| Nacra 5.2 Spinnaker Pictures and write up #146931 06/26/08 06:39 PM 06/26/08 06:39 PM |
Posts: 902 Norman,OK | Hey, I have told three people I would send them some pictures of my 5.2 spin rig, but instead I thought I would post them on here again. These are not close up shots, if you want to know specifically how to do it I am going to do a write up here about it. 1. You will need all the parts, you can try and fabricated them yourself or you can order them online from Murrays.com (sorry rick you don't carry alot of the Nacra stuff in the online store) below is a list of parts and links to them Pin that mounts on front beam where the pole sits http://www.murrays.com/mm5/merchant.mvc?...p;Store_Code=MSSpinnaker Bale (this is what the line at the top runs through at you hoist to) http://www.murrays.com/mm5/merchant.mvc?...p;Store_Code=MSPole (just about anything will work, but about 12 feet has worked well for me) Snuffer hoop( mine is aluminum but you can buy carbon ones from ricks online store I believe) Spinlock cleat to cleat the halyard 4 ratchet blocks
| | | Re: Nacra 5.2 Spinnaker Pictures and write up
[Re: gree2056]
#146932 06/26/08 06:46 PM 06/26/08 06:46 PM |
Posts: 902 Norman,OK | Step one: I drilled a hole through each bow then refilled that with epoxy. The hole i drilled was about 3/4 of an inch and then once the epoxy hardened I redrilled a 1/2 inch hole. This was to make sure I was drilling into solid hull. You can see in the picture above that I ran a piece of non stretch line through the hole and tied a figure 8 knot on the outside and a loop on the inside. this give me something solid to attach the bridle wires that support the spin pole to. You can also see that I have bridles that run to where the bridle wires attach. This supports the middle of the pole. In the picture above I have no prebend in the pole but I now run with about 3 inch's of prebend in the pole that I pull into it using a truckers hitch on the two bridle lines up front. To support the pole vertically I have a loop of low stretch line tied around the connection of the bridles and the forestay. there is also a metal support that i made out of 1/4 inch stainless cable just like your shrouds would be made of but it was a pain.
[Re: gree2056]
#146933 06/26/08 06:50 PM 06/26/08 06:50 PM |
Posts: 902 Norman,OK | Step two: To ready the mast for the rig I mounted the spinnaker bale about half way between the shroud attachment point and the top of the mast. This may be a little high but my mast appears to handle it okay even up to 25mph wind as long as you keep the mainsheet tight to provide support for the mast. Above the bale I mounted a block which the halyard runs up through and then back under the bale.
That is really all there is to the mast setup, it was simple enough. depending on the spin you may have to adjust the hoist height but you can change that or the pole height. Both can cause problems so be careful.
[Re: gree2056]
#146934 06/26/08 06:56 PM 06/26/08 06:56 PM |
Posts: 902 Norman,OK | Step three: Rigging the sheets was pretty easy for me. I run an inter 17 spin and pole so if you have a different spin or pole you will run into some different issues.
For the outside set up blocks i have them attached at the shrouds to the bottom hole in the adjuster. This has worked well for me but you might want to experiment with farther forward or back. If you go forward just use a backer plate of some kind and bolt and eye strap to the hull. But I would be careful with that setup.
from that block the line leads to a block on the front beam, this is another ratchet block. It is attached at the same place where the wire for the jib blocks is attached. But you could adjust that depending on where you wanted it but I have found that to be about ideal.
Then the sheet leads to the other side and through two more ratchet blocks that are mirrored of the two I just mentioned.
Depending on the wind speed I either run no ratchets on or both on both sides on.
[Re: gree2056]
#146939 06/26/08 07:08 PM 06/26/08 07:08 PM |
Posts: 902 Norman,OK | If anyone has any other questions just ask on here, I will try to get on here once daily to answer any questions.
Disclaimer.... I am no expert and have extra hulls at an extra mast at my house so I didn't mind taking some risks.
[Re: gree2056]
#146940 06/26/08 07:16 PM 06/26/08 07:16 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit
Posts: 531 Lake Murray SC | Awesome!
If I can get anytime to work on our boat, I will use your write up!
Thanks!!!
E-Scow 24' ULDB
[Re: FasterDamnit]
#146941 06/26/08 08:19 PM 06/26/08 08:19 PM |
Posts: 16 South Texas | Exactly what I was looking for. Iam going to save it My favorites so I can refer back. Thanks. I may have additional questions, If I do i'll PM you.
79 Nacra 5.2 #1145
[Re: gree2056]
#146942 06/27/08 09:01 AM 06/27/08 09:01 AM | Anonymous
| Anonymous
Unregistered | but my mast appears to handle it okay even up to 25mph wind as long as you keep the mainsheet tight to provide support for the mast. SO you have tested your new spin at 25mph? Yea Haw! | | | Re: Nacra 5.2 Spinnaker Pictures and write up
[Re: BLR_0719]
#146944 06/27/08 11:43 AM 06/27/08 11:43 AM |
Posts: 6,049 Sebring, Florida. | You would rather mow the lawn than sail? You sick bastard... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> The lawn will still be there when the wind dies.
Blade F16 #777
[Re: gree2056]
#146946 06/27/08 02:31 PM 06/27/08 02:31 PM |
Posts: 271 Atlanta, Ga | just talking sh*t <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> | | | Re: Nacra 5.2 Spinnaker Pictures and write up
[Re: BLR_0719]
#146947 06/27/08 05:17 PM 06/27/08 05:17 PM |
Posts: 902 Norman,OK | That is actually the lawn next door, my front yard had a sunfish in it and it is mowed.
[Re: gree2056]
#146948 06/27/08 05:27 PM 06/27/08 05:27 PM |
Posts: 1,383 Kingston SE South Australia | You've got great neighbours, you dump all your gear on it so they can't mow the lawn and you keep yours neat. Does your wife know you own a cat? Thanks for your posts its perfect info for my project. regards
[Re: ThunderMuffin]
#146950 06/27/08 10:58 PM 06/27/08 10:58 PM |
Posts: 902 Norman,OK | In one of the posts I stated that after some tests I did start prebending the pole. usually about 3-4 inchs based on what the wind is doing.
822
guests, and 132
