Spinnaker care #146981
06/27/08 06:55 AM
06/27/08 06:55 AM
Pensacola, FL
C
Cab Offline OP
Cab  Offline OP
C
Pensacola, FL
Recently I have been getting small holes in my spin along where the retrieval line runs up the sail. In a previous post it was mentioned that this was caused by taking the spin down on the tack that put the retrieval line on the outside of the sail. This is the port tack for me and I have been taking the spin down from port more recently. Anyone have any ideas or solutions?
Chris
Trident F16
Re: Spinnaker care [Re: Cab] #146982
06/27/08 07:11 AM
06/27/08 07:11 AM
Matt recently mentioned stripping the halyard of the outer sheath in that area.
Problem is, I don't know how to do it. Maybe Matt or Patrick will come to the rescue. They're good at that stuff.
btw- my spin is more patches than spin. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Re: Spinnaker care [Re: fin.] #146983
06/27/08 07:36 AM
06/27/08 07:36 AM
Pensacola, FL
C
Cab Offline OP
Cab  Offline OP
C
Pensacola, FL
Thanks Pete. My spin is headed that direction too. I am trying to convince Nicole that I need a new set of sails, one for racing and one for practice. She is not buying it at all. It does seem right that if the line was slicker it would not damage the spin as much.
btw - I have space available for early November. Make your reservation soon.
Chris
Trident F16
Re: Spinnaker care [Re: Cab] #146984
06/27/08 07:41 AM
06/27/08 07:41 AM
We stripped the cover off the last part of our spi retrieval line, and had much less damage to our spis. Just take care to not remove much in one go, pulling on a slick spectra core is no fun!
Re: Spinnaker care [Re: Cab] #146985
06/27/08 08:46 AM
06/27/08 08:46 AM
chris,
sent you a pm.
make sure you lube up your spin and hoop really good too. I use the cheap 1$ variety spray silicone lubricant and really spray the heck out of the pole, spin, everything around there.
Re: Spinnaker care [Re: PTP] #146986
06/27/08 09:08 AM
06/27/08 09:08 AM
chris,
sent you a pm.
Also look everywhere the kite might rub on the drop, even the smallest sharp or rough edge can mark the kite.
Re: Spinnaker care [Re: scooby_simon] #146987
06/27/08 09:13 AM
06/27/08 09:13 AM
We used to lube our snuffers and spis, but finding the right snuffer made it so much easier on both crew and spi. Best snuffer we tried was the alu ring setup and except for stripping the cover of the line for the last meter or so (this was on a Tornado), we did not lube the snuffer, use the Holmenkol Sealn'Glide or other stuff.
Re: Spinnaker care [Re: PTP] #146988
06/27/08 09:22 AM
06/27/08 09:22 AM
Bob_Curry Offline
Bob_Curry  Offline
I agree guys, you have to spray everything everytime! Also, try turning the snuffer bag inside out and spray it too. If you find rough edges, duct tape or some kind of covering will help. Chris, tell Nicole that maintenence on the boat is like maintaining an airplane. If it wears out, it won't fly! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Bob <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Spinnaker care [Re: Bob_Curry] #146989
06/27/08 09:30 AM
06/27/08 09:30 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
When I got my new halyard from layline, it was a nice robline racing sheet 3mm spliced to some amsteel 12 strand. Its already pretty slippery where it runs through the chute, but I went a little futher and soaked the amsteel in some holmenkol overnight. Now its super-dooper slippery.
Re: Spinnaker care [Re: ThunderMuffin] #146990
06/27/08 01:12 PM
06/27/08 01:12 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
holmenkol liquid? I see a spray wax on the website, it that what you used?
Re: Spinnaker care [Re: bvining] #146991
06/27/08 01:35 PM
06/27/08 01:35 PM
Portland, Maine
Portland, Maine
no
its the seal-n-glide.
Same stuff you douse the chute in.
Re: Spinnaker care [Re: ThunderMuffin] #146992
06/27/08 01:57 PM
06/27/08 01:57 PM
How did you apply it on the spi? The Holmenkol website says to use a mop.
Re: Spinnaker care [Re: Tony_F18] #146993
06/27/08 02:11 PM
06/27/08 02:11 PM
We mixed it in a large bucket or similar and dumped the spi into it. Work the spi around and let it soak. Then hang it up to dry. Worked for us and was way easier than using a sponge.
Re: Spinnaker care [Re: Rolf_Nilsen] #146994
06/27/08 07:37 PM
06/27/08 07:37 PM
Portland, Maine
Portland, Maine
^ what he said. Used a big rubbermaid container.... dunked it, then tied it using some trailer bungies between two trailers and my car at Spring Fever. I don't know if it really is worth all the extra effort tbh.
Re: Spinnaker care [Re: ThunderMuffin] #146995
07/07/08 08:59 AM
07/07/08 08:59 AM
How long does Holmenkol last on the spin? How often do most people re-apply it? (at $35-$40/shot) it would get pricy to have to do every 3 or 4 times out...
Also, do you guys wash/airdry/ and fold up your spin after every use?
Re: Spinnaker care [Re: ] #146996
07/08/08 01:33 AM
07/08/08 01:33 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
For the week night racing, we use our old sails and just leave the spin in the snuffer, put a snuffer cover on.
Re: Spinnaker care [Re: ] #146997
07/08/08 09:49 AM
07/08/08 09:49 AM
Reno NV
Rhino1302 Offline
Rhino1302  Offline
Reno NV
My Glaser kite came with a package of Holmenkol and some instructions. The instructions said to mix the Holmenkol with 6 Liters of water and sponge it on the sail while it hangs in the shade (to keep the stuff from drying too quick).
I thought about dunking it in a bucket, but I'd have to dilute it more than recommended, and the stuff is expensive enough that I wanted to do it right.
I'm also storing the kite folded as recommended, although it sure would be easier to keep it in the snuffer.
Re: Spinnaker care [Re: Rhino1302] #146998
07/08/08 10:59 AM
07/08/08 10:59 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Flaking (folding) the kite makes a big difference in how long it stays crisp. By my estimate twice as long, possibly longer. It's well worth the time and hassle. I've been lazy and I've been diligent... diligent is better :-)
F18 USA 242
http://www.solarwind.solar
Re: Spinnaker care [Re: Cab] #146999
07/08/08 04:06 PM
07/08/08 04:06 PM
mbalhuizen Offline
mbalhuizen  Offline
I have been told that these small holes are actually burnholes that are created by the heat release by the friction betrween the halyard/retrieval line and the spinnaker.
By using swiftcord as halyard/retrieval line there is less friction/no heat or at least no more holes.
Making the spi as slippery as possible is of course a good idea. I know that our dealer in Holland applies a silicon coating much like the seal&glide as discussed here.
Just my 2 cents,
Martijn
Martijn Balhuizen
I20-The Netherlands
Re: Spinnaker care [Re: mbalhuizen] #147000
07/10/08 01:08 AM
07/10/08 01:08 AM
i am trying the Holmenkol today....
0 registered members (), 551 guests, and 93 spiders.
Posts267,056
