| Location for Spin pole base #146902 06/26/08 06:09 PM 06/26/08 06:09 PM |
Posts: 16 South Texas | Where is the best location to mount the spin pole base(other than the front of the boat). I am putting a spin on my 5.2 & have been told the ideal location is with a clamp on the dolphin striker, have also seen on Hobies where it mounts on the front cross member. This is a home made assembly, I found a two piece carbon windsurfer pole which is a little over 13 feet, I'll cut it to 12 ft mount my hardwere, etc. Any ideas, concerns. pics of other mounts.
79 Nacra 5.2 #1145
| | | Re: Location for Spin pole base
[Re: arbo06]
#146905 06/26/08 07:09 PM 06/26/08 07:09 PM |
Posts: 902 Norman,OK | On my 5.2 rig I bought the pin that the Inter boats use and just mounted it to the front beam,
check out my write up on the 5.2 spin rig I just finished. there are some good pictures and info.
10,795
guests, and 390
