Location for Spin pole base #146902
06/26/08 06:09 PM
06/26/08 06:09 PM
South Texas
Rockport Offline OP
Rockport  Offline OP
South Texas
Where is the best location to mount the spin pole base(other
than the front of the boat). I am putting a spin on my 5.2 & have been told the ideal location is with a clamp on the
dolphin striker, have also seen on Hobies where it mounts on the front cross member. This is a home made assembly, I found a two piece carbon windsurfer pole which is a little over 13 feet, I'll cut it to 12 ft mount my hardwere, etc.
Any ideas, concerns. pics of other mounts.
79 Nacra 5.2 #1145
Re: Location for Spin pole base [Re: Rockport] #146903
06/26/08 06:37 PM
06/26/08 06:37 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I used the front beam on my H-20 (RIP) with good results. I mounted an eyestrap with the enclosed insert horizontally on the beam and used a long cleavis pin to secure it.
Re: Location for Spin pole base [Re: arbo06] #146904
06/26/08 06:43 PM
06/26/08 06:43 PM
arbo06 Offline
arbo06  Offline
Ferrule eye strap, available at West Marine.
Re: Location for Spin pole base [Re: arbo06] #146905
06/26/08 07:09 PM
06/26/08 07:09 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
On my 5.2 rig I bought the pin that the Inter boats use and just mounted it to the front beam,
check out my write up on the 5.2 spin rig I just finished. there are some good pictures and info.
Re: Location for Spin pole base [Re: gree2056] #146906
06/27/08 05:41 AM
06/27/08 05:41 AM
France
pepin Offline
pepin  Offline
France
Mine has a U shaped piece of aluminium riveted to the front beam with a horizontal pin, parallel to the beam, going through the pole to hold it in place.
Re: Location for Spin pole base [Re: pepin] #146907
06/27/08 07:01 AM
06/27/08 07:01 AM
Tornado_ALIVE Offline
Capricorn
Re: Location for Spin pole base [Re: Tornado_ALIVE] #146908
06/27/08 07:03 AM
06/27/08 07:03 AM
Re: Location for Spin pole base [Re: Tornado_ALIVE] #146909
06/27/08 07:04 AM
06/27/08 07:04 AM
Re: Location for Spin pole base [Re: Rockport] #146910
06/27/08 07:52 AM
06/27/08 07:52 AM
Use a rubber universal joint for attaching the pole to the beam...inexpensive...piece of cake to attach.
0 registered members (), 21,527 guests, and 653 spiders.
Yesterday at 04:54 AM
