| Re: Nacra Rudder issues
[Re: Kennethsf]
#14643 10/13/05 03:36 PM 10/13/05 03:36 PM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | Three initial reactions..... How does it react if you struck an object with the rudder?
It's a long reach to release it isn't it?
I'm assuming you still utilize shock cord for lifting up the rudder but could you add a line on the opposite path to control lifting the rudder. (I dislike the shock cord solution.)
Very cool though. You're a thinker. I like your tiller arm adjuster as well.
Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: Nacra Rudder issues
[Re: PTP]
#14644 10/14/05 07:25 AM 10/14/05 07:25 AM |
Posts: 12,310 South Carolina | I've said it before - but the stock system works well if you use the right kind of line. This is one of the only places I would use the cheaper version ... but get the cheap white/red poly line from Lowes and use it on your rudder hold downs - you'll never have a problem again...the knobby nature of the line and the size of it result in it staying put.
Jake Kohl | | | Re: Nacra Rudder issues
[Re: jes58]
#14647 10/19/05 03:59 PM 10/19/05 03:59 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | They should be slightly toed in. Never toed out. Toed out is like sailing around with your foot dragging in the water. Before you adjust the toe make sure you get all the slop out of the system. I got some of the Hobie delrin rudder pin bushings for thier castings and drilled my Nacra castings and installed them with stainless pins. Much better.
1 registered members (FredL),
343
guests, and 59
