Page 1 of 3 1 2 3
Hull Repair #146124
06/18/08 01:44 AM
06/18/08 01:44 AM
Simon C Offline OP
Simon C  Offline OP
Hi All,
Can anybody local suggest somewhere to get closed cell foam and polystyrene foam sheets.
Also, for anyone hanging out for a sail, Winter series at McCrae, Saturdays in July, 1.00pm start. (You can probably guess from my question that I will not be sailing) <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Cheers,
Simon
Taipan AUS341
Re: Hull Repair [Re: Simon C] #146125
06/18/08 03:39 AM
06/18/08 03:39 AM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Simon,
If I was doing this at home I would deal with FGI and they have a sales outlet in Springvale...in Melb.
FGI - Springvale
1612-1638 Centre Road
Springvale VIC 3171
Tel: (03) 9550 5650
Fax: (03) 9547 5179
Postal: PO Box 40
Clayton South Vic 3169
hope this helps and you are back on the water soon....
Enjy the smell of glass.
David
"Banh Sidhe"
Re: Hull Repair [Re: Simon C] #146126
06/18/08 06:30 AM
06/18/08 06:30 AM
Peter_Foulsum Offline
Simon,
Sorry to hear your Mozzie is sick. <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> What are the symptoms ?
Another local supplier is Nupol Composites although they are into Polyester and Vinyl Ester but have core materials.
http://www.nupol.com.au/branches
And another one is:
Saint-Gobain RF Pty Ltd
635 Queensberry St
North Melbourne
VIC, 3051
Ph: (03) 9329 0111
Their website wasn't working tonight. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Peter
Mosquito 1814
Macka Mozzie
Re: Hull Repair [Re: Peter_Foulsum] #146127
06/18/08 07:53 PM
06/18/08 07:53 PM
Simon C Offline OP
Simon C  Offline OP
Thanks Peter and David, I'll try FGI first as they're just around the corner from my work.
Peter,
It's not a big drama. I sailed with a "crunchy" foam frame for most of last season and I need to replace it as I have cracks in the deck where it has been flexing. I should have done it earlier but I have found myself on the committee for the Yacht club this year and that has taken up a fair bit of time. ( Plus I've been whimping out and putting off cutting a hole in my deck given my lack of knowledege in this area!) <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
I was considering re-decking the working deck but have decided to go with key-hole surgery. I figure that as long as I get the strength right, any untidy workmanship can be fixed with bog and paint. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />I am also fitting my new centre boards.
Looking forward to the learning experience and the fumes.
Simon
Taipan AUS341
Re: Hull Repair [Re: Simon C] #146128
06/18/08 07:59 PM
06/18/08 07:59 PM
3 weeks Newman WA 1 week Robe ...
Brian P Offline
Brian P  Offline
simon do yourself a favour and get some gloves. dont get the M.E.K. on your skin. its a pretty nasty organic chemical. you are better off not reading the MSDS ( material safety data sheet).
Brian Partridge
STINGRAY 580 "Fantasia"
A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD
BUT YOU CAN ROLL IT IN GLITTER!!!!!
Re: Hull Repair [Re: Brian P] #146129
06/19/08 01:45 AM
06/19/08 01:45 AM
Lake Bonney, SA
dkd Offline
dkd  Offline
Lake Bonney, SA
Simon,
I believe you boat has AJ hulls.....and if so yours is not the only one I know of, with soft working area decks, that is, theones between the beams
It may be prudent to take the decks off and check all the frames....and easier in the long run, than doing it "keyhole"
but in the long run....your call
enjoy it either way, and not that hard a job either way
David
Re: Hull Repair [Re: dkd] #146130
06/19/08 05:09 AM
06/19/08 05:09 AM
Melb. Aust
Trevor Offline
Trevor  Offline
Melb. Aust
Hi Simon,
You mentioned the crunchiness to me at the states - was it the front deck, or between the beams?
Trevor
Mozzie 1828
Sugarloaf Sailing Club
Melbourne
Re: Hull Repair [Re: Trevor] #146131
06/19/08 06:11 AM
06/19/08 06:11 AM
Simon C Offline OP
Simon C  Offline OP
Yes, It's between the centrboard case and rear beam. I quite like the thought of re-decking as David suggests and replacing all the foam but when you've never done this sort of thing, going solo for the first time is a bit daunting.
Trevor, If you had the time to pop down one weekend and give me some pointers for the first one, I'd be happy to compensate you for your time.
Simon
Taipan AUS341
Re: Hull Repair [Re: dkd] #146132
06/19/08 06:49 AM
06/19/08 06:49 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Simon,
David
I'd go with David if you look up "stingray deck repair" on thebeachcats.com you'll see the results of keyhole surgery by the previous owner of my old stingray. It works for a while but then can be a total mess. If you can work out how to get your decks off you'll find the rest easy just grind out the cracked foam and put in new foam. I added a layer of divinicell and glass under the decks for hardly any extra weight and bullet proof decks. If you get the prescarfed divinacell it easily flexes to the shape of your deck, just take the deck off support it upside down put in some cloth, some resin add your foam, some weight to push the foam to shape jobs done.
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Hull Repair [Re: JeffS] #146133
06/19/08 06:59 PM
06/19/08 06:59 PM
Simon C Offline OP
Simon C  Offline OP
An excellent point you make Jeff.
I checked out the reference you gave..... boy, a picture's worth a thousand words. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Thanks.
Simon
Taipan AUS341
Re: Hull Repair [Re: Simon C] #146134
06/20/08 06:45 AM
06/20/08 06:45 AM
Melb. Aust
Trevor Offline
Trevor  Offline
Melb. Aust
no worries Simon,
Once the freeway is open (next week I think) You should only be about 35 minutes away.
If you like, I can bring some tools down and we can open her up!!!
Should take less than an hour.
Trevor
Mozzie 1828
Melbourne
Re: Hull Repair [Re: Trevor] #146135
06/20/08 08:45 PM
06/20/08 08:45 PM
Simon C Offline OP
Simon C  Offline OP
Much appreciated Treveor,
I have sent you a PM with address and phone numbers. Yes, the freeway opens next Sunday. My boys are at their mothers that weekend and I have the following week off to continue the job, so if next Sunday suits, I'll prepare the operating theatre. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Simon
Taipan AUS341
Re: Hull Repair [Re: Trevor] #146136
06/25/08 01:41 AM
06/25/08 01:41 AM
Simon C Offline OP
Simon C  Offline OP
Hi Trevor,
Did you get my PM?
Simon
Taipan AUS341
Photos... I know you'll ask for some Peter F [Re: Simon C] #146137
06/29/08 06:35 AM
06/29/08 06:35 AM
Simon C Offline OP
Simon C  Offline OP
This is mid way through exploratory surgery. (Thanks Trevor for showing me the way with that first router plunge)
Looks like the cause of my problems is a very dodgy repair!
Re: next [Re: Simon C] #146138
06/29/08 06:43 AM
06/29/08 06:43 AM
Simon C Offline OP
Simon C  Offline OP
Notice the join in the stringers.... no support and bugger all glue... Also, its a bit hard to see but the deck support was put in with bog.... no epoxy let alone tape.
Simon
Taipan AUS341
Re: next [Re: Simon C] #146139
06/29/08 06:56 AM
06/29/08 06:56 AM
Simon C Offline OP
Simon C  Offline OP
All the crap out (except the broken stringers) and time for Trevor and I to head to the pub <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Couple of interesting things found. The positioning of the track as per the glass boats, and fibreglass cases.
At this stage the consensus of 2 in my garage was that a proper repair to this area will be all that is required, rather than doing the whole deck. Everything fore and aft of the impact zone seems solid and where it should be.
Plan is some Ply half-frames with t-tops at the joins, cut and insert new stinger lengths to suit, doubling at the joins, and a good number of thick foam frames, epoxied in.
I'll take some happy snaps as I go for anyone interested.
Simon
Taipan AUS341
Re: Photos... I know you'll ask for some Peter F [Re: Simon C] #146140
07/04/08 08:07 AM
07/04/08 08:07 AM
OK Simon,
I've waited long enough. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Where's the rest of the happy snaps ?? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Were both hulls having the same problem ?
Did this hull have any leaks prior to the surgery and if so have you checked around the centreboard casing ?
Peter
Mosquito 1814
Macka Mozzie
Re: Photos... I know you'll ask for some Peter F [Re: Peter_Foulsum] #146141
07/05/08 01:48 AM
07/05/08 01:48 AM
Simon C Offline OP
Simon C  Offline OP
Hi Peter,
I've had the boys home for holidays this week so not much time. Also, I had a bit of trouble tracking down some 3mm Ply, coming in 3 weeks <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" /> so I've relaxed off a bit. I'm getting the Bog off from the dodgy repair, bloody hard stuff!
In the mean time, some snaps of the case set up. Not what I expected to find.
Will hopefully make some more progress this week
Simon
Taipan AUS341
Re: Photos... I know you'll ask for some Peter F [Re: Simon C] #146142
07/05/08 01:49 AM
07/05/08 01:49 AM
Simon C Offline OP
Simon C  Offline OP
and another
Simon
Taipan AUS341
Re: Photos... I know you'll ask for some Peter F [Re: Simon C] #146143
07/05/08 01:51 AM
07/05/08 01:51 AM
Simon C Offline OP
Simon C  Offline OP
and last one
Simon
Taipan AUS341
Page 1 of 3 1 2 3
1 registered members (vasil), 372 guests, and 39 spiders.
