soft hull tops on Prindle 16 #146377
06/22/08 08:19 AM
06/22/08 08:19 AM
destinlarry Offline OP
I have a 83 prindle 16, the top of the hulls in front of the tramp are getting springy, what can I do, what danger does this present. I have also noticed that the insides of the hulls under the tramp where you stand to right the boat after flipping are getting the same way. Thanks
Re: soft hull tops on Prindle 16 [Re: destinlarry] #146378
06/23/08 04:15 PM
06/23/08 04:15 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Sounds like 25 years of loyal service may be what you get.
The odd patch of softness does little harm and can be repaired, but it sounds like you have a bit more going on. The foam between the skins must be breaking down.
That is unless you have an old enough boat that was made in one solid skin. If this is the case, it may be possible to cut some access hatches in the deck and lay up some reinfocing or sub-decks.
Re: soft hull tops on Prindle 16 [Re: destinlarry] #146379
06/24/08 06:21 AM
06/24/08 06:21 AM
Long Island, NY
gregP19 Offline
gregP19  Offline
Long Island, NY
I wouldn't recommend sailing the boat if the hulls are soft in the area where the bridle wires attach to the hulls. When you tension the mainsheet the force applied can fold the bows inward. This happened to me on a H16.
Re: soft hull tops on Prindle 16 [Re: gregP19] #146380
06/24/08 07:01 AM
06/24/08 07:01 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Send me your email address and I will send you a step by step repair with photos and complete materials list.
hullflyer1@netzero.net
0 registered members (), 418 guests, and 42 spiders.
