beach wheel cradle questions #146631
06/24/08 11:45 PM
06/24/08 11:45 PM
WA, ID, MT
davefarmer Offline OP
WA, ID, MT
So the Tiger Trax for the HT just showed up (6 months later!). I've got the wheels back on the axel no problem, but it came with a pair of Performance Catamaran cradles that have never been mounted to the axel. I think they might have been designed to mount to trailer crossbars. Anyone got suggestions on how to attach these? And one side of the cradles is slightly higher than the other, any advice on which side is inboard and out? I'll attach pic(s) in the morn. Thanks!
Dave
Re: beach wheel cradle questions [Re: davefarmer] #146632
06/25/08 07:32 AM
06/25/08 07:32 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Usually they just bolt on.....
I'd put the high side on the outboard, but make sure that you get the most surface area contact either way.
Re: beach wheel cradle questions [Re: davefarmer] #146633
06/25/08 09:57 AM
06/25/08 09:57 AM
WA, ID, MT
WA, ID, MT
pic
Re: beach wheel cradle questions [Re: davefarmer] #146634
06/25/08 09:58 AM
06/25/08 09:58 AM
Tiger Trax for a Hobie Tiger?? sounds like a match made in heaven... but i thought those wheels dont work well on big boats or sand?
Re: beach wheel cradle questions [Re: davefarmer] #146635
06/25/08 09:59 AM
06/25/08 09:59 AM
WA, ID, MT
WA, ID, MT
another. Thanks Bill, bolt thru from the bottom of the cradle(recess bolt head below carpet?)?
Re: beach wheel cradle questions [Re: davefarmer] #146636
06/25/08 09:59 AM
06/25/08 09:59 AM
wheels took 6 months for delivery?
Re: beach wheel cradle questions [Re: ] #146637
06/25/08 10:01 AM
06/25/08 10:01 AM
WA, ID, MT
WA, ID, MT
6 months for the seller of the boat to get around to shipping the beach wheels, which somehow didn't come with the boat.
Re: beach wheel cradle questions [Re: ] #146638
06/25/08 10:03 AM
06/25/08 10:03 AM
WA, ID, MT
WA, ID, MT
The wheels are for a Bimare Javelin, significantly lighter than a Tiger, so I hope they'll work ok. I've been pulling the boat up and down the beach on strips of carpeting so far.
Re: beach wheel cradle questions [Re: davefarmer] #146639
06/25/08 10:14 AM
06/25/08 10:14 AM
gotcha
Re: beach wheel cradle questions [Re: davefarmer] #146640
06/25/08 07:18 PM
06/25/08 07:18 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Dave
I've got the same cradles, I made a small slit in the carpet to get the head of the bolt so that it sits down in the recessed area in the middle of the cradle, drill a hole in the cradle, and through the tube. Bolt thru the cradle and tube, you could add some 5200 and make it really solid.
Glue something rubberry, like a piece of radiator hose on the end of the bolt that sticks out of the tube with silicon, the cradles will hang down when they are not in use, and every once and a while they will spin to the hang down position when you are putting the boat on it and you dont want to put the boat down on the end of the bolt, it makes a nice neat hole. Yes, its been done before.
Re: beach wheel cradle questions [Re: bvining] #146641
06/25/08 08:54 PM
06/25/08 08:54 PM
Drill a hole in the edge of the cradle and run the line through that as well. That way when you pull on the line the cradle flips to the upright position.
When are you making it back to MN Dave? You need to put that fleet membership to work. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Re: beach wheel cradle questions [Re: Karl_Brogger] #146642
06/25/08 11:30 PM
06/25/08 11:30 PM
WA, ID, MT
WA, ID, MT
Great! Thanks for the ideas guys. Mike Hensel has graciously offered to swap me a set of cradles designed for this axel diameter, so the project just got substantially easier. Probably won't make it back to MN this summer, Karl. Hopefully next year!
Dave
Re: beach wheel cradle questions [Re: davefarmer] #146643
06/26/08 06:14 AM
06/26/08 06:14 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Bill pointed out a common problem, especially if you often have newish crew. An alternative to consider is to recess the bolts in the tubes. Drill a large enough hole in the bottom of the tube such that you can get a socket inside to tighten the nut on shorter bolts.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
0 registered members (), 626 guests, and 34 spiders.
