), 392 guests, and 34 spiders.
